Question about SAMSUNG GT E2652
Battery charging failed,battery charger adopter ok
Presently the spare, battery replaced,and battery charging with portable charger.
    Filmmaker:
    Uploaded 5 video answers.
  • 100 Answers
2 most likely possibilities in my experience: Phone plug has been bent/damaged this has happened to us on 2 phones.(most likely an internal wire). It will require service.
or
2) Cable or wall plug transformer have been damaged and charge is minimal or cut off (happens if the progs get bent or the wire gets kinked or over flexed or pulled hard.
Test each component with a friend's / co-worker's unit that you know is working (or at the store) Replace components as necessary.
Posted on Nov 25, 2014
My dcr trv 285e is not charging .working on battery and camera is on with a/c adopter lead but no charging light and battery is not charging in power off mode . Please.help
If the battery is not holding a charge, I think the only solution is to replace it. Have you tried with a spare battery ?
Oct 06, 2016 | Video Cameras
Is the charger to be "on" while charging it; then on while hooked to battery?
The portable charger should NOTE be connected to a battery while the battery is connected to a vehicle! Charge the battery off the car, then disconnect the charger and put the battery into the vehicle to start it! If the charger is not working check the fuse! If that is ok then probably damaged the circuitry!
Jan 02, 2015 | Cars & Trucks
I have a sterling diamond scooter. How can i use jump start to charge the battery? Is there any emergency portable charger to carry if i get stuck outside and there is no car or power.
It might be easier to carry a spare battery. I am not familiar with your unit. I do not understand how a jump start would work without an external power source.
Dec 06, 2014 | Health & Beauty
Battery not charging
sounds like bad connector on the phone
Feb 12, 2014 | Cell Phones
Is it a replacement battery ,you purchased, with the EXACT same specs? Some aftermarket inexpensive batteries do not work well with your laptop. How do you know it's not charging, by the Icon in the Tray Notification Area? Again sometimes aftermarket batteries don't have the ability to communicate with the software. The pin-outs are not the same.
Dec 09, 2012 | Computers & Internet
My speakers stopped charging. Now the battery is dead and the speakers are completely useless. Is there anything I can do?
The first thing you could do is trying another charger of the same type, if the battery starts charging you'll only have to get a good charger, if it doesn't, you have a failing charging jack, circuit or battery at portable speakers.
Feb 16, 2011 | Apple Logitech Inc MM50 Portable Speakers...
My laptop is not starting when I plug in adopter the charging light shows but when I press start button light goes off and it does not start. Is this a battery problem. I always use the charger/adopter to...
Try removing the battery and then starting the computer with the power cord. Sometimes the battery is bad and prevents the computer from working properly.
Aug 02, 2017 | Acer Ferrari 3200 Notebook
Whenever I charge the battery, the orange light on the charger won't light up/show. Then, when I put the battery in the camera, it will not turn on.
Rechargeable batteries don't last forever. This one may have simply stopped working.
However, it is worthwhile checking that the contacts on both battery and charger are clean. Dirt or corrosion can prevent the battery from charging.
There is also the possibility that the charger has failed. You can buy a new battery and try charging it. If it charges, then the charger is good and the old battery was the problem. If it doesn't, then you must get a replacement charger, and you will have a spare battery, which is no bad thing.
Oct 27, 2010 | Cameras
DUR-7 charging problem
Are you sure it is not the charger itself at fault here?
If you have or know someone with a multimeter get them to check if any voltage is present on the charger plug of the cord. Batteries do not suddenly stop they usually give less and less time in uptime mode before they finally stop altogether. I would suspect the charger or charging circuit.yes it can be fixed
Please rate my help++++Thanks for using FIXYA
Jun 03, 2010 | Durabrand DUR7 Portable DVD Player
Hace a APC XS 900 that said battery needs replacement, unit is about a year old. I replaced the batteries & it lasted about 2 hours & again says replace batteries. I know the new batteries are OK...
disconnect one terminal of the battery then measure charging voltage betwen +ve and -ve it should be 13.8vdc for one 12v battery if charging voltage is not present then battery is ok then connect ammeter to measure the current in Ampere .take care it should be in series if current if no current then battery must ok opern the ups there is a charger transformer measure i/p voltage to transformer if not present then check i/p path if present then check diodes at o/p of charger if faulty replace it also check capacitor and regulator ic if faulty replace it your problem must be solved
Mar 13, 2010 | APC Back-UPS XS900 (BX900) UPS System
SAMSUNG GT E2652 Logo
53 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
