Question about Hotpoint Washing Machines
Display flashes f03....anyone know anything...?
    New Friend:
  • 15 Answers
FO3 is a Temperature sensing fault
the washing machine not heating on wash or dry settings.
Posted on Nov 25, 2014
Whirlpool duet front load washer code F03 & E01
I have the same problem and my washer machine is new
Oct 09, 2012 | Whirlpool Washing Machines
F03 DISPLAY ON MY NV-SD300 PANASONIC
go to panasonic.com/vcr and give them the model/serial # and ask what the F03 error code means and they can give you a solution for the problem.
Jerry
Aug 27, 2012 | Panasonic Televison & Video
Display reads code F03 on Whirlpool oven. Can I
Hi
Thanks for using FixYa. F3 error means Open oven temperature sensor or thermal fuse. You’ll need to replace oven temperature sensor or thermal fuse to resolve the issue.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jan 15, 2010 | Whirlpool RBD305PD Electric Double Oven
Hotpoint Ultima automatic washing machine, half way through wash cycle the display flashes F 03. The machine is less than 2 years old.
Error code F03 indicates wash thermistor open/short circuit.
Check all connections on thermistor and associated leads.
Hope thisn helps.
Nov 27, 2009 | Washing Machines
VCR keeps showing "F03" and doens't do anything
Your vcr seems to use the K Mech. F03 Means that the mechanism locks when unloading.
The cause of which might be the loading motor or drive, timing and most likely the mode switch.
Jun 02, 2009 | Panasonic Televison & Video
Wt741
not sure if this is repairable but wonderedif anyone else has had the same problem,my wf860 keeps flashing f-03.
Oct 18, 2008 | Hotpoint Ultima WF860 Front Load Washer
Kenmore f03 error message
check motor if noisy or hard to turn its motor, also check concetions to&from ccu board and mcu board . "less soap plz"
Oct 17, 2008 | Kenmore Elite 45986 Front Load Washer
Fault code F03
No drum rotation signal. A shop visit is required. Sorry..accordianman
Apr 23, 2008 | Televison & Video
Indesit WIE 147 - Display 'F-03' fault
Indesit washing machine error code 3 (F03) On certain Indesit washing machines, if the on off light is flashing 3 times, with a slight pause, followed by flashing a further 3 times, or if it is didplaying F03 you have an error code that is explained as follows -
NTC fault - check Thermistor and module connections.
The NTC is the thermistor, which is a modern-day thermostat. It’s inserted into a tube in the heating element and is filled with heat sensitive crystals that change their electrical resistance according to their temperature. By knowing what electrical resistance the crystals have at given temperatures they can tell the water temperature.
With this fault the NTC is either faulty, or there’s a dodgy connection to or from it or there’s a connection problem where it connects to the main PCB.
It’s not something you can easily fault find yourself unfortunately, apart from if there was an obvious broken wire.
Feb 10, 2008 | Indesit W 123 Front Load Washer
Whirlpool oven fault f03 shown
f03 error is a sensor error.you could have taken an ohm reading on the thermistor to see if it was bad.if you replaces the t-mistor then the only other component responsible is the board.make sure all the connections on the board are clean and tight before you replace it.
Sep 28, 2007 | Ovens
Washing Machines Logo
79 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
