I have a Nordyne E1EH-012HA Furnace. When switched to Auto and Heat, you can hear it click but the heat never comes on. If it is switched over to On and Heat, the heat will kick on. Any info will be a
I have a Nordyne E1EH-012HA Furnace. When switched to Auto and Heat, you can hear it click but the heat never comes on. If it is switched over to On and Heat, the heat will kick on. Any info will be appreciated. Thanks
    Sergeant:
    Novelist:
  • 185 Answers
A sequencer is bad. When you give the furnace a call for heat it sends power to the sequencer which turns the fan on then a bank of heater and then another bank. So the sequencer is not turning on the fan with the heaters. When you put the fan In the ON position you bypass the sequencer and the fan comes on along with the heat strips. So you will have heat. The other way since there is no fan to keep the heating elements cooled off it trips the limit which keeps the heaters from burning out and then you don't have any heat.
Posted on Nov 27, 2014
Gigatech
  • 259 Answers
SOURCE: REPLACED 10KW FAN/HEAT SEQUENCER AND LOST TRACK OF WIRING
Could not find the E1Eh-020HA but found the E2 series
http://www.nordyne.com/Literature/707716c.pdf
http://www.nordyne.com/Literature/901a.pdf
Hope this helps. :]
Posted on Dec 13, 2007
jumptrout51
  • 3361 Answers
SOURCE: Nordyne electric furnace heats up but fan won't
If the fan runs in the ON setting then you have a bad fan relay for the heat mode.
Did you install the t-stat before or after the problem?
If after, you have a bad fan relay.
Posted on Feb 21, 2009
meBNme
  • 334 Answers
SOURCE: Bad sequencer or fan relay?
does ANYTHING come on when set to heat?
Posted on Mar 06, 2009
  • 659 Answers
SOURCE: Anyone have a wireing diagram for a nordyne E1EH-015HA
Intertherm does not offer a wiring diagram for the E1 series anymore. So I have included a link to the E2 series. They are very similar and you may find this service manual helpful for whatever problem you may be having.
http://www.nordyne.com/literature/359a.pdf
Posted on Apr 11, 2009
  • 2069 Answers
SOURCE: need pictorial wiring diagram for
kindly get here the service manual with diagrams for you e2 model. hope that helps and thanks for using fixya.
Posted on Sep 11, 2011
Can i use a different blower relay
Yes. The coil voltage, number of poles must match. And if it fits a socket, the pin configuration also.
Apr 09, 2016 | Heating & Cooling
I have intertherm e1eh-015h I just wired up heat
when the thermostat is set more than 2 degrees higher than room temperature the auxiliary heat will run with the heat pump.
Oct 11, 2014 | Heating & Cooling
Need replacement part # and wiring diagram for Nordyne Intertherm E1EH O12HA sequencer
take it to a hvac supply house and they will match it up for you. The wiring diagram will be on the furnace
Oct 30, 2009 | Heating & Cooling
Apr 11, 2009 | Heating & Cooling
Feb 28, 2009 | Heating & Cooling
Nordyne electric furnace heats up but fan won't come on when set to auto. Is it a relay switch. Have installed a new thermostat.
Feb 21, 2009 | Heating & Cooling
Intertherm E1EH-015HA FURNACE no heat
Sounds like a downflow electric furnace? If so it sounds like you have 15kw worth of electric heat, you might have a defective heating sequencer, witch is what they call a dual on one plate.
Nov 26, 2007 | Heating & Cooling
Heating & Cooling Logo
49 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
