Question about Home Security
I have a SL91B twin security light and I don't know how to connect it to the plug
2005 flstn won't start engine light comes on while cranking
Hi Anonymous, and the usual suspects are:
1. Fuel tank empty
2. Fuel supply valve turned off.
3. Fouled spark plugs.
4. Engine flooded with gasoline as a result of over use of enrichner.
5. Fuel valve or filter clogged.
6. Vacuum hose to automatic fuel supply valve disconnected, leaking, or pinched.
7. Discharged battery, loose or broken battery connections.
8. Loose wire connection at coil, battery or plug between ignition sensor and module.
9. Spark plug cables in bad condition and shorting, spark plug cable connections loose,
or cables connected to wrong cylinders.
10. Ignition timing incorrect due to faulty ignition coil, ignition module, or sensors " Manifold Absolute Pressure" "Camshaft Position Sensor" "Crank Position Sensor" "Brake Apply Sensor
11. Engine lubricant to heavy ( winter operation )
12. Sticking or damaged valves or push rod wrong length.
13. Primary cam sproket spline sheared or missing spacer.
14. Security alarm system not disarming.
For a primary suspect please visit the website below: Good luck
Big Twin Carb EFI DTC Intructions codes Harley Davidson Forums Harley...
Dec 11, 2013 | Harley Davidson Motorcycles
Will not start. no lights on power commander box
Hi Jamie, and the usual suspects are:
1. Fuel tank empty
Dec 07, 2013 | Harley Davidson Motorcycles
When I plug my video card into computer I get no video NVidia N470GTX
  1. Make sure the monitor is set to ther correct input
  2. Make sure the motherboard is set to PCIe output not onbaord
  3. Make sure The video card has the power connecters connected securely.
Sep 25, 2013 | MSI N470GTX TWIN FROZR II nVidia GeForce...
Bike wont start - oil light on
Hi Anonymous, when checking for spark the CKP needs to measure the compression bump in order to send the correct signal to the ICM/ECM so always check for spark with either a third plug grounded or lift the end of the plug boot 1/2 " off one of spark plugs that are in the head. and the usual suspects are:
1. Fuel tank empty
Set Change Override Transport Harley Security Alarm PIN Code No Key Fob...
Mar 31, 2013 | Harley Davidson FLSTF Fat boy Motorcycles
Oil light stays on my fat boy and won't start
1. Fuel tank empty
7. Discharged battery, loose or broken battery connections especially the negative cable at "BOTH" ends
For a primary suspect please visit the website below. Good luck and have nice day.
Jan 14, 2013 | Harley Davidson FXSTS - FXSTSI Springer...
Street bob security light on,won't start
1. Fuel tank empty
For a primary suspect please visit the website below. Good luck and have nice day.Harley Davidson Wiring Diagrams and Schematics Set Change Override Transport Harley Security Alarm PIN Code No Key Fob...
May 17, 2012 | Harley Davidson Motorcycles
My 02 fxst will crank but wont turn over checked coil spark plugs ?
1.Ignition/Light Key Switch not in IGNITION position.
2.Engine Stop switch in the OFF position.
3.Discharged battery, loose or corroded connections check negative cable at BOTH ends. (solenoid chatters).
4. Bank Angle Sensor tripped and Ignition/Light Key Switch not cycled to Off and then back to on.
5. Starter control circuit, relay or solenoid faulty.
6. Electric starter shaft pinion gear not engaging or over-running clutch slipping.
7. Security alarm not disarming
For a prime suspect please visit website below and good Luck.
Feb 12, 2012 | 2002 Harley Davidson FXST Softail Standard
I need to replace a 15/15/15/15 Bryant Quad breaker. It is very difficult to find these for sale. Can a quad be replaced with two twins or four single pole breakers?
The reason for using the quad, is so that if any one of them trips, they all trip. GE used to sell lever covers that would join the levers together. I don't know if they still do. And I don't know if the Bryant breaker is JUST 4 single poles with their levers connected together.
Aug 13, 2011 | Bryant Westinghouse Bqc Quad Circuit...
We have 2 quinny zapps for our Twin Boys which we would like to connect from Time to Time so we don't have to take the Twin pram all the Time. Bought the connectors from Prince Lionheart, unfortunately...
Good Afternoon
We're unable to provide advice on this query as we do not produce a product which would connect two strollers together in this manner.
Jul 11, 2011 | Quinny Baby Gear
After connecting to the usb, led lights up, then off, windows does not detect it.
Is the hub you mention, an extension from another usb port only, as the adapter may need to be powered and require a AC/DC powered hub to work.
Jan 10, 2007 | Ashton Digital WRUB-2011i (Twin Pack)...
Home Security Logo
450 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
