Question about Ctm Health & Beauty
What to do when charger cable has 4 pin plug but scooter has 3 pin socket
I have received a mobility scooter CTM HS-360 but it does not have the correct connector plug. The scooter has a 3 pin socket but the charger cable has a four pin plug. What is the best way to solve this? Is there a 4-to-three pin adaptor? Grateful to receive your help. Thanks. Eugene
    New Friend:
    Problem Solver:
  • 7 Answers
There are no adapters that go from 3 pin to 4 pin, However, generic chargers a relatively inexpensive. If you purchase a different charger, make sure that the voltage output is correct for your scooter. Also, find out what the scooter manufacturer recommends for amperes output. If the amperes are too high you risk causing damage to the battery from charging too rapidly.
Monsterscooters has been a good resource for me. They have researched the parts I need, and even if they didn't carry them, they let me know what I needed so I could try to find it elsewhere.
Posted on Nov 26, 2014
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 87 Answers
No, you need the correct charger.
Posted on Nov 23, 2014
wcdoc1953
  • 280 Answers
SOURCE: tire pressure for the The
This scooter may have air free tires not requiring any inflation. This type of tire has foam in the tire and is maintenance free. Look for a air inflation nozzle coming out of the tire. If you don't see one the tire is air free. If you do have a nozzle, then you can add air up to the maximum inflation pressure written on the side of the tire. Hope this helps.
Posted on Feb 21, 2011
SOURCE: Need owners manual for A ctm hs 740 mobility
go onto ctm homecare website and into rescource centre then dowloads and click on 740, regards, Bill.
Posted on Nov 06, 2011
SOURCE: Where can I download a manual for Mobility Scooter HS-360
Have you tried ( bt junkie ) you will need a bittorrent to use it i use ( u torrent)
Posted on Jan 11, 2012
gewiz
  • 1271 Answers
SOURCE: Have a shoprider monaco, red light flashing on charger indicating a break somewhere, have tried another charger still the same. have changed the 3 pin charging socket on the scooter, still the same, h
first of all don't use a 12v charger they are for car batteries only
the read flashing light as in low battery ? please confirm ?
Posted on Dec 09, 2012
gewiz
  • 1271 Answers
SOURCE: i need info or specs on a C.T.M. mobility scooter HS-686 motor model 1110-938
hi, my understanding that is a 350 to 400 watt , 24v motor, now the exact wattage should be stamped on a label mounted on motor, resistance wise you looking at about 0.4 to 1.0 ohms, that is the resistance of the brushes etc. Poorly fitted brushes or brushes that are deformed ( is the string ok ) will result in a higher resistance. are you looking for a like to like replacement.
Regards
Posted on Mar 10, 2013
Battery fullycharged hazard light flashing scooter wont go
Count the Flashes, it is a flash code. Need the number of flashes.
May 02, 2016 | CTM Homecare CTM HS-360 4-Wheel Power...
Where can I download a technical and repair manual for a C T M HS-360 MOBILITY SCOOTER 4 wheel mfg 2003 and parts list?
go google and type in workshop manual for ctm mobility scooter model hs-360
the first page has a pdf version for down load and the site is ctm mobility scooter-ctm home care product .inc.
further down the sites is a pdf version download parts manual as well -- ctm home care hs-360 parts
Oct 24, 2015 | Health & Beauty
ON 325 SCAL, ORANGE WIRE FROM CHARGER IS NOT CONNECED. WHERE GO
hi , i take it you referring to a on-board charger ? if so would bit be possible to see a photo of this ...
Regards
Rob
www.gewizrepairs.co.uk
May 01, 2014 | Ctm HS 890 4 Wheel Heavy Duty Power...
Hs 360 scooter light flashes 7 times how do i fix the problem
Hi, this is normally because the throttle pot is either not dead centre or related cabling etc to the controller has been damaged. when looking at the throttle lever look at the centre stem, you should see a cross head, now when at rest this should be dead centre to you, if it isn't it means it moved and that's the fault. Now loosing the related holder etc will allow you to centre it again.. Please contact me for more info if required..
Regards
www.gewirepairs.co.uk
Dec 18, 2013 | CTM Homecare CTM HS-360 4-Wheel Power...
Need owners manual for A ctm hs 740 mobility scooter.
Jun 14, 2011 | Ctm HS 890 4 Wheel Heavy Duty Power...
Health & Beauty Logo
94 people viewed this question
Top Ctm Health & Beauty Experts
wcdoc1953
wcdoc1953
Jeff Tilburn
Jeff Tilburn
Oloyede Monsuru
Are you a Ctm Health and Beauty Expert? Answer questions, earn points and help others
