Question about Locks & Locksmithing
I have an interior lock set on door to bedroom ; locked out keys on other side. Help
  • 1,268 Answers
Use a credit card and push it in at the latch, between the door and the frame holding the door away from you, while pushing the card inward onto the latch ramp wiggle the door in and out until the card slides all the way in and pushes the latch into its receiver and door will open.
Posted on Nov 23, 2014
5 Suggested Answers
VtToolMan
  • 704 Answers
SOURCE: brought door with lock locks when u push lock
You might not be pushing the correct sequence of buttons to unlock the door. You should only have to enter in your code to unlock the door, unless there was a problem when the lock was programmed.
Here's a copy of the user manual so you can verify the codes were entered properly and that the lock is set up correctly.
http://www.smarthomeusa.com/Products/ED1460XXXX/manuals/WeiserLockPowerbolt1000-manual.pdf
Hope you find this Very Helpful and best regards!
Posted on Aug 19, 2009
  • 963 Answers
SOURCE: I have forgotten the code
Here is the "literature grid" from the KABA website, which has manuals and parts lists for the
Simplex mechanical pushbutton locks:
http://www.kaba-ilco.com/access_control/literature/literature_grid_mechanical_pushbutton_locks.
aspx?id=13
You'll need Adobe Reader installed, as these are PDF files. The manuals show installation and reprogramming instructions.
You can also research other models of locks from this page.
Posted on Mar 06, 2011
  • 963 Answers
SOURCE: My Weiser Lock won't completely turn the lock
Good news! Weiser has a lifetime warranty against mechanical defects and problems with the finish (but only a one year warranty protecting the internal electronics). Here's the link to the warranty page:
http://www.weiserlock.com/CustomerService/WarrantyInfo/Powerbolt.aspx
But before you pursue that, a few questions and comments. How does the lock function with the door open? If it functions okay, then you need to investigate the alignment between the door lock and the door jamb/strike plate. Also, these locks can be internally adjusted for installation in doors with a 2 3/8" or 2 3/4" backset. Is it off by about 3/8"? if so, check that.
Some months ago I suggested that possibility to someone else with much the same problem. He found that a plastic member had disintegrated in that area of the lock and was jamming it up.
Here's a link to the installation instructions; you'll see what I'm talking about under Item 2 Deadbolt Latch Installation (Piece B)
http://www.weiserlock.com/Support/Faq/50160000000HhmZAAS.aspx
A note about PDF files: If you cannot view the installation instructions, you need to first install Adobe Reader. You can get the free download here:
http://get.adobe.com/reader/
Good luck--and please leave feedback if this helps!
Posted on Nov 15, 2011
Interior light stays on when driving.goes off when I use key fob to lock
Interior lights will not turn off when door closed - VW Audi Forum
www.vwaudiforum.co.uk/.../36009-Interior-lights-will-not-turn-off-whe...
... locking when using key fob, only from the inside via the lock on the drivers door ...by key fob and manually turn off the interior lights but the door lights stay on.
close door light & interior lights - CarGurus
www.cargurus.com > Questions > Ford > Edge
CarGurusJul 24, 2010 - close door light & interior lights - close door light on my ford edge is lit up on the dash and the interior lights wont go off. all the doors, truck, and . ... are completly shut. what to do? help before my battery goes dead. ... charged Interior lights work Headlights are strong Key fob locks and ... Used Ford Escape".
Door Chimes, interior lights on when stopped, and power locks have ...
www.grandamgt.com > ... > Technical Q&A
Apr 28, 2011 - 13 posts - ‎5 authors
It really only happens when its totally stopped while in drive. ... Key Fob- It works, but no longer gives the horn sound to confirm its locked. ... The fact that the car doesn't honk when using the remote isn't a problem. ..... Currently my dome light stays lit when on the door position and my alarm goes off as soon ...
Help - Interior lights staying on / door locks going crazy ...
www.mazda3forums.com/...interior.../329450-help-interior-lights-stayin...
Feb 11, 2009 - It seems that my interior lights stay on while im driving. ... If you get into the car start up the car, and then close the door the lights shut off. ... the when youuse the key fob to lock the car at night the interior lights stay on as well.
Jan 27, 2016 | Cars & Trucks
The lock got flipped on the bedroom door. I am now locked out. The door knob has been removed but I cannot get the mechanism inside the door unlocked. How can I do this?
You are almost there. Take the knob containing the spindle and insert into the latch mechanism. Twist it and the lock button will pop out. Open the door. Put everything back together. NOTE: I just confirmed this using a lock mechanism in front of me as I answered this.
Nov 09, 2013 | Hardware & Accessories
2006 KIA.DOOR LOCKS; When you unlock the doors with remote, the doors immediately lock again. With the key, door unlocks and stays unlocked. however, the feature when you turn key to the right two times...
intermittant is spelled intermittent. .... Ah, locking system. ... You will find a broken wire in one of the doors that are used to set the door lock.
Probably the drivers door return wire.
Oct 26, 2013 | 1998 Honda Civic
How do i break into a locked bedroom door?
look for a small whole like screw whole twisting it around should open it did it before allot of times.
Oct 05, 2013 | Locks & Locksmithing
I locked my bedroom door with my keys in the room
Look closely at the door knob and you will see a very small hole in the middle of the door knob. Use a piece of stiff metal such as a heavy paper clip straightened out and push it into that hole. that will unlock the door to your bedroom if you have a normal bedroom door lock.
Mar 25, 2011 | Garden
The driver side door will not lock or unlock using key fab. Only the passenger and trunk will unlock. Cannot lock my car unless i manually lock my drivers side door, shut it then hit the lock on the key...
some how lever to the lock unit came off , need to open the interior panel of the driver door and put back lever to the lock unit. It should work.
Dec 14, 2010 | 2002 Toyota Celica
Mk4 Golf. Remote locking, windows and interior lights not working
Maybe fuse number 6 is blown (check lefthand side of steerning wheel where all teh fuses are located - you must open the door)
Jan 10, 2010 | 2003 Volkswagen Golf
2001 Town and Country Lock and Unlock is Going Haywire on its Own
Door Locks Go Crazy 1
Door Locks Go Crazy 2
Door Locks Go Crazy 3
Not to difficult to understand what's happening ,when you know how they work .Plus you need tool the proper tools to diagnose .
Mar 03, 2017 | 2005 Chrysler Town & Country
Keyless Entry and Remote
I have had this problem take you drivers door put your key and un-lock from the out side with key (NO) then open the door push un-lock from the inside button and then set from you remote and it should set if not push un-lock then lock and then do the un-lock with the key. Let me know if that works. what my car did was locked from the inside and I had the problem were it would not work till I un-locked from the out side plus I had to go to radio shack and change the battery from the control.
Hope good happens.
Nikki2913
Oct 22, 2008 | 1996 Ford Explorer
Locks & Locksmithing Logo
62 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Tom Chichester
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
