Can we convert lpg heaters to tg gas? - Heating & Cooling
  • 148 Answers
Yes you can
Posted on Nov 23, 2014
5 Suggested Answers
steve_lima
  • 181 Answers
SOURCE: I have 5 dayton heaters the model number is 3E371, they were made
the proble with converting them is it's not just the orffice.you need to take out the fuel valves.replace the feed line to the orffice,you need to get the correct regulators that attaches to the lpg tank.cost isn't worth doing the change over
Posted on Mar 17, 2009
  • 3315 Answers
SOURCE: Just need to no what is required to convert a
hi change the burner injector and the pilot and the reg or the spring inside , you should be able to buy a kit for this.
Posted on May 07, 2010
  • 11 Answers
SOURCE: want to convert heater from natual gas to lpg are
Dont know if you can get orvices for that heater but almost all gas appliances can be converted for nat to lp and lp to nat,they made a spud kit which is a blank orvice that you drill out your nat gas orvice to I think a 20 drill side and install the spud in and redrill to size usally a nat-gas orvice is around 8 to 10 sizes larger then a lp.The big thing is the gas valve and if it has a built in regulator or not,some valves can be conferted to open up the regulator pressure by the spring or a block off kit and others are fixed and cant be changed,have to replace valve.most nat-gas are at 3" to7" and lp is at 10".Hope this helps you
Posted on Jul 11, 2010
  • 120 Answers
SOURCE: Rinnai inbuilt lpg gas fireplace IB35ETR wont
You don't mention any error codes displayed. If this is the case I would start with a new main PCB. It should try and light for approx. 10 seconds and then go to lockout with an error code 11 if it was a gas supply issue. This is all controlled by the PCB hence my opinion on a PCB fault.
Posted on Sep 16, 2010
Testimonial: "Thanks for your input. Winter is coming and I will have a look at the heater this weekend. Good, clear advice. Thanks again."
Need to convert Paloma gas heater from natural gas to lpg in qld.
You can't!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Among other things besides having to reprogram modulation, you'd also need to re-jet it and that's not possible in the field. NG and LPG jets are not the same due to vastly different operating pressures.
Some brands can be field converted but not Paloma/Rheem/Richmond/Rudd Tankless units!
May 18, 2014 | Water Heaters
Hi, I have Osaka Gas Heater model 43-540.
A natural gas heater can only burn natural and vice versa unless there are changes such as orifice and regulator. They can easily be converted to use either fuel, but you have to know what fuel supply you have, and what the appliance is set up for. Since you've already tried LPG, if it turns out the appliance is natural gas, then replace the spud (burner nozzle) before trying to operate it again. LPG cannot pass through the small nozzle hole in a natural gas appliance.
Nov 25, 2013 | Heating & Cooling
Lpg heater conversion to natural gas
You will need make, model, serial number and name of heater to obtain your kit.
Try National energy the sell spares and they are on line , The how well that is a Gas Fitters job.
Mar 03, 2012 | Heating & Cooling
Have a NG unit need to convert to LP gas. wath can i do.????
Unfortunately, there is absolutely nothing you can safely do to convert it from Natural Gas to LPG.
Each unit is manufacutered and tested for the specific gas type. Attempting to change it, puts all the liability on you, if something should go wrong. There are some on this site that will tell you all you have to do, is change the pilot orifice. That's fine for a Vented heating appliance, but not a Vent-free Heater like yours. In your case, you'd need a new control valve assembly, pilot assembly, burner, etc. That alone is about the cost of a new LPG Vent-free Heater. Besides, DESA Interantional has been out of business for 3 or 4 years now. So, parts would be an issue.
Sell the heater to someone who has Natural Gas and use the proceeds toward a new LPG Vent-free Heater. Always remember and don't every forget, it's always safety first when it comes to gas appliances.
Hope this helped you and thanks for choosing FixYa.
Aug 18, 2011 | Desa International GWN30T GLOWARM® Gas...
I need my everdure gas heater to be converted from natural gas to lpg,could you help,thanks
you will need the conversion kit for the heater and an autorised gas fitter to convert if in wa perth contact me on 0439905607
Jun 10, 2011 | Heating & Cooling
Model reu2402w need jets for lpg the unit at the moment is natural gas still going but need to run it on lpg
Who is the manufacturer of your heater? Unfortunately, the model number alone doesn't help much. Also, you said you need the "jets" to convert it to LPG. Did you mean you needed the burner Orifices?
Please advise. Thanks
Mar 25, 2011 | Heating & Cooling
I brought a European LG outdoor heater to the USA and want to convert it to LPG. Where can I find the parts? It seems that all the terminations need to be metal fitting and rubber hoses with hose clamps...
Very tricky, EU gas runs on a different mbar pressure to US. It's not just changing the parts but also making sure it is legal to operate and it will need to be tested to CSA standard. In EU they have a CE certificate - this means nothing in US. For info on LPG gas see gas types, might be best to just buy a new burner head that is already converted to run on US LPG pressure.
Feb 21, 2011 | Frontgate Stainless-Steel Outdoor Patio...
329H portable heater Can this be converted to a gas bottle fitting will it be ok what is the use age and how many watts of power to run the electronics etc
You need to convert the unit if you are changing from Natural gas to LPG. This involves getting a full conversion kit for your model and changing burner , gas pressures and electronic settings.
Power draw on high remains at 22Watts. Input is almost identical for either natural or LPG gas as you would expect but running costs depends on how much you pay for your LPG. For example in Australia we use 45kg bottles of LPG, they retails at about A$110 delivered. One of these would last about 170 hours running a 329 on high.About 2 litres of LPG per hour
Aug 26, 2010 | Heating & Cooling
Can we convert Laars lite llg175N to propane from natural gas? If so how
You can convert this laars with a new burner tray, new gas valve etc..I have lots of customers who was the visa versa to you Natural to LPG and LPG to Natural..I offer an exchange service please see..
http://www.laarsman.co.uk
Miles
May 20, 2010 | Jandy Laars Lite 2 Pool Heater 125,000 Btu...
What is required to convert an LPG Rinnai 1001 to natural gas
Its complicated to convert. Get a qualified gasfitter to do it. The part number to convert LPG to Nat Gas is R1911 (at least it is here in New Zealand)
Jun 14, 2009 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Heating & Cooling Logo
37 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
