Question about Music
Trying to record a mix through a peavey board. I do not get a high pitch hum until I click rec on my Mac. I am connected via usb to the mixer board. Any suggestions on what I might could try to stop this coming through the system as I'm recording?
    Scholar:
  • 52 Answers
First, check your levels on the console. Is anything turned up high, channels, gain settings on channels? Check and see if the noise exists whith the main outputs muted or turned down. If it goes away it is a fader or gain setting on a channel. If it persists, then you have a co nection issue with the USB . Try a different cable. Make sure the Mac is on the same electrical circuit as the mixer, or if it is on battery, try adding it on the electrical circuit with the mixer. See if location of the mixer to the computer makes a difference as well. They may be too close to each other. Hopefully one of these things will fixya.
Posted on Nov 23, 2014
5 Suggested Answers
  • 5603 Answers
SOURCE: Lexicon alpha interface is recording a faint high pitched sound
Check for ground loops.
You MIGHT be able to cut the noise by setting the EQ's to clip the highs.
Posted on Aug 24, 2009
  • 5603 Answers
SOURCE: Our Peavey 32fx is not recognizing the memory
I wasn;t able to get a manual to download, however, a lot of these things MAX out at a 2Gb stick. If you try using larger, I suspect that might be the problem.
Blogs seem to indicate that the sticks are LESS than reliable and one has to remove a lot of effects due to CPU throughput being insufficient.
Make sure your memory stick is less than 2Gb
Posted on Jan 04, 2010
  • 5603 Answers
SOURCE: Connect xenyx 2442fx to computer
If you want to record in stereo, the quick and dirty way is to get a 1/4 inch stereo to 1/8 inch plug cable and go frrom the headphone output jack. (Use a Wye connector if you need to listen on the phones)
All the other outs are TRS and XLR balanced and the computer audio (mic) inputs are unbalanced. You would need special cables to connect those.
Posted on Feb 08, 2010
SOURCE: Iam trying to make my behringerXENYX 1204fx mixer, / connect
I have trouble my new behringer xenyx 1204FX VU led dead , like new VU it must play , how to repair this unit VU light
Posted on Mar 24, 2010
How do i connect my keyboard and my laptop?
Download USB MIDI driver for yamaha from yamaha website,and install to laptop.
Next:
Make sure the POWER switch on the instrument is set to OFF,then use an AB type USB cable to connect the instrument to the laptop.
After making the connections, turn on the power of the instrument.
Laptop will immediately notify that new hardwares is connecting and automatically install the drivers. Wait until the process is finish.
Thats all. In Ableton,the setting MIDI input must be set to USB MIDI.
Aug 19, 2015 | Yamaha PSRE413 Keyboard
I want to record using Tascam with my peavey xr1220 mixer
What Tascam recorder are you using? If you are multitracking you will be unlikely to be able to use this mixer. Otherwise get a phono lead to fit the tape out and suitable connections for the Tascam recorder at the other end. This will allow you to record the main mix but unless you are a solo act or putting everything through the PA this will probably be pretty useless to you.
Jan 07, 2015 | Peavey XR 1220 Powered Mixer Mixer Powered
Driver for Peavey PV20
what operating system are you using?
Feb 05, 2014 | Peavey Pv 20 USB 20 Channel Mixing Board...
I am trying to connect a computer to a peavey src 4026 to record sermons
Why not un-complicate the circuits by eliminating the soundboard first?
May 11, 2017 | Peavey Music
High pitch feedback
you are sending the signal back on itself, hit the usb to main switch to off.
Nov 12, 2013 | Peavey PV6 Mixer
Right fader knob doesn't do nothing. No sound come out from my right speaker when I turn the right knob up
PV series mixers from peavey suffer from horrible sliders pots quality, so be prepared to change that pot, it is pretty easy to change, real difficult comes out when you are trying to reach it, let me know a bit further to help you out troubleshoot accurately the issue.
Jan 18, 2013 | Peavey Pv 20 USB 20 Channel Mixing Board...
I have purchased a peavey pv 6 (not the usb) and I have a squeal problem when I activate the tape to mix button and rising the master fader to 0 and my headphone volume. I am using a creative soundblaster...
You MUST turn off the echo from the computer OR remove the sound card to line in connections. The tape out goes through the sound card and immediately back out to the tape in and around it goes for feedback.
Jun 28, 2011 | Peavey PV6 Mixer
I have the peavey xr 8600 and i wanna know how to connect an additional non powerd mixer to it ( i wanna use the peavey as an amp??
That's easily done. Simply connect the left(or right) output of your mixer to one of the channels on the peavey. Use any line input. Since the peavey is a mono system, there's no need sending a stereo mix to it.
Mar 08, 2011 | Peavey Xr 8600 8 Channel Powered Mixer
Getting a high pitched hum that is coming from the usb connection on the back of the mixer running into my imac. i disconnect the cable and the hum goes away. ideas?
This sounds like a ground loop. Make sure ALL (including the computer) interconnected devices are powered from the same receptacle. Make sure there are no lamp dimmers around as these can cause hum...
Dec 19, 2010 | Mackie Vlz3 802 8 Channel Analog Micline...
Using the USB connection to send the stereo mix to a computer
You have to insert a track into Reaper "arm" it. If you can't figure it out, I'd suggest posting in the Peavey forums.
May 14, 2009 | Peavey 32fx USB 32 Channel Mixer
Music Logo
Top Music Experts
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
