Monitor heater keeps shutting off why?
Monitor heater keeps shutting off,is it the fan or do I need to get it serviced?
  • 22 Answers
78 olds uses a push and pull water controle on the heater hose. Make sure that the cable is working the water valve on.the heater hose. If it is working the valve back and forth then its most likley your heater core stopped up.. take both heater hoses off at the motor. Take your garden hose and flush water threw heater core. USE LOW PRESSURE.. DO NOT TURN YOUR GARDEN HOSE.ON FULL BLAST.. IT COULD MAKE THE HEATER CORE TO START LEAKING IN SIDE YOUR CAR. With.low pressure run water in each.heater hose.till water coming out looks clean. If this dont get you heat. Then check.your thermastat it may be stuck open.
Posted on Nov 23, 2014
    New Friend:
    Problem Solver:
  • 5 Answers
I pretty sure you don't need to get it serviced. I think it turns of because it gets to hot. My computer heater does the same. I hope this helps. (If your heater brakes please don't blame me)
  • Stoneman23
    Stoneman23 Nov 23, 2014
    I'm pretty sure he's talking about a computer heater
Jandy lt250 heater has air flow message
make sure 24 volts ac on both sides of pressure switch if not replace pressure switch or copper tube is plugged if only 10 or so volts will not keep gas valve open
Nov 21, 2012 | Jandy Laars Lt 400,000 Btu Heater
Furnace fires up and heats to desired heat setting and burner shuts down , but the main blower continues to run on.
its the fan control AFC not shutting off , it comes on at temp rise say 150f drops back to 130f with fan on , burner shuts off fan runs untill temp falls to 100f the fan shuts off in this case it keeps running
Nov 13, 2010 | Dayton Gas Furnace Heater
FAN KEEPS RUNNING
Did you just install this or has it been running for a while.
Usually if the fan keeps running and if you just installed it,the temperature settings need to be adjusted, but first make sure the fan switch button (should be the white button) is pulled out completely.
Set your Fan on setting at about 120°F and fan off at about 90°F.
If you get your fan settings to close together when the blower starts it may cycle on and off a few times before finally staying on.
If this has been in service for a while then it's probably bad and needs replaced.
To check it out first make sure the fan switch button is pulled completely out then turn the fan on setting up and see if it will shut off,if it doesn't then it's bad and needs replaced.
Jan 10, 2010 | Honeywell L4064B2236 Fan/Limit Control...
MPI 41 Keresene Monitor Heater LIft Pump over-primed?
I recently relocated monitor heater from living room to dining room and ran new line to heater. I have pressed the priming button located on right side and turn unit on, but all that happens is it will click on run for a cycle and burner never ignites and then turns itself off and burner indicator lights continue to blink on and off, I dont think it is getting proper fuel to unit. What do I need to do?
Jan 05, 2010 | Heating & Cooling
Keeps shutting off and the fan won't come on at all
Thed fan should come on soon after plugging in as long as the heater is cold. The heater then shuts off after sensing no flame. Either the wiring is bad, the fan motor is bad, of the top has been bent down so it is hitting the fan. Remove the top, make sure the fan turns freely and check power to the fan motor. The fan motor also turns the air pump that **** the ful out of the tank. Ck this and let me know if you need help.
Nov 28, 2009 | All-Pro Kerosene Garage Shop Heaters - All...
The heater fan keeps gpoing
The fan will not shut off immediately. It has a cool down period of up to 5 minutes. Or, the fan limit switch needs adjusting.
Oct 27, 2009 | Heating & Cooling
Flame wont stay lit
Sounds like a flame sensor problem. The board is not getting the proper signal from the flame sensor so it thinks the burner did not light and shuts the gas supply off. It keeps the blower operating to ensure that no gas is accumulated in the burner area. I suggest you contact a local mechanical contractor to service your heater.
Jun 23, 2009 | Pentair Minimax NT Heater
Heater starts and then stops.
I will keep you posted. I have aquired all the service manuals and I am in the process of taking the heater apart. It is not the motherboard.
Mar 09, 2009 | Pentair MINIMAX NT TSI IGNITER
Pentair Heater shuts off prematurely when warming spa
check gas pressure could be running out or overheating
Mar 06, 2009 | Pentair MINIMAX NT TSI IGNITER
Heating & Cooling Logo
453 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
