Question about In Microwave Ovens
When I plugged in my 2010 Montana 5th wheel, model #3075rl it fried my microwave, dvd player and my WII , now I do not have electricity in the bedroom part of the fifth wheel. How do you know if it is
When I plugged in my 2010 Montana 5th wheel, model #3075rl it fried my microwave, dvd player and my WII , now I do not have electricity in the bedroom part of the fifth wheel. How do you know if it is the outlet or a fuse? How do you check the fuses? How do you tell which one is for which part of the RV?
    Sergeant:
    Champion:
  • 282 Answers
Exactly where did you plug it into? It may have been a 220 volt outlet and if it was then you need to replace everything that blew out. Usually anything today are using circuit breakers rather then fuses.
Posted on Nov 26, 2014
MicrowaveSvc
  • 9047 Answers
SOURCE: Sharp Microwave Model R-1830: No power
A microwave can be dead for many reasons.
It may be the fuse, which is usually located behind the grille or on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open oven thermal cutout (TCO) on the top of the oven cavity / body or an open thermal fuse on or above the magnetron.
These should read closed (virtually zero) on a continuity check.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it went dead or when you plugged it in or opened or closed the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
You can usually find exploded views and order parts by entering your model number here at the Sears parts site but the best place to order Sharp parts is Tritronics.
Posted on Oct 13, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: GE Profile Advantium 120 Microwave (Model SCA1000DBB03)
We have the service manual for this model and have uploaded it to our site here to help you.
You will need the
free Acrobat Reader to view or print it in case you don't have it.
It may be the fuse, which is usually located behind the grille, on the floor of the oven behind the control panel, between the door switches, or on the filter board near where the cord comes into the unit.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking TCOs or thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
So don't let that fool you.
If the cavity thermostat needs to be checked or replaced you'll need to pull the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Dec 25, 2008
SOURCE: Microwave stopped working while cooking. Is there a fuse?
If unit is built-in reove screws holding unit to cabinet.
Slide out about 2 inches to access 3 screws holding grill.
Remove grill to get to two screws holding control panel.
Fuse is behind control panel,
Posted on Mar 17, 2009
atomicflash
  • 17 Answers
SOURCE: my maytag microwave lost power
There is always a fuse inside a microwave.Sometime this has only blown due to a surge,and upon replacing, the microwave will continue working.If it is something worse the fuse will continue to blow.In this case it could very well be the transformer,but there are other possible causes as well.(for example the control board or a short.)
Posted on Jun 24, 2009
  • 4088 Answers
SOURCE: HOW TO REPLACE BLOWN FUSE
Look for a reset button on the back--push to reset. If trips again, unit has probable short.
Posted on Jul 12, 2009
My microwave is making a shrieking noise ever since our power came on after hurricane Irma. Is there anything to stop this noise
Yes Noreen, Get a new one.. insurance?
....the table motor might be going out..(turntable)...its not hard to replace and the replacement motor is not expensive
Sep 19, 2017 | Microwave Ovens
Jenn air wall oven
Your microwave oven probably has been living on borrowed time since 2010. Consider replacing it.
Oct 05, 2016 | In Microwave Ovens
How do i get the back off my emerson microwave
Screws are probably on the bottom of the microwave - then the whole side and top come off - then you have access to the back - i doubt it has an internal fuse though! I presume you have checked the plug fuse.
Be very careful - microwaves generate a massive electrical output and will fry you in a second!
May 13, 2014 | Emerson Fans Emerson MW8115SS Microwave...
Interior light flashing and fridge not working
It might help to know some models and conditions - say, after a power hit which could have fried them both?
Two devices malfunctioning? I'd look at the power source. Plug the microwave in somewhere else.
Mar 12, 2011 | Microwave Ovens
After about 2 weeks of use, the microwave began to make a horrible buzzing noise from the "box" in the upper right hand corner on the back. It also smelled horrible. It then proceeded to stop working...
Two weeks? This is a warranty problem. The buzzing noise was probably either from high-voltage arcing or an overloaded transformer trying to drive a shorted component. The smell is from something electrical getting fried. Remember it; the next time you smell it, you'll know to pull the plug.
Oct 12, 2010 | Sunbeam SMW777 Microwave Oven
I AM LOOKING FOR A DOWN LOADABLE MANUAL FOR SHARP R-1874 850
Sharp Electronics has a website for support and your microwave is listed and there is a tab to access downloadable manuals etc Visit their page HERE
Jun 01, 2010 | Sharp R-1874 Convection/Microwave Oven
Blows the powerstrip
Hello. I can help you. Let me review some info. about microwaves.
First of all, a microwave requires a lot of power. Most microwaves must have their own circuit to work well for a long time. Do not use any powerstrip or other extension cord, always plug a microwave directly into the wall.
The problems you are having are most likely due to your powerstrip than to your home wiring.
Plug your microwave directly into the wall and use it. If it works then discard the powerstrip as it is a fire hazard. get back and let me know how u make out.
May 27, 2009 | General Electric Microwave Oven
The Keypad of my sylvania microwave does not work
Sounds like you have a bad membrane keypad.
To download owner's manuals for Canadian models of Sylvania microwaves, visit here, where you can also contact them.
For help with US models of Sylvania microwaves, contact Customer Service at 1-800-856-8977 (Mon-Fri 9:00-5:00 Pacific Time) or visit Galanz.
Dec 12, 2008 | Sharp R-1480 Microwave Oven
Microwave Ovens Logo
63 people viewed this question
Top In Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you an In Microwave Oven Expert? Answer questions, earn points and help others
