My heater comes on and lights up but does not put out any heat it's not that old any ideas on how to fix it
    Problem Solver:
  • 40 Answers
Is fan blowing any air out?
Posted on Nov 23, 2014
  • Joshua Derenburger Nov 23, 2014
    Yes it just blows cool air though
  • Joel C.
    Joel C. Nov 23, 2014
    If you can open it up, unplug it first. Check the wires that go to knob or button that adjusts heat.
Ford F150 only blows heat when truck is driving
May a a vacuum or electrical problem that actuates the blend door.
Jan 06, 2014 | 2002 Ford F150 Regular Cab
I have a bissell pro heat carpet cleaner. It is model 25a3 and about 1 year old. no water comes out when I press the trigger to clean the floor. The tools attachment works fine, any ideas?
If you are getting water from the tool. But not at the floor the most likely problem is the heater is clogged with coagulated soap or minerals. You will need to separate the upper handle to get to the heater. Insure the machine is unplugged. Remove the cover from the heater making sure you don't lose the little gaskets on each screw. Clean the channels inside the heater and put the cover back on. Be aware of how you are Taking it apart so you will know how to reassemble it.
Oct 31, 2013 | Bissell 25A3 Proheat Upright Deep Heated...
Crane convection heater won't come on
This seems to be a common problem among owners of this heater. The power light is on, but the fan nor heat will work.
I will post what I did to fix it, in case you are desperate for heat or something, but I don't recommend doing this and I'm not responsible for any loss you incur... bla bla dangerous bla bla you get the idea.
Take off the black side panel (not the side with the timer). It easily comes off by taking out the little screw around the edge. Inside you will see the heater bar with all the little heat-fingers sticking out of it. Towards the right you will see a little fuse thingy with a power connection behind right side. This fuse is blown. You can jumper past it or carefully pull that power connection off and unwind it a bit for extra slack and bring it to the OTHER side of the fuse where there is an available male terminal that just happens to be waiting there for you. While you are there, make sure all the heater fingers are separated nicely and free of dust-balls and stuff. Make sure the wires are secured away from the heat bar, and put the black panel back on. Yay it works again.
Oct 07, 2012 | Crane Convection Heater, White
I have a Coleman outdoor heater and the sparking unit works when pressed and pilot lights and I hold if for a minute or so and then when I release pilot to turn up the gas and light the heating unit, the...
Use a needle. You cad disamble it and clean it and clean the old wet propane out and replace it. I have one you can have - dont need it in SO CAL - pay shipping only
Jul 18, 2011 | Coleman (5040B750) Patio Heater
95 Jeep Grand Cherokee. A/C only blows heat. Dealer mechanic says something broken in dash and very costly to fix--not worth the money on old vehicle. If clamp heater/radiator hose, can get partial AC,...
Put an small brass butterfly valve in the heater line, on both sides. That will turn it off for the summer, and you can turn it on for winter. Alternatively, you could try and do like I'm doing on my '59 Chevy, when I get it out of the flood plain, and route ice water through the heater core.
Jun 05, 2011 | Jeep Grand Cherokee Cars & Trucks
I have a Lennox 80MGF3/4-100A-1 forced air gas heater and the pilot light isn't lighting automatically as it is supposed to. Can I light it manually?
NO, they are not like the old ones that sometimes you had to relight on a windy night.. there is not a gas pressure control lever and too many safety switches will keep things from happening. and the induced draft blower motor would be like starting a fire in a wind tunnel. even if lit. it would extinguish it's self at the end of the heat cycle and put you right back with no flame. i miss old tech!! so easy to fix. and keep it going. are the heating wires getting red hot! those hot wires are what ignite the fast flowing gas.
Dec 23, 2010 | Heating & Cooling
I have a 3000btu dnya glo unvented gas fied room
I'm not familiar with these heaters but I assume there is button or something you push to get the pilot to light. There will be air in the pipe between where the gas comes in and the pilot light. You have to give it enough time for the gas to push this air out of the line. Hope this helps.
Mar 13, 2010 | Dyna-Glo D-E37 Wall Mounted Panel Heater
Heat come through onl on passenger side
Look for a hole or opening in the fire wall from under the hood.
Wire harnesses, AC lines and heater hoses usually have a grommet that closes off the air leak where they come into the passenger compartment. One may have rotted or simply pulled out. If pulled out, work it back in.
If you can get under the dash with the seat pushed all the way back, you can put a drop light under the hood, get under the dash and look for the light coming in. If you see anything.....PLUG IT!! :-)
Dec 03, 2009 | 1999 Oldsmobile Aurora
Blinking Clean light in Whirpool dishwasher
Control is programmed to stop running and not allow any further cycles if it detects a water heating problem (no temperature increase detected in heated Main Wash on 3 consecutive cycles). Control blinks the Clean LED 7 times repeatedly and disables the Start/Resume key until cleared. Running Diagnostics clears the control and allows it to operate again. The water heating problem must be fixed or the control will stop running again. See potential causes below. Heater circuit problem: ■ Open in heater. ■ Open connection or component in heater circuit. ■ Faulty heater drive circuit on control. 1. Check operation of heater in Diagnostics cycle. 2. Unplug dishwasher or disconnect power. 3. Check resistance of heater and all components and connections in the water heating circuit or heat dry circuit.
dont forget to vote hope this helps thank you
Jun 20, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
I have a 2 year old kenmore series 400 electric dryer model 110.67422 and my problem is it will not get hot it turns light comes on just no heat i tested the contacts on the heating element with an ohoms...
if you got the meter to give you any reading the heater is good,so it must be the heaster box fuse,this fuse control the heat,if it get to hot it pops,.let meknow-mike
Dec 12, 2008 | Dryers
Heating & Cooling Logo
54 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
