Question about Honda Carburetor for HS520 Snowblower
I have a honda snowblower SZAN-1131370 how can i stop the back firing it starts up ok with chock on but when i shut choke off it seems to backfire does the air needle valve need to be adjusted
    Master:
  • Honda Master
  • 428 Answers
Well my best guess is to take the carb a part and clean it and put it Back together and see what Happen,s Ok
Posted on Mar 10, 2015
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,095 Answers
Carburetors never need to be adjusted once they have been adjusted at the factory UNLESS something is not right with the carb.
If the gas has been in there since last season I suggest you take the bowl off the carb and see if the Ethanol Gas caused the internal parts to rust. Ethanol gas is a very bad idea that the politicians forced on us without considering the affects
Posted on Nov 25, 2014
How to start my "Toro Power Clear 621e snowblower"
Usually full chock, pull a few times,if it doesn't start go to half chock. Out should give full chock.
Jan 05, 2018 | Garden
After start it backfires, sputters then runs
Hi,when starting bike you put the chock on,remeber this is to make a richer mixture for cold start,so when you start the bike put put the choke off a little bit as it warms up,other wise wat you are doing is couseing it to floud,so again as the bike warms up put the choke off little bit at a time,all the best.
Sep 01, 2015 | Honda VT 1100 C2 Shadow Sabre Motorcycles
I am getting gas In the crankcase. engine back fires run only with choke out
float is stuck, bad needle and seat, debris between needle and seat and check air cleaner made sure it not oil or fuel soaked even if dry replace
Sep 18, 2014 | Honda Horizontal Engine 5 HP OHC 3/4 x...
Bike starts but stalls when the choke is shut off
First clean carbs, slow and main Jet also, if 1 (or 2nd) cylinder is not getting enough fuel, it will back fire. 2nd, if you change pipes to a custom opened ones, you have to sync the carbs, if that is not possible (to sync carbs), you have to change slow and main jet 1up.
sync
https://www.youtube.com/watch?v=oep9AyqcVXk
Apr 18, 2014 | 2004 Honda VT 1100 C Shadow Spirit
Backfiring and trouble starting
If you change the exhaust pipes, you have to sync the carbs (if you cant sync them, you have to change the carb jets), usually it is backfiring because the carbs are not in balance.
May 18, 2013 | 1996 Honda VT 600 C Shadow
I have a xr650r it is running fine but it seem
I'd check these things: Is the choke in the "on" or choked position? Is the air filter clean and the air filter inlet not obstructed by something? Also, if the bike has been sitting for more than about 6 months, it is possible that the carburetor needs to be cleaned out and/or the float is stuck.
Oct 23, 2009 | 2005 Honda XR 650 L
Back fires when you let off the gas goin down the road
ok buddy on carbs will be the mixture screw turn this in to stop it backfiring turn it till it stops backfiring buddy09f7129.jpg
Oct 14, 2009 | 1992 Honda VT 1100 C Shadow
Broken choke control on snowblower
hi jared
the chokeis connect to the carb.it opens and close the trottle.try to locate where to connect the cable to opperate the trottle
bye
Jul 02, 2009 | Honda Garden
Honda Carburetor for HS520 Snowblower Logo
223 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
