Question about Saws
How to replace the locking pin on a dewalt dw705 type 4 miter saw
  • 288 Answers
SOURCE: I have a dewalt 706 miter saw and the blade brake
this is a replaceable part and they do wear out
Posted on Nov 27, 2009
  • 142 Answers
SOURCE: Can't change mitre angle
you need to remove the guide fence with the screws on the back. then you remove the throat plate and there is the bolt is that keeps it all together.
Just took one apart last week, not really difficult
Posted on Dec 27, 2009
  • 18 Answers
SOURCE: nee the instruction manual for the dewalt dw718 compound miter
You can grab the manual and any replacement parts or accessories that should of came with it from eReplacementParts.com - They are DeWALTs supplier for manuals, parts, accessories, and tools online.
Posted on Apr 12, 2010
  • 885 Answers
SOURCE: can i get guard for 10" miter saw
Go to www.ereplacementparts.com and search on your model to get a parts breakdown. Use TS1342L as the model number, the ZR indicates it's reconditioned. You can order parts from them or get the part numbers for the parts you need and check the internet for other vendors that may have better prices.
Posted on Feb 25, 2011
al_kupchella
  • 843 Answers
SOURCE: neeed to calibrate bevel stop
I assume you can find the adjusting screws, but here's how to measure if you have it dead-on: First, confirm repeatability as follows----. Move the saw as if you were going to cut at miter, then move it back to zero. Now cut off the end of a 6 inch (or so) board. Then move the saw again, and move it back to zero. Cut off about 3/4 inch of the same board (make sure you haven't turned the board over). The 3/4 inch piece you have cut off might not be square, but the two cut edges of the 3/4 inch piece should be exactly parallel to each other. Find a way to confirm that. A micrometer or good calipers make this easy, but you may have to improvise - the key is that your check for parallel needs to be more precise than measuring it with eyeballs and a tape measure. Repeat this a couple of times. You may find that you have to be careful about resetting the saw each time so that you can get repeatability. OK, now that you have a repeatable setting turn the board over and take another cut. Any deviation from 0 (or 90) will be doubled and the two cuts will not be parallel. Make your adjustments to the saw until you get two parallel cuts when you flip the board over. And one more thing! This method ASSUMES that the board you are cutting has parallel edges. If you have calipers this is easy to confirm.
Posted on Mar 04, 2011
My Dewalt DW705 miter saw just stopped running,instantly. Have power all the way to the brushes,power through the switch when engaged. Still won't run. Any ideas?
The motor may have failed abruptly. There could be an open thermal overload if your saw is equipped with one buried in the motor windings.
Nov 28, 2016 | Saws
Where can I order a replacement trigger switch
How to Install a Switch Kit on a DeWALT DW705 Miter Saw ...
? 12:35
https://www.youtube.com/watch?v=FJ1Wo2xufzI
May 15, 2013 - Uploaded by eReplacementParts.com
Get a replacement switch kit for your DeWALT DW705 miter saw ... kit on a DeWALT DW705 miter saw which replaces thetrigger switch (part ...
Miter Saw Parts ' Tool Parts Direct
www.toolpartsdirect.com/saw/miter-saw.html
Shop the Tool Parts Direct inventory of miter saw replacement parts. A miter saw is designed to quickly make cuts at a variety of angles. Featuring a pivoting ..
Oct 23, 2015 | Saws
How to replace arm locking pin on a dw705 Type 4 miter saw
Can't remember how much access there is at the back on that model, on some you have to take the main hinge pin out to get to it and move the top arm assembly out of the way. Not always the easiest of jobs.
Dec 09, 2012 | Dewalt DW715 Heavy Duty 12" Single -...
Dewalt DW 705 Type 1 Hard to pull down to cut material
Go to www.2helpu.com that is the dewalt site. You might have to change the link arm that moves the guard up. They get bent over time. Check other parts on the raise and lower assy for wear at the same time.
Dec 04, 2012 | Dewalt DW715 Heavy Duty 12" Single -...
How do I remove 12" blade from from dw705 miter
loosen the guard screw, UNPLUG tool first, move the guard out of the way, there is a spindle lockon the backside of the gearcase push it and slowly turn the blade until it engages and then remove the bolt, it is a left hand thread. DO NOT disassemble the guard, just loosen bolt and move out away from blade also you need to have the head in the raised position.
Oct 28, 2010 | Dewalt DW715 Heavy Duty 12" Single -...
Need to get owners / instruction manual for my Dewalt DW705 type 3 12" miter saw. Do you know where I can get one quickly?
Hello. DeWalt has 13 types of this saw on file. Here is the link to all:
http://servicenet.dewalt.com/Parts/Search?searchedNumber=DW705&searchType=1
Click on the "more details" arrow of the one that meets your needs, then click the PDF symbol in the top right of the "product information" tab.
If this helps, please rate a four-thumbs up. Thank You.
Sep 12, 2010 | Hitachi C10FCE2 10" Compound Miter Saw
MISSING INSTRUCTION MANUAL
C'mon! http://www.dewalt.com/us/service/instruction_manuals.asp?SKU=dw70&submit=Submit
Oct 09, 2009 | Saws
Loose bracket miter dewalt dw705 saw
needs model of tool to be able to help you out
Apr 19, 2008 | Dewalt DW746X 10" woodworker's table saw...
Saws Logo
69 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
