How can i fix mx 437 cannon printer when prompted error occured 5100 with paper inserted on it
    Sergeant:
    Champion:
  • 246 Answers
Please reset the printer by eject the power and data cable for a one minite
Posted on Nov 27, 2014
  • 153 Answers
SOURCE: Cannon mx 310 error 5100 Says chck printr with alarm light flashi
heres the problem from service manual: error 5100, a error occured in your encoder signal, it list 4 things in the serice manual.
carriage unit. carriage motor, logic board, timing **** film.
ok my first thing i would look at is the film that runs directly behind the print head i would think it is dirty. just turn on printer and get print head to the middle and turn off machine, gentle move print head to one side and gentle clean the film strip with a cloth with a little metho on it, move print head to other side and clean other part of ****.
i reckon that will fix your problem its a common problem they tend to get a bit of grease on the timming ****.
Canon Tech
Posted on Jun 01, 2009
pineworks
  • 4041 Answers
SOURCE: Cannon PIXMA Service Error
Hi You can Try 2 things.
Have a go
There is some foreign object blocking your cartridges carriage that disables it from moving. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there
Next try.
It may be a piece of paper or a scotch tape or a staple wire.
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 10, 2010
SOURCE: Error 5100 on my canon mx 310.
the 5100 is the carriage error and can be caused by 4 different sensors. First off the "Timing Strip" that passes through the back of the Carriage Assembly can be contaminated with ink spots and this needs to be cleaned. Open the cover and use your flashlight to examine the timing strip as much as you can see. You really don't have much access to this strip unless you remove the covers,..and doing that is considerable work. The other items that can cause this error are the sensor inside the carriage unit, the drive motor for the carriage asm, and of course the main logic card. However, 99.6% of the time it is the Timing strip which is easitly contaminated with splattered ink.
Posted on Apr 02, 2010
  • 107 Answers
SOURCE: how to reset printer after refill ink for cannon
Dear Sir,
Ignore the low ink warning, the printer should still print after about 30 seconds or hit resume on the printer.
You will get this warning every time you print. There is no way to reset those cartridges. Thanks For YOur Time
Posted on Apr 08, 2010
pineworks
  • 4041 Answers
SOURCE: I have Cannon MX 700 printer. I cannot print due
ERROR 5100 means that there is some foreign object blocking your cartridges carriage that disables it from moving. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
Next try.
Solution 1:
Solution 2:
Posted on Apr 28, 2010
Cannon MX 490 printer saying it's off line and all looks set
I am afraid you will have to provide more information to get your problem fixed, was it printing when the error occured, or did it happened after you turned it on? Did some error message came out on screen?
Apr 03, 2017 | Cannon Office Equipment & Supplies
Printer show printer error occurred 5100 meaning what
Hi Hemalatha,
This error is a "Jam" error. Look for any objects / pieces of paper that is stuck in the paper feeders (front and back). Secondly there is a timing strip that gets dirty and could also cause this error. Cleaning it could solve this problem. Hereafter, press and hold the "Clear" button for 5 seconds or more to reset the error log.
Here is a tutorial on how to fix this error:
Here is a tutorial to clean the timing strip:
FIXED Canon Printer Error 5100
Dec 28, 2014 | Canon Office Equipment & Supplies
Cannon mp282 pixma ,how to fix error code 3
The E03 code indicates (1) That the Paper Output tray is closed and you are trying to print. Open the Paper Output Tray and the printer will resume printing. (2) There is a paper jam. Remove the jam, reload the paper into the printer, then press the "Black" or "Color" button,
Dec 25, 2014 | Cannon Office Equipment & Supplies
Riso error CODE p20-437
P20-437 Paper-ejection encoder sensor status does not change within 10 milliseconds after the paper-ejection motor is activated.
This error occurs when the encoder disc either breaks or slips off the motor. The encoder disc is either a plastic or metal gear toothed disc.
Sep 23, 2013 | Office Equipment & Supplies
HI I HAVE A CANON MX 320 MULTIFUCTION MACHINE, THE INK CARTRIDGES HAVE BEEN REPLACED BUT THE SCREEN KEEPS SAYING PRINTER ERROR HAS OCCURED 5100, HAT DO I DO TO FIX
5100 error means a Carriage Home Position Error.
Just make sure you remove the plastic strip covering the print head and the contact copper of the ink cartridge before you insert it to the cartridge holder.
Other possible solutions is that the cartridge is not properly seated on the carriage or cartridge holder. Once it is not properly seated the cover of the cartridge holder usually hit when it moves.
You may also clean the contact copper of the ink cartridge using an soft cloth or cotton moistened with alcohol to clean the surface. Please avoid touching the surface by your fingers.
Jun 23, 2010 | Canon PIXMA MP170 All-In-One InkJet...
Cannon pixma mp510 ~ error code 5100 help
Error 5100 is Carriage error.Possible problems in:
- Carriage unit
- Timing **** strip film
- Logic board assembly
- Carriage motor
First, make sure there is no paper jam anywhere in the machine.. look inside, rear, where the paper tray (output) is, etc to see if you find any shreds or torn paper that may have gotten stuck and you didn't see.Look carefully in the zone of Purge unit, using flashlight in the right side on printer.If this not help your printer need service.
Nov 19, 2009 | Canon PIXMA MP510 All-In-One InkJet...
Canon Tech
May 30, 2009 | Office Equipment & Supplies
60 people viewed this question
k24674
jasbo
jasbo
