Question about Dynasty DGRSC 36-6 Gas Kitchen Range
I have a Dynasty oven DG 36 and the thermostat #70001034 is broken. I think it's a whirlpool part. That on't mae the part anymore and I as wondering if I could use another thermostat?
Thermostat
    Habit-Forming:
    New Friend:
  • 155 Answers
Usually no. Thermostats are custom-wired and need to send signals to control panels, but also to gas and electric elements. Here's the parts site: http://www.dynastystoves.com/search-dynasty-parts.php?txtSearch=thermostat&submit.x=0&submit.y=0&submit=Search+Parts
Posted on Nov 25, 2014
Oven takes a long time to heat
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Mar 24, 2011 | Dynasty DGRSC 36-6 Gas Kitchen Range
When our oven is heating up especially and
I'll check the oven bottom pan first, the bottom of the bottom pan ( flame spreader ) must broken off, check the welded area it must cracked. You can either reweld it back on or buy a new pan. Dynasty / Jade ph # 800-884-5233
Nov 30, 2009 | Dynasty DGRSC 36-4CB Gas Kitchen Range
Dynasty oven fails to get enough gas to light.
I think you are talking about the oven safety valve or thermal valve. before you change you oven safety valve, I would check the Amperage on the oven ignitor first, install AMP meter on one of the ignitor wire, it should draw above 3AMPs, if not then you have problem with the oven ignitor and not the safety valve. we hardly change the safety valve, I'll try to change the ignitor first. Have fun.
Mar 28, 2009 | Dynasty DGRSC 30 Gas Kitchen Range
Need instruction book
Jade / Dynasty ph# 800-884-5233, most cases the big BANG noise is coming from the broken oven bottom pan, small BANG is normal, if you know how to remove the bottom them pull it out and inspect it, part of the V shape flame spreader may come off from bottom pan, you can have the welder weld it back on for you or order new bottom pan thru Dynasty. I'm not sure what do you mean by gas shut off. (turn off oven? turn off burners?)
Mar 22, 2009 | Dynasty DGRSC 36-4G Gas Kitchen Range
Oven has stopped working
Bad oven ignitor, to check it, turn on the oven, check Voltage on 2 ignitor wires, it should have approx. 110v, if yes, change the oven ignitor, if not then check oven safety valve of oven thermostat, but 90% is the oven thermostat. also make sure the oven tube is not corroded at the ignitor area, if so, change the oven at the same time. Have fun.
Jan 20, 2009 | Dynasty DGRSC 36-4CB Gas Kitchen Range
Gas leaks into oven when i turn on the broiler
You have what we called delay ignition. may be the broiler ignitor too far away from broiler, partially clogged broiler orifice or bad ignitor, I"ll check the Amperage on the ignitor, it should draw above 3 AMPs, if not, then I'll change the ignitor first then check the orifice. Have fun.
Dec 04, 2008 | Dynasty DGRSC 36-4CB Gas Kitchen Range
Dynasty range, oven does not heat up enough
30 inch oven has only one oven tube, 36 inch oven has 2 burners in it, most comment is the oven ignitor is out. If you have 2 burners, I'll change both oven ignitor at the same time, because they worked together. also check the oven tube, if it is corroded at the ignitor area, change the burners. Have fun.
Mar 22, 2008 | Dynasty DGRSC 30 Gas Kitchen Range
Oven Blows Igniters
sounds like you have a short somewhere. you may need an expert.
Feb 02, 2007 | Dynasty DGRSC 48-4GCB Gas Kitchen Range
Dynasty DGRSC 36-6 Gas Kitchen Range Logo
125 people viewed this question
Top Dynasty Kitchen Ranges Experts
Ismael Rodriguez...
Sal DeAngelo
Jaime Hernandez
Are you a Dynasty Kitchen Range Expert? Answer questions, earn points and help others
