Question about Garden
Need a wiring diagram for J .D 6630.to solve a starter problem.Thank you
No power to starter and all fuses O.K
  • 1,493 Answers
You don't need a wiring diagram friend, use a test light on the small wire at the starter solenoid and turn the key to start it. If the light comes on when try to crank engine and it don't crank over, replace the starter solenoid. If the light don't come on, there's no power from the switch to the solenoid and may just need to push the plug for wiring harness connection back onto the switch. This is about the only thing that ever happens when the problem happens.
Posted on Nov 23, 2014
I blew some fuse replacing battery.
Check your battery and starter connections. Are they all clean and tight, and correctly situated? Make sure no corrosion impedes electrical power.
Doesn't sound like you blew any fuse. You might have to look at a wiring diagram to test the starting system. With the key held in start, there should be power on the small wire at the starter solenoid (mounted on the starter motor). That is a good place to start-use a test light or voltmeter to test. If the small wire shows power, have the starter tested at a parts store. If no power with key held in start, then you do need a wiring diagram. The starting system is not all that complicated-it is pretty straightforward.
Feb 25, 2017 | Cars & Trucks
I need a wiring diagram for a 2002 chevy s10 4 wheel drive 4.3 for the starter to the switch
If the truck cranks over you have voltage at the ignition switch ! From starter to switch , First off starter to what switch ,ignition ? There is a 175amp fuse that supply's battery voltage to the power distribution center - fuse box under the hood . On the lower right side of the radiator support, below the battery !
Sep 10, 2015 | Cars & Trucks
Why cant i find a wiring diagram for a 2003 chrysler pt cruiser anywere?
You can. Try a Chilton's manual or the how to books sold at auto parts stores. The starter solenoid wire goes directly to the ignition switch The fuse marked IGN controls power to the starter solenoid.
Jul 17, 2014 | 2003 Chrysler PT Cruiser
Ignition problem
Check if the small wire on the starter has power with the key held in crank position. If battery voltage there, either bad battery cables or connections, or the starter solenoid has a malfunction. If no power when key held in start, it could be the safety switch (a clutch interlock switch on manual transmissions, or a park/neutral switch on automatics). You may need a wiring diagram to see the start circuit from ignition switch to the starter solenoid-some have a start relay in that circuit.
Find wiring diagrams at http://www.bbbind.com/technical.html
Free TSB's and wiring diagrams for every make and model.
Feb 09, 2014 | Cars & Trucks
Diagram of a 2000 chevy express wiring of a starter
( one question i have is every time the ignition fuse blows do i need to replace the starter relay? ) NO ! You have a dead short to ground on one of the circuits that fuse feeds. Do you know how to find a short circuit ? Video's on youtube show how. The fuse that blows ,is it IGN - A 40 amp. located in the under hood fuse/ relay center ? That fuse feeds B+ voltage to the ignition switch ,which powers up other thing's ,fuse's etc.. Not just the starter relay ! I see five other fuse's that get power from that fuse when ignition switch is in the start or run position . In the I/P fuse panel the gauges fuse #4 10amp , air bag fuse #10 10amp , turn b/u fuse #16 20amp. , Plus trans fuse #20 10 amp ! Pull out these fuse an try to start the van. if the ignition fuse doesn't blow the problem is in one of these other fuse circuits. There is one more fuse that get's B+ power from the ignition switch and ign A fuse ,crank fuse fuse #8 10amp. this powers the control side of the starter relay .
You can find a free wiring diagram here http://www.bbbind.com/free_tsb.html Enter vehicle info. year , make , model and engine . Under system click engine , under subsystem click starting. Click the search button then the blue link.
If you pull those fuse's i mention and it still blows the fuse look for a shorted ignition switch or wiring from ignition to the starter relay , not the relay itself. Park neutral safety switch . Isolate the circuit , pull the relay out of it's socket ,pull the crank fuse #8 in the I/P fuse box. with a ohm meter check to see if that part of the circuit is shorted to ground. Do you know how to do that ? Do you have a volt ohm meter ? You can buy one cheap at parts store .
Sep 14, 2017 | 2000 Chevrolet Express Cargo
The ignition quit working took the ignition wires touched together to make the bike start; the starter button then quit working so I was jumping the bike off the solnoid, worked for months. parked over a...
Check the starter,wire connection harness and starter solenoid.
That high amp means a power that was being drain by the solenoid or the starter motor.
Disconnect the wire terminal of the starter and connect your ignition, you will see that it will not drain power from your battery and solve your fuse popping.
Then pull down the starter, overhaul it and clean/lubricate the bushing. If you can't do the starter a mechanic can do it for you.
Hope that helps you.
Thanks for using FixYa!
Jul 15, 2011 | kawasaki KLR 250 Motorcycles
1984 ford f-150 4x4 ignition wiring diagram i need to see a break down wire for wire from starter to soloid to voltage regulator new starter new ignition module new started soloid and vechicle will not...
when looking at it from the front the most left is from the battery, now going right from there the little pin is from ignition, basically to flip this giant switch on. next little pin goes to your fuel shut off relay, it will turn on that relay to send power to your pump while cranking, next is the large out. far right. that goes to your starter.
May 16, 2010 | Cars & Trucks
Hello, need a wire diagram of the solenoid for a 1987 chevy blazer. Replaced starter and have no power. Thank you Tim.
should be a main cable wire and a couple of larger ring terminal fuse link wires on the top post and a smaller purple wire to the switch post neerest the block.no other wires are needed.
Jul 04, 2009 | 1998 Chevrolet Blazer
NEED WIRING DIAGRAM FOR 2002 PT CRUSIER STARTER
Hello chk614, my name is JShreader. Thank you for choosing fixya.com.
Here is a picture showing the Wires connecting to the Starter...
If you are looking for the formal Wiring Diagram...see below...
I hope this helps you. If you have any more questions or need any more diagrams, please don't hesitate to ask...Thanks again, JShreader!
Mar 31, 2009 | 2002 Chrysler PT Cruiser
Farenheit DVD-36 Car DVD need wiring diagram please
USUALLY THE BLACK IS ALWAYS GROUND AND THE RED CARRIES THE FUSE. IF IT DOES NOT SOLVE YOUR PROBLEM I GUESS YOU WILL HAVE TO TAKE IT TO A TECHNICIAN .THANK YOU.
Aug 14, 2008 | Farenheit DVD-36 Car DVD Player
Garden Logo
54 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
