I have Samsung SMB2030 Moniter I wanted to know which tv tuner card will be supported by it.I want to use external tv tuner card which will work without CPU
5 Suggested Answers
dugiehowsa
  • 114 Answers
SOURCE: moniter activation when turning on the cpu
First, I would make sure that the latest drivers for the video card are installed. If the video card is from a major manufacturer, then Windows Update might even provide them. Next, try booting the CPU into Safe Mode (hitting F8 when the computer first boots). Does the video display now? It may appear very large, as the resolution is turned down to the lowest settings. If the video appears correctly in safe mode, then the resolution settings may just need to be turned down in normal mode. The monitor may not be able to handle the video card if the settings are not compatible. Once you can boot back into normal mode, right click on the Desktop and select Properties. Then go to the Settings Tab. From here, turn down the resolution all the way. Then reboot. Does everything appear normally after reboot? If so, then turn up the resolution another notch. Keep repeating this process until you find a setting that the monitor can't handle, and then turn it back down one notch from there.
Posted on Oct 12, 2006
SOURCE: unable to use intex external TV tuner with acer 19''
LCD TV tuner is different than a CRT
Posted on Nov 09, 2008
bharrie
  • 158 Answers
SOURCE: how to connect external tv tuner card to creative sound card 5.1?
look for audio out in the external tv tuner. connect your speakers to it.
let us know the results, thanx
Posted on Jan 20, 2009
SOURCE: TV TUner external not starting up
Safe mode
Power saving off
restart normally
Posted on Feb 01, 2009
I have samsung SMB2030 LCD MONITER I wanted to know that it supports which tv tuner card
The output of the tuner card must match the input of your monitor. Assuming it's a fairly recent tuner card, it probably has HDMI output, so your TV must have an available HDMI input. Older tuner cards had VGA outputs which many monitors still utilize, although the display won't be nearly as distinct as with HDMI.
Nov 23, 2014 | Computers & Internet
Hi, I have buy a Frontech External TV Tuner card. On connecting to my LCD monitor (AOC) the monitor displays "Input Not Supported", but if my computer is running fine from the card (as manual...
TV tuner cards receive an input. Your monitor should still be connected to your computer using the VGA/DVI/HDMI output. The software for the TV Tuner should take the input from the external cards input and output it to your monitor like any other desktop application.
If your Monitor is giving you input not supported from your standard video output then you may have your resolution set to high,or the monitor frequency set too high (max of 60hz typically for LCD)
Sep 06, 2011 | Computers & Internet
Can the moniter be used as somthing els
YES IT CAN BE USED AS A TV BY CONNETCING AN EXTERNAL TV TUNER CARD. IF NOT THAT WE CAN ONLY USE THE PICTURE TUBE TO CONVERT IT INTO A TV.
May 13, 2011 | BenQ V773 17" CRT Monitor
I have a samsung lcd monitor , i want to use it as a tv which tv tunner card would be better external or internal and which brand thanks
These are the best brands so far that I have encountered.
Avermedia AVerTV DVI Box TV Tuner / Video Input Adapter
or the
Leadtek TV Pro 1680 tv box tuner
Apr 28, 2010 | Samsung SyncMaster 2233BW 22" LCD Monitor
Want to use samsung 2233SW LCD monitor as TV
Yes you can, if you has PC desktop, plug your lcd to it. change LCD resolution from your PC.
-- Right Click on desktop
-- Click properties >> click settings tab
-- You will see Screen Resolution, change to the lowest (800x600)
-- Nnplug VGA cable from PC
-- Now plug the cable tou your TV Tuner.
Feb 08, 2010 | Samsung SyncMaster 2233SW Monitor
How can I watch Television on my laptop?
you may need an external TV tuner connected to your laptop, the cable signal/connection will be connected on the tv tuner.
Let me know for any clarifications
Sep 05, 2009 | Acer ASPIRE 5720-4649 Notebook
How to connect external tv tuner card to creative sound card 5.1?
Jan 20, 2009 | Creative Labs Sound Blaster Live! 5.1...
Unable to use intex external TV tuner with acer 19''
Frontech external Miracle TV tuner not working with LCD(ACER 15") monitor. Error msg "input format not suppoting". But CRT monitor (samsung 14") is working with the same.
Pl give advice mr.reghu@yahoo.com
Jan 11, 2008 | Acer AL1916W 19" LCD Monitor
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
