Question about Craftsman Garden
How do I fix a seized depth ajustment on a Craftsman Router model number 315.269210
Tried to turn the depth ajustment in a vice it moves but not practicle ?
  • Craftsman Master
  • 2,478 Answers
Did you use wd-40 or something
Posted on Nov 23, 2014
Testimonial: "My question has nothing to do with riding mowers"
Craftsman router Mod. 315.17390. Adjustment rings are jammed.
The 'Adjustment rings' you ask about IF for depth 2 choices. 1-force out & retap/rethread. 2--replace router support stand. Suggest call 1--800-491-3457 or www.searspartsdirect.com. Have a good day!!
Nov 04, 2016 | Craftsman Garden
NEED A MORE IN DEPTH WIRING SCHEMATIC FOR SEARS CRAFTSMAN RIDE ON MOWER MODEL#917-259001
Go to www.searspartdirect,com Put in your model number and it will show you the schematic that you are looking for.
Jun 15, 2011 | Craftsman Garden
Do you have a copy of the manual i can download? Is there a way to tighten up the depth setting? it vibrates loose and loses it's depth when running.
Jerry, You haven't said what brand or model of router you have, so I can't help you with the manual. But I have had the problem you describe with a Craftsman router that I used to use. I was able to reduce the problem by replacing the bolt and wing-nut with a bolt and nut that I could tighten using a wrench rather than just my fingers. I also added a lock washer under the nut and another one under the head of the bolt too. Like I said, this is a router I used to use. I use a Porter Cable router now, which is much better.
Good luck, Al K
Dec 07, 2010 | Skil Tools & Hardware - Others
Snow blower won't stay running
ok heres what you do to get your snow blower to keep running.
while you have it choked, and you get it to the running point, turn the cup bowl ajustment in/out a fraction at a time while you move the chock off slowly till you get the right setting to keep it running then ajust the setting once more to clear it up to purrr like a kitten again the vibration moves the screw out to set everything out of wack......
Feb 09, 2010 | Craftsman 16" High Garden Tractor Snow and...
Cannot adjust router depth.
Build up of dust in the threads and or slides.....
Jan 29, 2010 | Hand Tools
Manual Craftman professional router table model
I have a Craftsman professional router table, laminated model 26608. I can not find a parts manual for this item. I tried a number of way to find parts for this item. I believe this was made by Bosch. I can not purchase a Router table mounting plate for this item. it measures 7" x 8". with a center hole of 3". also 3" insert rings. Bosch and Sears makes items for a professional router but the center hole is 3 3/4 inches and the plate is a lot larger in width and length. I have gone to Bosch on the internet and came up with a model RA1171. This is a model like the one I purchased; however, they have changed the size of the adapter plate and the center rings. the model no. they show is 29LCN1428.
Dec 31, 2009 | Craftsman Milescraft 1207 Turnlock Wood...
Have replaced drive gear on Craftsman GDO. Everthing engages and chain moves but door only opens 3 inches are so. Have ajusted opening cointrol on side to max and only 3 inches. When I unlatch GD from...
Loosen the chain enough that you can remove it from the pulley on top of the motor unit. Now with the door closed run the motor until the pulley turns in the clockwise direction and stops. Put the chain back on the pulley and tighten. You may have to tweak the up and down limits now.
Nov 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
Color depth problem I got kicked off computer earlier and when i logged back on the screen is all weird colors. I tried to use slider ect to fix problem but slider does not move it is stuck. I keep getting...
Double check for appropriate driver for the video card. Enter your service tag number at http://support.dell.com to find downloads.
-=/ Daft Tech /=-
Oct 23, 2009 | Dell Computers & Internet
Cannot remove the fixed base
Are you sure the lock nuts haven't loosened and worked their way down the threaded rod to tighten the router down into it's plunged position? That's a really common thing to happen with plunge routers, but without a model number I can't give you any certain advice.
Try breaking those two nuts loose and spinning them back up the stud and see if that doesn't do it.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread. If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Mar 15, 2009 | Tools & Hardware - Others
Maybe motor
how old. what model. if old, gears may be stripped. take off cover and watch limit switches. are they moving; contacts ok ; wires connected.
Jan 19, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garden Logo
44 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
