Question about MMF Industries MMF 221619003 Heavy-Duty Steel Lay-Flat Cash Box w/6 Compartments, Combination Lock, Sand
How to change code for lock box 221619003
I need to reset the combination
  • 29 Answers
How to change the 3 digit code of my samsonite ?
Luggage manufacturer Samsonite offers a variety of business, personal, travel products and accessories. Many Samsonite pieces such as attaches and other bags include a three-digit, built-in combination lock. When purchased, the locks are set on a factory default combination that you can change as often as you wish.
STEP 1
Turn the number dials to the previously set combination, or to "0-0-0", the factory default combination for Samsonite luggage.
STEP 2
Locate the reset button, usually placed to the side of the combination dials.
STEP 3
Press the reset button and hold it while rotating the number dials to the desired combination. Set this to a sequence easy for you to remember but hard for others to figure out.
STEP 4
Release the reset button after you set the numbers to the new combination.
STEP 5
Test the combination by turning the dials to the new code to open the lock. If the combination does not open the lock, repeat Steps 1 through 4 and test the lock again. If you still can't open the lock, contact Samsonite Customer Service at 800-765-2247.
Aug 28, 2016 | Luggage & Travel
How reset combination lock
1. Open the lock with the factory preset combination of 0005.
2. Find the tab on the end of the part of the locking mechanism that has the numbers.
Combination Reset Tab
3. Flip the tab up (with the combination set to the open combination). When you flip the tab up, you disengage the number dials from the tumblers, so that you can reset the combination without changing the position of the tumblers.
4. Change the combination to the desired combination.
5. Flip the tab back down. The dials are now re-engaged with the tumblers.
Aug 13, 2014 | OnGuard Doberman Series Lock 8030
How to change the code on my gordon digital electronic safe
Most inexpensive electronic safes have a reset button inside. Push that and then enter the new combination and finally press the button you normally use to unlock. Confirm the new combination works before closing the door again.
Jul 04, 2014 | Safe International Digital Electronic Safe...
Change combination of S-50EB
Hi Ronald
To change the combination on the S-50EB you need first to open the safe. Once the safe is open, look at the thin inside edge of the door (nearest the hinges) and you should see a small reset button. Press the button and the amber light will come on. Once the amber light is on, you have 20 seconds to enter a new code. It makes sense to change the code with the door open, in case there is a problem.
Aug 01, 2012 | Safe International Digital Electronic Safe...
I want to reset the entry combination
Try and use default code 159a then try and reset if not go to harborfreight.com put in safe it has instructions on how to change all these are the same even if name is different
Oct 02, 2009 | Safe International Digital Electronic Safe...
How do I change the combination code for the glove box if there is not a way how would I find out what the combination is
I assume you know the current combination and can open it. To set the combination to a number code of your choice you must first remove the red plastic guard over the yellow tab next to the combination dials. Push the glove box release lever to the right to open the glove box. To change the combination:
1. With the glovebox open, hold the release to the right and slide the yellow tab up. This locks the release open and permits you to reset the code.
2.After resetting the code, write it down in case you forget it.
3. Slide the yellow tab down and the release will return to the closed position.
4. Close the glove box and move the dials off the code you set to lock it.
This is all from the 89 Pontiac Owners Manual. Good luck, hope it works.
Jun 15, 2009 | 1989 Pontiac Grand Prix
Reset lock code
there is only five combination for lock code you make a list manually gradually tried each combination and if you are fast doer it takes a day but If you won't only reformat the best solution.
Oct 18, 2008 | Nokia N95 Cellular Phone
MMF Industries MMF 221619003 Heavy-Duty Steel Lay-Flat Cash Box w/6 Compartments, Combination Lock, Sand Logo
957 people viewed this question
Top MMF Industries Retail Supplies Experts
Electroboy
Electroboy
Patrick Tinashe...
Are you a MMF Industries Retail Supply Expert? Answer questions, earn points and help others
