Question about Motovox MVS10 43cc 2 Hp 2-Stroke Gas-Powered Stand-Up Scooter
I have a motovox mvs10 43cc 2hp gas powered scooter and was wondering if there is suppose to be plastic like components in fuel tank and what are reasons that could cause it not to start.
I have recently replaced the pull starter and added fresh mixed fuel.
    Habit-Forming:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 103 Answers
Often the is a fuel filter in the tank at the end of the fuel line, if it has deteriorted then yes it could stop it from starting due to a clog in the carb. If ou have good spark then sprat a few puffs of starter fluid into air intake or on the air cleaner ( which should be clean ) . if it starts for a second or two then it's most likely your carb.
Posted on Jan 22, 2015
My 50cc scooter won't go over 30mph
Hi, Bob and the usual suspects are:
1. Idle speed improperly adjusted.
2. Inlet system air leak.
3. Damaged or restricted fuel tank venting system.
4. Dirty or damaged air cleaner element.
5. The accelerator pump is inoperative.
6. Vacuum piston assembly malfunction.
7. Enrichener valve is not seated or leaking.
8. Restricted fuel supply tract.
9. Plugged bowl vent.
10. Loose or plugged fuel and air jets or passages.
11. Improper float level.
12. Worn or damaged needle or needle jet.
13. Loose or plugged main jets or passages.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Help Ruck won go above 30mph Thanks
Advice please 49cc won go over 20 mph
gy6 50cc to 100cc bbk upgrade still wont go over 30mph It Is The Ride
My scooter won reach top speed anymore scooters
SCOOTER WONT GO OVER 20MPH HELP
Mar 28, 2017 | GAS Motorcycles
43cc motovox will start and run ok for a couple of mins. then loses power and dies . Checked compression hot and cold OK , new carb and spark plug didn't help.
when it stops immediately check for spark if no spark when warm but spark when cold suspect ignition coil or related component
Oct 11, 2013 | Motovox MVS10 43cc 2 Hp 2-Stroke...
Yamaha bee wee won't start
Hi, Warren and the usual suspects are:
1. Fuel tank empty.
2. The fuel tank has old dead gas.
3. Fuel tank bottom contaminated with ethanol sludge, dirt, water, rust, etc.
4. Fuel supply valve/petcock turned off.
5. Fouled spark plugs.
6. Engine flooded as a result of overuse of the enrichner.
7. Vacuum hose to the fuel supply valve/petcock disconnected, broken, cracked, or pinched.
8. Fuel valve/petcock or filter clogged.
9. Fuel line to carburetor or throttle body pinched, kinked or blocked.
10. Carburetor float stuck.
11. Fuel injectors clogged.
12. A severely discharged or damaged battery, you need 12.5 volts or better and be able to pass a load test if necessary.
13. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
14. Loose or corroded wire connection at the coil or plug between ignition sensor and ECM module.
15. Spark plug cables in bad condition and shorting check for spark leakage in the dark, cable connections loose, or connected to the wrong cylinders.
16. Ignition timing incorrect due to a faulty ignition coil, ignition module or MAP, CMP, CKP, O2, TPS, ETP, IAC sensors.
17. Faulty neutral, clutch lever, or kickstand safety switch.
18. Faulty fuel pump or fuse or relay.
19. A stuck bent or burnt valve.
20. Tilt sensor needs a reset.
21. Security system not disarming alarm needs a reset.
22. Check for engine trouble codes.
ScooterCommunity
Scooter Troubleshooting Scooter won start All about Scooters
BWS Manual Scooter
OEM parts for Yamaha
YAMAHA BWS YW100E Owner Manual
Dec 31, 2011 | 2007 Yamaha yW 100 Beewee 100
2005 Honda Metropolitan stalls with throttle
Hi, Snoopyfan6 and the usual suspects are:
1. Idle port, transfer ports, slow air jet clogged.
2. Idle adjusting screw set too low.
3. Air fuel mixture adjustment too lean.
4. Pilot/slow fuel jet clogged.
5. Faulty accelerator pump.
6. Float level too low.
7. Float bowl contaminated old fuel, water, dirt, rust, etc.
8. Carburetor bowl vent line clogged/blocked/pinched.
9. Fuel line to carburetor kinked or pinched.
10. Fuel filter clogged.
11. Intake manifold leak.
12. The gas cap is not venting properly or fuel tank venting system blocked.
13. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
14. Needle and seat stuck closed in the float bowl.
15. Multi carburetors not in sync.
16. Faulty fuel pump.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
urbanscootin com Honda Metropolitan Scooter Forum View topic 2006 metro...
2005 Honda Metropolitan Scooter Rough Start and No Power
Honda CH80 Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda CHF50 2007 Metropolitan Owner Manual
May 08, 2011 | 2005 Honda Metropolitan Base
I need a new high pressure line that goesfrom the compresser to the tank where do i go`?
What you are looking for is called an unloader tube. I have used cooper water line for a refrigerator ice maker to replace the plastic. Its a little hard to work with because it is not as flexable as the plastic stuff, but it works the same and is not as likely to were out as fast. You can get the cooper line from any hardware store.
Mar 04, 2011 | Clarke Power Products Inc AC2001 2HP 4...
The Craftsman Sim-Pul string trimmer starts and runs for one sec.
The larger line is the fuel return line from the purge bulb and should have the nylon connector (funnel thing) on it holding it in place inside the tank so the line won't pull out.The smaller diameter fuel tank line goes from the tank to the lower pipe fitting on the carburetor (fuel intake line). This line has a weighted fuel filter inside the tank on it.
New fuel lines are recommended every so often as the ethanol added to our gas nowadays wreaks havoc on the lines and carburetor as well. Get new lines...cut them long....feed them thru holes in fuel tank...grab with tweezers or needle-nose pliars....put on either the fuel filter or the nylon retaining nipple and pull the one with nipple down to bottom of tank...one with fuel filter can stay long to help draw fuel in the tank (yes, it moves around and is supposed to).
Jun 06, 2010 | Craftsman Convertible 25cc. Gas Line...
Fuel Starvation on 2006 200cc Vespa. Toward end
It's quite easy to get the tank out.
Remove the 4 bolts (2 front and 3 back) on top of the tank under the seat. You can lift the tank out.
replacing the fuel tap is a bit harder as you need to loosen a nut inside the tank, then pull the tap out.
Mar 16, 2009 | Peg Perego Vespa Scooter
50cc Sunl gas scooter
You may need to adjust the fuel/air ratio. There is a small screw under the pull starter facing horizontally (its behind the plastic air filter cover, but accessable) adjust either clockwise or counter clockwise in small increments and give it gas and see if it dies or boggs down. Also check that spark plug is clean and not fouled, and air filter is clean and olied.
Jul 06, 2008 | Transport Schwinn Rechargeable Portable ...
Motovox MVS10 43cc 2 Hp 2-Stroke Gas-Powered Stand-Up Scooter Logo
125 people viewed this question
Top Motovox Garden Experts
Dennis Key
Dennis Key
john h
Are you a Motovox Garden Expert? Answer questions, earn points and help others
