Question about Hotpoint Dishwashers
My hotpoint dishwasher model HDA2000G05 dishwasher has been hooked up and every time i try to run a cycle it runs for roughly 2-3 minutes then during the drain cycle it throws the error code C5, telli
My hotpoint dishwasher model HDA2000G05 dishwasher has been hooked up and every time i try to run a cycle it runs for roughly 2-3 minutes then during the drain cycle it throws the error code C5, telling me there is not enough water in the machine.
  • 46 Answers
It can only be the main mother board or the drain pump going bad. one of the two. Hop that narrows it down for you
Posted on Nov 23, 2014
  • 114 Answers
SOURCE: hotpoint built in dishwasher
Check your air gap on your kitchen sink. If equipped, you will most likely find it clogged. Pull off the metal cap, then unscrew the white or clear cap. You should find your clog there. Replace both caps and remember to pre-rinse the dishes better before loading.
Posted on Oct 02, 2007
  • 90 Answers
SOURCE: 18 in dishwasher drains water during cycles
find out how the dishwasher is set up to drain. Pour water into dishwasher 4 or 5 gallons, see if water disappears. if so, your drain is ran wrong
Posted on Jan 05, 2008
  • 3422 Answers
SOURCE: stuck in two minute drain cycle
It is possible that the unit has leaked.
I want you to please check THIS link it will solve your problem.
Don't forget to do the banging test mentioned there.
Goodluck..
Posted on Feb 25, 2008
  • 276 Answers
SOURCE: dishwasher cycles but does not clean the dishes
if your dishwasher is cleaning poorly, check these: Water-inlet valve Most cleaning problems are caused by the dishwasher not getting enough wash water, so the water-inlet valve is often to blame. This valve is usually at the bottom left or right of the dishwasher, behind the lower access panel. It's the device with the main water line from the house, a rubber tube to the dishwasher, and two wires attached to it.
When a water-inlet valve is defective, you may hear the sound that's usually referred to as "water hammer." If the water-inlet valve is defective, you need to completely replace it.
Dishwasher Water Inlet Valve Replacement
Be sure to read and understand any instructions that come with the new water inlet valve.
Tools required:
Adjustable wrench
Multi-Screwdriver
Pliers
Step 1. Disconnect the dishwasher from its power source.
Note: Dishwashers are usually wired directly to the home’s electrical system. To disconnect the power, switch off the circuit breaker or remove the fuse for the electrical circuit the dishwasher is attached to. Try to turn the unit on after disconnecting the power to be sure you were successful.
CAUTION: If you’re not sure you’ve shut off the power properly, DO NOT CONTINUE. Call a qualified appliance repair technician to complete the repair.
Step 2. Turn off the water supply to the dishwasher. This is usually underneath the kitchen sink or in the basement or crawlspace near the location of the dishwasher. Pliers may be helpful here.
Note: If there are no shut-off valves, you must shut the water off at the main water supply valve for your home.
Step 3. Remove the lower panel(s) of the dishwasher. These are usually held by 2 to 4 screws at the upper and lower corners of the panel(s).
The inlet valve is usually near the front of the dishwasher. Attached to the valve you’ll see: 2 or 4 wires, the water supply line from the house and the water feed line that goes to the dishwasher.
Step 4. Remove the household water supply line from the valve. The line is usually secured with a brass compression nut. The water supply line is usually copper or braided stainless steel.
CAUTION: Water supply line may be hot.
Step 5. Remove the fitting from the valve the water supply line was attached to. This fitting may be very difficult to remove. It may help to put the valve into a vice in order to remove the fitting. If you cannot remove it, replace it. The fitting is not an appliance part but a plumbing part that is available at most hardware stores.
Step 6. Remove the screws holding the valve to the dishwasher frame.
Step 7. Label the wires to the valve so you’ll be sure to reattach them correctly.
Step 8. Remove the wires from the valve.
Step 9. Remove the clamp on the black rubber water discharge tube and pull the tube off of the valve.
Step 10. Reinstall the old fitting (or a replacement fitting if necessary) onto the new valve the water supply line was attached to. Use Teflon tape or pipe joint compound as a thread sealant. Make this fitting tight to prevent leaks. Make sure that the fitting points in the same direction as the old one so that the water supply line will meet up with it properly.
Step 11. Install the new valve in the reverse order of the removal instructions.
Note: The water supply line is under high pressure. Be sure to tighten the fittings properly.
Step 12. Turn on the water to the machine, and check for and correct any leaks.
Step 13. Reinstall the access panel(s). Restore the power to the dishwasher and test.
Note: You may have to let the dishwasher run a few minutes before it reaches the next water fill cycle.
Internal filters Every dishwasher has some type of filter to keep large food particles and foreign objects away from the pump assembly:
  • Most modern dishwashers have self-cleaning filters that don't need any routine cleaning.
  • Some have filters in the bottom of the dishwasher that you need to periodically clean. You don't need any tools to remove the filter, and cleaning it is easy. Consult your owner's manual to determine which type you have and its maintenance requirements.
If your filter is clogged, it may be causing the cleaning problem.
Drain valve Some dishwashers have a valve (or gate) that should open only during draining. If debris lodges in the valve, it can't close properly, so water drains out during the wash cycle. Most dishwashers drain into the garbage disposer. If yours does that, listen for water flowing into the disposer during the wash cycle. If you can hear it then, the drain valve may be clogged.
Spray arms There's a spray arm at the bottom of your dishwasher--it may have a tall spray tube mounted to the center of it. There may also be a spray arm located directly beneath the upper rack of dishes and/or above the upper rack.
If debris is blocking the holes in the spray arms where the water comes out, it could cause cleaning problems. Regularly inspect each of the spray arms and clean out the holes as necessary.
Water temperature To get the best cleaning results, the water entering your dishwasher needs to be hot enough. Try running the hot water in your kitchen sink for about 30 seconds before starting the dishwasher, to pre-heat it. Also, if your dishwasher lets you select a higher wash or rinse temperature, try that to see if it helps.
To check the temperature of the hot water that comes from your kitchen faucet use a waterproof thermometer. If the water isn't 120 degrees Fahrenheit, your dishwasher may have trouble getting your dishes clean. You could increase the temperature of the hot water to the whole house--and therefore the dishwasher--by adjusting the hot water heater thermostat.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Detergent cup Dishwashers don't perform their best if detergent is introduced only at the beginning of a cycle, so add detergent to both parts of the cup.
Posted on Nov 19, 2008
  • 130 Answers
SOURCE: water in bottom of dishwasher, can't get it to drain
pull your water drain line out and place in a bucket on the floor. then try to drain it again. alot of time the hose get an air gap or blocked with gunk.
Posted on Feb 16, 2009
Most buttons dont seem to respond and the number 2 shows up and seems to be a countdown of 2 minutes. I can hear the motor running during that time. but it wont run, what is the prob?
Sounds like it is only going into the Cancel/Drain cycle. Probably a short in the control panel membrane. You will need to replace the control panel.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jeffrey_634abadf963e31e5
Nov 25, 2014 | Whirlpool Gold Series Quiet Partner Iv...
Hotpoint DC28 not washing
1.press cancel button
2.check if the door closes securely.
3.since there is water in d/w try running a short cycle.If it works, clean the inside thoroughly to ensure no clogs.
Jan 12, 2014 | Hotpoint 18 in. DC28 Slim-Line Built-in...
Hotpoint aquarius dishwasher tablet dispenser not working
Clean it by running a cycle with hot water and 2 cups white vinegar, I suspect you have mineral deposits built up and causing it to stick closed and this causes the problem
Jan 18, 2012 | Hotpoint Dishwashers
My dishwasher (model # DU81ODWGU1) is leaking water and suds during the wash cycle. I ran out of dishwasher powder so I had used regular dish soap for this cycle. Did this cause the problem? My...
MOST DEFINITLY You can put regular dish washing liquid in a dishwasher will do that every time take a few washings to stop run 2-3 times empty it will stop.
May 06, 2011 | Whirlpool Dishwashers
Water not draining after last cycle
Here is a tip that I wrote that will help you with your problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
May 13, 2010 | Hotpoint 24 in. HDA3740G Built-in...
Dishwasher during normal cycle gets hung up and does not advance
HI. this is just a control fault. you can try to reset the core program by unplugging this unit for 5 minutes. this will drain all power and reset the core on the timer/control.
If you experience the same situation after this reset, simply replace the control/timer module.
Jun 02, 2009 | Kenmore Dishwashers
Whirlpool Dishwasher won't drain during normal cycle
As you say a clogged line or valve does not make sense.
Try running it without the heated drying and see if it empties or if the cancel button will work then.
The dishes should air dry quickly if you empty it and open the door.
It could be a defective thermostat allowing it to get too hot during the heat cycle
May 18, 2009 | Dishwashers
Hotpoint WD860 problem
washer wf860 showing f07 error. why
Mar 04, 2008 | Hotpoint Washing Machines
Dishwashers Logo
63 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
