Can a levono charger work with dell? - Computers & Internet
    New Friend:
    Problem Solver:
  • 19 Answers
No, Lenono will only work with Lenovo. All laptop fittings are different, also be careful of wattage
Posted on Nov 23, 2014
MY DELL AXIM CHARGER DOESNT SEEM TO WORK AND I WANT TO KNOW IF I CAN GET A SUBSTITUTE CHARGER
contact the manufacturer we do not have items here for sale , just advice , some good ,some not so much
Nov 03, 2016 | Dell Computers & Internet
Levono g560 right touchpad button not working
If something was spilled on the keyboard, that could happen.
Otherwise, you most likely have a bad button. You will need to have the keyboard replaced.
Jan 10, 2014 | Lenovo Computers & Internet
When I connect charger with my laptop 30 sec show battery is charging after 30 sec one message show:- QuickSet The Ac power adapter type cannot be determined. your system will operate slower...
del recognition circuit may have failed in charger , or could be fine central pin on charger plug or laptop plug has broken connection,it is used to tell laptop that this is genuine dell charger.If you remove battery will laptop work off charger.if does then definitely one of the three problem possible . for first only soln try another dell charger first,often has to be one to suit your model ,common dell problem ,if then work and charge battery ,you will need to replace charger as recognition circuit failed. If either of last 2 can repair but need to pull apart repair broken connection ,or open up laptop and check power connection and repair connection . If you remove battery will laptop work off charger.if does the definately one of the three problem possible . for first only soln try another dell charger first,often has to be one to suit your model ,common dell problem ,if then work and charge battery ,you will need to replace charger as recognition circuit failed.
Oct 27, 2013 | Dell Inspiron 65W PA-12 1525 LAPTOP
Using a Dell Inspiron no apparent power to laptop with our without a adapter. New universal laptop charger...still light on charger goes off as soon as connected into laptop power port.
hi
sounds like the laptop has a motherboard fault, dell laptops need to be run from dell chargers only and at correct voltage and correct amps output. the information is normally provided on lable on the base of the laptop, universal chargers do not normally work on dell laptops, would suggest you try and use original dell charger .
Aug 07, 2013 | Computers & Internet
Hi i have a dell 6400 notebook when the charger conected to notebook cpu usage is 100% and do not work corectly but when disconect the charger work normal and good, (whith battry) this problem happen when...
hi
when plug adoptor any trebal in mouse working if mouse aero do some problem buy orignal charger
becuse local charger is not work properly dell some model spaishaly 6400 ok if u have orignal charger change bettary
if fix your problem click yes for vote
Jan 06, 2011 | Dell Inspiron 6400 Notebook
6 month old dell inspiron 1764 says can not identify a/c power adapter works with only the battery and works with charger will maintain around 50% but not charge
HI there,
In most instances, just as you've described yours, the culprit is usually the charger. It's not uncommon for the charging system in the charger to cease to function while the power function continues to work. This is particularly true of Dell chargers.
If the laptop is still under warranty, call Dell Support and they'll almost surely send you a new charger because this problem is considered to be a possible safety hazard.
Since Dell's standard factory warranty is for 1 year, they should be able to help you. If not, and you have to purchase a new battery on your own, be sure to purchase ONLY a Dell charger
Sep 19, 2010 | Dell Computers & Internet
How do you change hinges on a levono series y530
call 1-877-453-6686 and have tech support create a depot service for you...that will take 9bus days to be fixed and that is for free...advised to use Fedex as a courrier...smile:D
Mar 26, 2010 | Lenovo IdeaPad Y530-5243U
Charger not recognized
Folks.
The issue with most of the Dell charger issues rekated to a new charger not being able to charge the battery is the fact that Dell has a screwy proprietary circuit design in their laptops and chargers.
It seems that the Dell laptops are designed so
only Dell chargers will work. While other
brands of chargers will power the laptop when plugged in,
they will not charge the battery.
They do this so they have a monopoly on their chargers and thus can charge a frickin' fortune for their, Dell chargers.
Want them to change this? don't buy Dell products for a while. If enough people ban them, they would change this **** overnight!
Jul 07, 2009 | Dell Inspiron 1501 Notebook
Levono X301
Where as your mac is concren have you tried to reinstall the clean reinstall of MAc os? if not then try that once.
And you would get info about Levono X301 on
http://www.notebookreview.com/default.asp?newsID=4603
Dec 22, 2008 | Lenovo ThinkPad X301 Laptop Computer -...
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
