Question about Pitco Economy 35 lb Capacity 90,000 BTU Natural Gas Fryer
Do I need a preassure regulator on the outside natural gas pipe line coming into my pitco 35+c fryer
  • 3,368 Answers
I would think so. Check with the gas compan and verify the pressures. Better yet get a professional to do it for you so you do not blow the place up.
Posted on Nov 26, 2014
Instuctions on how to change a pitco fryer from nat gas to propane
Hi there!
You need to order a gas valve conversion kit (from nat to propane), propane pilot orifice and propane burner orifice,
Gas valve conversion kit consists of a replacement spring thicker than of natural gas valve spring, gas valve cap and a sticker.
Pilot orifice for propane has smaller bore than of natural.
Burner orifice for propane has also smaller bore than of natural burner orifice (one for each burner).
You will be able to find these parts on the list of Pitco Distributor when you visit http://www.pitco.com
Regards.
Jul 08, 2012 | Pitco Frialator E24 Deep Fryer
I have 2Psi inlet pressure so if I don't use regulator pilot is working but huge flam. But when I put regulator in (3
Hi there.
Your maxitrol regulator specification is correct for natural gas use, the pressusre setting may be in minimum (3"wc) that's why the fryer does not fire-up or it may also be clogged.
Check also if the spring is sitting properly on top of the plunger.
Regards.
Jun 24, 2012 | Frymaster Dean SR42G Deep Fryer
Pitco deep fryer flames coming out the fryer
Hi there.
The soot or carbon have probably build up inside the fire tubes, better check and have an authorized service technician clean them.
Make sure that the fryer is receiving the rated gas pressure and correct gas type as stated on the nameplate, this way, carbon or soot formation on fire tubes can be prevented
Regards.
Sep 12, 2011 | Pitco Frialator SG14 Deep Fryer
Drain valve leaking,do i need to replace if so getting the right valve.steve
It depends on where it is leaking. If the oil is coming out around the threads where the valve screws onto the fryer, you can remove it and put teflon tape on the threads on the fryer and then put the valve back on tightly. If it is dripping through the valve when it is closed, you need to replace the valve. The only thing you need to match up is that it has the same threads and that it is a high temperature valve. Most Pitco fryers use inch and a half pipe threads. Pipe threads are weird, inch and a half pipe actually measures 1.9 inches outside to outside of the threads. The temperature range is up to 500 degrees F. Check with your nearest restaurant supply company. They can order you a new valve if that is what you need.
Oct 08, 2010 | Pitco Frialator Kitchen Appliances -...
My pitco 35 c the flame is burning yellow and not going inside the very wall i thought it might be the regulator pressure on the fryer on the back side
Low gas pressure will produce low flame quality (yellow flame).
Check and remove any dirt or soot on burner holes, and orifice
Burner flame not going inside the fire tube could be due to soot or carbon build up inside the fire tube blocking the flame path, check the inside of the fire tube, if considerable amount of soot is seen, better have them removed.
Yellow flame will cause a lot of problem on fryers if not corrected as soon as possible.
If you have doubt on your gas regulator, better have a qualified service technician to check it.
Sep 02, 2010 | Pitco Frialator 35CS Deep Fryer
Deep fryer from a restarant to change over to propane need orfices
I am looking at buying a pitco double deep fryer. It is natural gas, is it possible and at what cost to switch it over to propane. Model: F14S-CV - Serial: G99DC09212 Thanks Derek
Jul 19, 2009 | Pitco Frialator SG14 Deep Fryer
Want to convert pitco frialator model 14 from gas to propane
I don't know of any docs. of how to convert gas types, I can tell you that Pitco / Magiktch'n does offer conversion kits. These kits do have everything you will need, in one kit! You will need to call Pitco at phone # (603) 225-6684, with a model and serial #. These kits are normaly around $94.00 US. If you should need help with how to, there is a 24 hour tech. service # number to walk you though it!
Scoota
Jan 22, 2009 | Pitco Frialator SG14 Deep Fryer
Pitco 35LBSS propane fryer
Yes it is a solstice model fryer that was made for one of the chain stores like a pizza hut wing street perhaps. It has also been converted from natural gas at some point to propane. If you have any other questions please feel free to ask.
Hope this helps Ya
Jul 02, 2008 | Pitco Frialator 35CS Deep Fryer
Deep fryers
Yes you can,you need to change the regulator,gas valve and orfices.
Jun 06, 2008 | Pitco Frialator SG14 Deep Fryer
Converting a pitco frialator from natural gas to propane
you need to change the pressure regulator,burner orfices and possibly the gas valve.goto northernparts.com and type in the model of the fryer for propane
Dec 12, 2007 | Pitco Frialator SG14 Deep Fryer
Pitco Economy 35 lb Capacity 90,000 BTU Natural Gas Fryer Logo
56 people viewed this question
Top Pitco Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Pitco Kitchen Appliances - Other Expert? Answer questions, earn points and help others
