Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
<!-- from fixya rte -->My door lock light keeps flashing - Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
    Top Expert:
  • Frigidaire Master
  • 21,338 Answers
Check the door allignment.
Posted on Nov 23, 2014
I have a ge profile oven model starts pt 916 when i broil food the "locked" light flashes, i usually keep the oven door open so i can watch the food after about 5 min the locked light goes off
The only thing spring to mind Mary is that you somehow selected a cleaning cycle which superheats the oven and turns burnt on fat and grease to charcoal. The cleaning cycle never finished and the stove remembers it. The light is flashing to remind you. When the cleaning cycle is in progress, the door locks until it is finished.
Either remove the wall power plug or flip the breaker and leave it overnight. It _should_ erase it from the memory. Or you have to compete the cleaning cycle as per the instruction book.
Sep 05, 2016 | GE Ovens
How do you keep the door locked so you can use t self cleaning feature
Good Morning Friend,
I understand you want to know how to keep the door locked on your Frigidaire oven, model# FEB24S2AS, so you can use the self-clean feature. The "Door Locked" light will flash until the door locks when the self-clean cycle is in use. It glows constantly after the door locks. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 28, 2014 | Frigidaire FEB24S2AS / FEB24S2AB Electric...
After using the self-cleaning feature, "Door Locked" keeps flashing on the the screen. The door will open but this Door Locked keeps flashing and I can't use the oven
Cycling the power off and then on again will sometimes reset it...often you will have to call the customer service number to get the steps to take to unlock that...
Also check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Apr 22, 2010 | GE Profile JTP56 Electric Double Oven
F90 code flashing and i cant reset it
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question@#$%
Jul 07, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Lock light on frigdaire self cleaning oven
OK, this is not a good situation here. your Electronic Oven Control board is damaged. the logic sectors are faulty. The F-1 represents a major EOC failuer and, you will need to replace your EOC(clock) asap, if possible.
Jun 07, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
DOOR Locked Flashing
check the interlock switch, can be some object has stuck to it...
Sep 06, 2008 | GE Profile JTP18 Electric Single Oven
Ge monogram single convection wall oven
There is usually a micro switch that is activated when the lock lever is in place - very likely this switch is still activated or has failed closed (defective) .
Aug 26, 2008 | GE Monogram ZET3058SHSS Stainless Steel...
Was able to get the lock to go in on the door and then turned off the power which reset the system.
Mar 31, 2008 | GE Profile JTP56 Electric Double Oven
Ge oven problem
door lock is not work check wires motor and switchs.. you may have to replace the door lock
Dec 11, 2007 | Amana AOCS3040 Electric Single Oven
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
