Question about Sagem Televison & Video
After trying to get colours rectified by doing a Factory reset the picture will not fit screen as it did before. How can i adjust the picture?
Every button on handset.
    New Friend:
  • 43 Answers
Provide more details ( brand of tv, model etc) please.
Posted on Nov 23, 2014
I have a philips 42PFL5432D/37 that has a shadow covering about a 1/3 of the screen and will not change screen format. Stuck on Zoom setting that doesn't fit the entire picture on the screen. Bret
Try a factory reset to this set, and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Aug 05, 2016 | Philips Televison & Video
How can full picture be restored?
A factory reset can rectify the problem. There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 03, 2015 | Panasonic VIERA Televison & Video
Colour loss
Try a reset to this set and check. If it do not help you, contact any service technician. There are two types of reset to TVs. The first is simple to do; a Hard Reset; and the other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Apr 04, 2015 | Toshiba 32BV700B 32 in. LCD HDTV
Screen sethi, i am using HP LP2065 LCD with my computer. Now the problem is that color setting of LCD is not good and hence no clear picture and video.Please suggest me what i should do. thanks
try in menu auto adjustment and factory reset......
you can also play with frequency a little and color setup , clock and clock phase in Image control menu, play with it and you will see result... then save it...
Mar 27, 2014 | HP LP2065 Monitor
Colours are not fitting the picture
Look for any jammed buttons on remote. Remove battery from it. Switch off the TV manually, and wait for some time and switch it on. Now using control panel, try resetting it to what it was.
Aug 26, 2012 | Philips 37PF7320A 37 in. HD-Ready LCD...
E472VL picture on HD cable channels does not fit screen correctly-how can we fix it?
Consult the manual---the answer lies in the size controls being grayed out so you cannot adjust or try to adjust the vertical size!
Mar 28, 2012 | Televison & Video
Loss of good colour constant blue ghosting to picture, tried adjusting colour and gamma settings, no luck new lamp fitted still same problem. reset to factory settings picture gets worse? help
This will require a technician to repair.
You can do it yourself if you have the service manual and some knowledge of electronic repair, and access to the necessary parts.
It's generally cheaper to buy a new unit than to have one repaired though, unless of course it's under warranty.
Apr 04, 2011 | Hitachi CP-RS55 LCD Projector
Picture colour is wrong. Too much green and pink.
first reset the settings to factory default. then swap out the cable. if you still have trouble, replace the colorwheel.
Mar 27, 2010 | InFocus ScreenPlay 4805 Multimedia...
Colour problems
try to go in menu do factory reset ok
Feb 03, 2008 | Sampo PME-42S6 42 in. HD-Ready Plasma...
Televison & Video Logo
73 people viewed this question
Top Sagem Televison & Video Experts
Andy Fraser
Andy Fraser
electracon
ka4iup
ka4iup
Are you a Sagem Televison and Video Expert? Answer questions, earn points and help others
