Question about Maytag Ovens
Where is the thermo fuse of a Maytag double oven built into the cabinet ???
During a self cleaning the oven stops working. Now it is inop.
  • Gere knutson Nov 23, 2014
    Hi Elsie , I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    Need model number as the thermo-fuse on most oven are on the back of the oven. Thanks
catriver
  • 878 Answers
SOURCE: Oven shut down during Self-cleaning
tde, sounds like your thermal fuse (TC0) opened on the back side of the oven. If this opens, it will shut the oven down. This happens alot during self cleaning on built ins. Sometimes I have to re-route the tco to a different area to prevent this from happening. Your part number is 4451442. You will have to pull the oven out far enough to remove the back paneling and replace the fuse....Catriver..post back.
Posted on Oct 25, 2006
catriver
  • 878 Answers
SOURCE: Whirlpool Double over
big dib, the TC0, ( thermal cut out) probably has opened. This is non resetable. To get at it you have to pull the oven out to a point where you can get at the back. Then you have to remove the oven back panel and there is the TCO. Part number 4450249. You can verify this by ohming out the TC0, if it shows open (no continuity) it's bad. I have done a number of these and it takes two people to repair it safely. Kill the breaker when going in there. Catriver..post back.
Posted on Dec 30, 2006
SOURCE: Maytag "Magic Chef" electric double wall oven
check the high limit swtich. You need to remove the back of unit to find it. replaced it part# is:w10175596
Posted on May 19, 2008
SOURCE: whirlpool rbd275pdb double wall oven died during self clean
The first time we used our Whirlpool oven the same thing happened - no power and yet the circuit breaker was not blown. I called Whirlpool, and they sent out a technician to check it out as it was still under warranty. He said the temperature was off (too hot) by 20F - he adjusted. He also replaced the blower. What he did not tell me was that the thermal fuse had blown, and he replaced it - this was the REAL cause for the failure. I got the impression that he did not want to let me in on the secret. He did not note on the paperwork that he replaced the thermal fuse. Last week I decided to run the oven through the self-cleaning cycle (the oven is now 8-1/2 yrs old) - I don't believe that we cleaned the oven but a couple of times since the first time that it was "repaired." I used the default 3-1/2 hour setting. Everything appeared to be fine - the oven went through the cleaning cycle with no apparent problems. The display now read "cool down" - I went to bed thinking everything was okay. I got up the next morning only to find out that the power was out. I called Whirlpool and demanded that they repair the unit again as they clearly never fixed it correctly in the first place. They offered me 15% off on a new oven - WHOOPEE! I asked to speak with the supervisor - he did not budge either. I was upset, and I told him that I would NEVER purchase a Whirlpool appliance again! I decided to tear into the oven to see if I could detect anything wrong. I pulled out the front panel - everything looked okay. I then noticed the "thermal fuse" - I did not know what it was called at the time, but it looked familiar. I checked voltage on either side of the fuse and found the voltage to be zero on the downstream side of the fuse. I pulled it out and read the information on the device: Microtemp 110C. I called a local appliance repair shop - they told me that it would cost $50 to purchase a new fuse! I told them that seemed very high. I ended up stopping at Radio Shack. They have thermal fuses in various temperature and voltage ranges. I got a 144C 10A fuse and carefully soldered the connectors to it and replaced the protective plastic sleeve. I actually bypassed the thermal fuse in order to use the oven before I found the replacement fuse. While it is a good idea to have a protection device for the slim chance that an oven may malfunction by overheating, it is not a necessity for the functionality of the oven. Hopefully, the thermal fuse will not fail during my next attempt to self-clean the oven. I do have a concern about the 10 amp rating, but I'm sure that it will work fine.
Posted on Apr 15, 2009
sclarke7
  • 222 Answers
SOURCE: Whirlpool built-in double oven model# RBD305PDB12
the humming sound is coming from the "squirrel cage" fan in the back of the unit, there may be some resonance vibration from the fan this issue should be addressed by a qualified service tech, the whole wall oven needs to be pulled out, i would have him check the fan.
Posted on Aug 27, 2009
My friend used her self clean feature on her electric oven and now the digital display is out and the oven won't work. Any ideas?
HI,
This issue is the oven got too hot during self clean. There is a thermo-fuse to the display on the right hand side directly to the board. But this fuse does not show up in the wiring diagram. Also you have have taken out a second thermo fuse on the backwall to the oven in which it must be removed from the cabinet to replace. I need a model number to direct you on the correct parts, and location of this parts.
Get back to me with more information..
Aug 28, 2011 | Ovens
Have a Kenmore Elite Built-In oven 790.4812. It's a double oven. Was working fine. 1 year old. Wife self-cleaned upper oven for first time. Oven does not work now. Sears Repair guessing that the oven...
It has nothing to do with the tight fit.
It has everything to do with self-cleaning on ovens.
The thermal fuse blows due to extreme temperatures.
Replace the fuse to use the oven.
Use an oven cleaner to clean the oven OR replace more fuses in the future.
Jul 25, 2011 | Ovens
How do i self clean
WASHINGTON, D.C. - The U.S. Consumer Product Safety Commission, in cooperation with the firm named below, today announced a voluntary recall of the following products. Consumers should stop using recalled products immediately unless otherwise instructed.
Name of Product: Thermador� Built-In Ovens
Units: About 37,000 (42,000 built-in ovens were previously recalled in June 2007)
Manufacturer: BSH Home Appliances Corp., of Huntington Beach, Calif.
Hazard: The ovens can have gaps in the insulation where overheating can occur and when used in the self-cleaning mode it can cause nearby cabinets to catch fire. This poses a fire hazard to consumers.
Incidents/Injuries: BSH Home Appliances has received three additional reports of incidents, including two that resulted in fires that damaged surrounding cabinets. No injuries have been reported.
Description: The recall involves Thermador Brand built-in double ovens with model numbers C272B, C302B, SEC272,C301U, SEC302, SECD272 and SECD302 and serial numbers between FD8403 through FD8701. Model and serial numbers are located on the underside of the control panel.
Sold at: Appliance and specialty stores nationwide from June 2004 through July 2007 for between $3,000 and $4,400.
Manufactured in: United States
Remedy: Consumers should immediately stop using the oven�s self-cleaning mode and contact the firm to schedule an inspection and free repair, if necessary.
Consumer Contact: For additional information, contact Thermador at (800) 701-5230 24 hours/day, 7 days/week, or visit the firm�s Web site at www.thermador.com
Dec 05, 2010 | Thermador C301U Electric Single Oven
After usung the self cleaning function the oven no longer works
Check for correct voltage at plug, in the mean time the oven will be disconnected from any power, see if it resets with no power for 10 minutes
Nov 13, 2008 | Whirlpool RBD305PD Electric Double Oven
Dacor ECS230 Epicure Electric Double Oven
You probably tripped a safety thermostat in the back of each oven. If you turn off the breaker and find a way to pull the units out you could probably remove the rear panel and reset the thermostat by pushing in a button on the back of the open thermo. Some thermo's aren't resettable though so you'd have to buy a replacement.
Sep 22, 2008 | Dacor ECS230 Epicure Electric Double Oven
Self-Clean gets too hot on JTP56 double-oven
Your husband is correct, kind of. You should not try self clean again until you get the oven repaired. You have a temp sensor going out. I doubt that the oven actually got too hot, most likely the resistor in the sensor is failing as it heats up and giving a false temp reading.Since the lower oven was operating at the time, it is probably the sensor in the lower oven. Don't use it for baking until you get it repaired. It will go out completely and shut down both ovens. You should be able to get a new sensor for around $30 and they are not hard to replace.
The oven won't set your house on fire during clean mode if the cabinets were built with the correct air space and dimensions, but they do get very hot, about 800 degrees F. Most ovens give no trouble during the clean cycle, but if there is any weak components in the electronics system it will show up then. It will give you less trouble over time if you don't use the self clean mode and just manually clean it.
Jan 18, 2008 | GE Profile JTP56 Electric Double Oven
Cleaned oven now won't heat
Probably what happened is during cleaning cycle the oven overheated the tco (thermo cut off). This is a thermo-fuse that is located behind the control board. It will need to be replaced.
Aug 25, 2007 | Whirlpool RBS245PDS Electric Single Oven
Dec 29, 2006 | Whirlpool RBD245PD Electric Double Oven
Oct 24, 2006 | Whirlpool RBD275PDS Electric Double Oven
Ovens Logo
Top Maytag Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Mack Baxter
Are you a Maytag Oven Expert? Answer questions, earn points and help others
