Question about Elna Sewing Machines
Hi, my elna lock f4 keeps on breaking the nr2 string. I have treid everything, changing tension...... please help
Playing around with tension, took it for service! Still keeps on breaking. It works for about 7cm then it breaks again. Don't know anymore
  • Elna Master
  • 1,860 Answers
Try changing the needles, also try adjusting the tension, make sure it's threaded correctly
Posted on Nov 24, 2014
SOURCE: thread breaking.
Have you tried to change needle?
Posted on Feb 20, 2008
SOURCE: Elna SU missing stiches and breaking thread
it sounds like the needle hook timing is out. You need to get the needle in the lowest position and measure the gap from the needle to the hook point on the bobbin shuttle. It should be 1/4". You will need to remove the foot and foot plate to be able to see. I use a 1/4" drill bit as a gauge. If you need to adjust it, you will need to remove the free arm cover to the right of the foot and loosen the 2 allen head screws that hold the drive gear. Adjust the gap, tighten the screws and retry. Usually if the needle catches the thread to early, it will make a bad stitch and the upper thread will break. If it catches to late, it will make thread loops and the machine will skip stitches. Good luck, these are a good machine and worth fixing. Phil
Posted on Nov 13, 2008
SOURCE: Thread in needle or bobbin keeps on breaking
The tread only breaks in the needle. what can i do . i don't get to sew anything . I tread the needle and get everything ready and start the machine and as quickly as that the tread is broken and the machine has not sewn at all.
Posted on Apr 07, 2009
  • 55 Answers
SOURCE: Thread Breaking On Brother Sewing Machine
if thread is good quality you may have a sharp groove in your needle plate hole from needle breakage. if so, polish with emery tape.
scott
Posted on Jul 27, 2009
  • 8 Answers
SOURCE: Top thread keeps breaking on my Janome 1600P.
I had a similar problem and then realized that the thread on the top had a **** on the spool it was catching on.
Posted on Sep 24, 2009
I have an Elna Pro 4 DE overlocker and the thread keep breaking - I have re threaded a number of times now but the thread keeps breaking - it was working fine earlier today - what could be the proble
Try different thread (black thread seems to be more problematic because of the heavy dye). Perhaps, change the needles.
When you re-thread, do you completely remove all the thread and start from the beginning--there could be a snag somewhere or the thread is looped around something, ie the thread tree? ALWAYS RAISE the presser foot when threading. Give each thread an extra little tug when going through the tension disk--it will sometimes make a little snap sound when it seats. Also, make sure you are threading each in the order specified. Threading out of order will generally guarantee a problem.
There is a slight chance something (thread bits, lint) could be stuck in the tension disk.
If it continues, you may want to take it for service as it could be the timing is off.
Dec 12, 2016 | Elna Sewing Machines
I'm having trouble properly threading my Elna 1010. Could you please help? The bobbin thread keeps bunching up and breaking
bunching of thread under the material is an indication of insufficient tension of the needle thread
increase the needle tension until the threads meet at the center of the materialbeing sewn
Jul 26, 2016 | Elna Sewing Machines
Thread keeps breaking when I sew.
one of three issues: top tension too tight, bottom tension too tight, needle timing off.
Oct 21, 2015 | Elna 2005 Mechanical Sewing Machine
How to adjust the tension on ELna F4. I started out with the factory settings but the needle threads are very loose no matter how high I turn the tension.
Be sure to raise the presser foot BEFORE threading the upper thread so that the thread will seat properly in the tension disks.
Sep 18, 2015 | Elna Sewing Machines
What is the standard elna lock f4 thread tension settings
five on all tension dials and stitch length between two and three for a normal 'marrowing' 4 thread overlock. at factory tension dials would all be set to five.
May 13, 2011 | Elna Sewing Machines
I have an elna overlock Pro 5DC, which I bought new years ago. The dealer went out of business, and with her the repairman who knew Elnas. When mine developed a problem, I had it serviced by an all-brand...
If you google elna overlock pro 5dc, I found this site and you can download your manual for $10, hopefully it will help you.http://www.tradebit.com/filedetail.php/30251842-elna-pro-5-dcde-sewing-machine-owner
It is so frustrating to have a great machine and no one can help you. Good luck
Sep 21, 2010 | Elna Sewing Machines
My thread keeps breaking, I have changed thread type but it still keeps happening, as I cannot find my manual could you please help? thanks
I suggest you change your needle and make sure you're using the right needle and thread combination for the fabric you're trying to sew. Also, don't use old thread. Exposure to sunlight and age weakens thread. If the tension on the top thread is way too tight that could make the thread break also.
Good luck and let me know if these suggestions help.
Jan 11, 2010 | Elna Sewing Machines
Sewing Machines Logo
113 people viewed this question
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
