Question about Frigidaire FPHS2386L Stainless Steel Professional 22.6 Cubic Foot Side
I have a frigidaire pro FPHS2386L and the freezer is too cold. Any ideas?
We've reset the fridge and we've also unplugged it. I've adjusted the temperatures to both the fridge and freezer multiple times to no avail. Also, the items in the fridge seem to be freezing even when the temp seems high. Current temps are freezer (-9F) and fridge (+58F)
    New Friend:
  • 76 Answers
George makes a good point but I'd like to add that there is generally a fan that blows the air between the freezer into the fridge area. If there is no obstruction, the fan most likely needs to be replaced. On a few models this can be done with a little patience and a screw driver and the fan part. Check with a Sears Parts distribution store avaiable around the country for the part if the model is carried by Sears. If not, Google the fridge make and model number with Freezer Fan Replacement.
Posted on Nov 24, 2014
    Sergeant:
  • 229 Answers
Nothing in the fridge can freeze at 58 degrees. There is only one refrigeration unit, making cold in the freezer and then taking a portion and sending it to the refrig. Look to see if something is blocking the free exchange of air between the freezer and refrig. A plastic produce bag is often the culprit.
This morning, my Frigidaire FFHS2322MS refrigerator had a pond of water in front, the compressor was clearly off and the lights inside were on. No error code of the displays, they were just bla
Have a technician test the start capacitor on the compressor. When they go bad the motor will draw excessive current which trips the thermal overload switch on the compressor. It usually resets itself once the compressor case has cooled down.
Nov 15, 2015 | Frigidaire FFHS2322MS 22.6 cu. ft. Side by...
Fresh Air Maachine by Ecoquest
I've read from some other posts on here that Ecoquest is good about returning the items and replacing them.
Jul 12, 2008 | Ecoquest Fresh Air Air Purifier
Why does clean stay on
it has a reset function hold down power 5 sec otherwize check to see if there is any dark spots on the bottom before reinserting. 1st make sure its unplugged then 2nd there should be a copper set up as if putting a 9 volt battery into a fire alarm. there should be two side by side the darkening is where either cleaner was left still dripping or a dust partical probably from the paper towel. caused a static charge. use a Q tip to clean it . and always make sure it is dry if u hear a static sound unplug it is still wet.
Apr 26, 2014 | Ionic Pro TURBO Air Purifier
I have 4 GS6000 two of them are printing 1/8 or 1/4 bigger than the size shows in PhotoShop. Does anyone have any idea why?
First make sure there really is no invisible spacing around the images that are loaded to ONYX, Colorburst, whichever you use.
Is the media you are printing being fed to a take-up-reel, and are you using a tension bar? These all are likely causes. This problem is printer side I'm positive. I have 2 Epson GS6000 printers myself, and this happens often where after printing for a few days the sizes might start increasing.
You may need to go to the printer settings:
PAPER SETUP - PAPER FEED ADJUST - LINE FEED ADJUST
*It will then print some measuring lines that in my case are always close to 19 1/2 inches.
*You will also see on the display a option to adjust numbers
*If the sizes on both marks aren't exact 19 1/2 inches each, you need to add or subtract that amount, and then convert it to millimeters. This is the number you need to enter into the printer.
Press Enter on the printer to submit.
The next test print you do should be exact size you need.
Nov 14, 2012 | Epson Stylus Pro GS6000 Printer
My Turbo Air Purifier shuts off on its own after about 1 minute when it's on high and about 10 minutes when it's on low. The blades are spot free and I have pulled the fiber cleaning rod up and down...
Hi jerry bauer,
I work for the Ionic Pro company. Please call customer service at 800-875-8577 and they will be happy to assist you. Thank you, Mary
Nov 28, 2010 | Ionic Pro TURBO Air Purifier
Just cleaned - it is dry... but now it is noisey
i had a noisy screechy electrically crackley ionic pro , i just unplugged her ,opened her up and ,pulled out the three bladed cartridge , you can now see the three metal tabs that make contact with the three bars .. carefully bend these out so they have more spring tension applied to the three bars , what was happening was the electrical connection was to weak , the added tension[sping pressure ] stops the noise cold , its a miracle
Aug 18, 2010 | Ionic Pro TURBO Air Purifier
I placed the filters back in , but the clean red light is still on. this is an ionic pro compact cleaner
Try unplugging it, for a few minutes and wait then plug it in again and see if it resets.
Otherwise you need to reset it.
Most appliances that displays warnings have to be reset after it is corrected.
even your trusty automobile check engine light.
good luck.
Jan 30, 2010 | Sharper Image Ionic Breeze 3.0 Air...
Water drips down from Freezer. The water is coming
Since you said the water supply is shut off, the likely culprit is a clogged drain tube that connects the defrost tray to the water collection pan for evaporation at the bottom of the fridge.
The source of the clog is usually either mold growth or more likely, ice build up. Regardless of which, if you access the defrost heater in the freezer section, you can thaw ice that has collected in the tray and if needed, use a turkey baster to direct a hot stream of water at the point the hose attaches to the tray and treat the hose for mold, below.
Once cleared of ice, mix a small amount (5 or 6 oz) of water and 1/2 to 1 ounce of bleach and direct down the tube to kill any mold / growth. Be careful not to use to much or overflow, as clean up will be difficult due to the bleach mixture.
The next thing to do (if icing up) is to determine why. A careful check of the defrost circuit should be done. Otherwise, you'll be doing this over - and it may start to affect the temperatures in the frozen and fresh food sections of the fridge.
I hope this helps!
Nov 05, 2009 | Air Purifiers
Red...cleaninh light..
ame problem. I returned it to the store and they gave me a new one. So Far so good. My little ionic pro now keeps shutting off by itself. Have no idea why.
Jun 07, 2008 | Ionic Pro CA500 Air Purifier
Frigidaire FPHS2386L Stainless Steel Professional 22.6 Cubic Foot Side Logo
61 people viewed this question
Top Frigidaire Air Purifiers Experts
Michael Youngman
Michael Youngman
Are you a Frigidaire Air Purifier Expert? Answer questions, earn points and help others
