Question about Home
How do i stop water coming from bypass hose on aquatronic 1
  • 3 Answers
I assume this is a Tritton electric shower...
If the shower still works it could be because the bulb for the indicator is blown, or is not properly seated in the lens aperture on the front cover.
Those indicator bulbs tend to be on a flying wire that is easy to mis-assemble.
It will not cause any problem with the operation of the shower, but it's a pain if the light is not on.
If it's an electric shower, you typically should have an indicator on the pull cord isolating switch in the bathroom
Posted on Nov 26, 2014
  • Alan Q Nov 26, 2014
    Sorry - ignore this - I was replying to another question! I will delete if I can figure out how to do it!
I had to bypass my heater core. I snaked a hose from the input pipe around the motor and tied back in at the thermostat BYPASS HOUSING. I started with a 5/8 hose piece to a 3/4 elbow back to a 5/8 hose...
Was the heater core leaking? Have you checked your thermostat? By passing a leaking core should stop a running hot problem if that was your only leak. Does your cooling fan come on? Has the car been run extremely hot?
Oct 06, 2013 | 1993 Pontiac Grand Prix
How do i bypass the heater core
LOOK at the firewall under windshield engine side ,u will see two hoses coming out of firewall does are the heater core hoses, follow them going to the engine, once u locate where they are connected in the engine just connect does two ends with other hose same type and disconnect, remove or cut the hoses in the firewall side, this is how u bypass the heater core it will be no water going inside the core so the leak will stop
Aug 22, 2012 | 1994 Isuzu Rodeo
How do i change the water pump belt on a 2001 Cadillac Deville .
2001 Cadillac Deville 4.6L SFI DOHC 8cyl Removal & Installation procedure...
1. Before servicing the vehicle, refer to the Precautions section.
2. Drain the coolant.
3. Remove or disconnect the following:
Negative battery cable
Upper fill panel, if equipped
AIR injection control valve, if equipped
Air cleaner
Oil level indicator tube nut, if necessary
Water pump belt cover
Water pump drive belt
Lower radiator hose
Thermostat bypass hose from the coolant inlet housing
Water pump cover
4. Remove the water pump by rotating it clockwise using special Tool J 38816-1A (water pump remover/installer).
To install:
1. Install the water pump with a new O-ring, by turning it counterclockwise using the special tool, until it stops. Torque the water pump to 73 ft. lbs. (100 Nm).
Fig. To ensure proper operation, be sure to install a new O-ring (click for zoom)
2. Install or connect the following:
Water pump cover. Torque the bolts to 89 inch lbs. (10 Nm).
Lower radiator hose
Thermostat bypass hose to the coolant inlet housing
Air cleaner
3. Refill and bleed the cooling system.
4. Run the engine and check for leaks.
Hope this helps (remember to rate this comments)
Mar 10, 2011 | 2001 Cadillac DeVille
Ford escort zetec .there is a hose attached to the oil seperator pipe just under the thermostat and distributor where does this connect to .. please
Bypass Hose that goes from the water pump to the cylinder head on many "A" series engines. A common point of failure. Always keep a spare. 1 hose and 2 clamps included. Not for 1275's Bypass Hose that goes from the water pump to the cylinder head on many "A" series engines. A common point of failure. Always keep a spare. 1 hose and 2 clamps included. Longer hose for 1275cc engines.
Feb 13, 2011 | 1997 Ford Escort
What might be the source of an antifreeze leak? It appears to be coming from the engine front up and to the left of the oil filter on my V6, '95 Camry. I find the small puddle after the car has stopped,...
yes it could be a bypass hose it could be a freeze out plug going bad it may be a bad head gasket it may be a bad water pump these are a few items to check.
Jan 28, 2010 | 1995 Toyota Camry
My heater not working, i replaced thermostat and radiator hoses, had radiator flushed and rodded, and still no heat. What is wrong?
Too much blockage in heater hoses or heater core.
Bypass valve may be stuck on "bypass" .
1. Remove bypass "Tees", but don't discard.
Replace with straight-through hose fittings.
The core may start leaking under the water pressure since there is no bypass hose.
Once the heater starts working, put Tees back in place. You need bypass protection or the engine will overheat.
Sep 25, 2009 | 1996 Ford F150 Regular Cab
When water is hooked up and turned on I have water coming out the
On some pressure washers there is no bypass. If this is supposed to bypass, then the pressure bypass is faulty.
Jun 16, 2009 | 2004 Sym Husky 125
Coolant leak-'96 Buick 3.4 V-6
Sounds like what is normally called a bypass hose. It however is normally made of rubber, like the radiator/heater hoses are made of. If it runs from the water pump to the intake manifold, then a bypass hose would be it, regardless of its composition.
Sep 22, 2008 | Asetek COMING SOON WaterChill Xtreme Base...
Home Logo
63 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
