Question about Seloc Nissan Tohatsu Outboards 2.5-140HP 1992-2009 Repair Manual All Engines - Seloc
Why does my tohatsu 30 two stroke start but cuts out upon acceleration
Plugs and fuel filter
2 Suggested Answers
goldbill
  • 184 Answers
SOURCE: 30 hp 4 stroke carburator problem
Check your "sync n link" of the throttle pick up and the ignition timing.
Posted on Oct 14, 2012
John deere model FC420
Specifications
Engine HD45
Engine Model Number(Kawasaki FC420V
Horsepower (10.5 kW (14 hp)
Displacement (423 cc (25.8 cu.in.)
Crankcase Capacity w/o oil filter (1.3 L (1.4 qt.)
Crankcase Capacity with oil filter (1.6 L (1.7 qt.)
Spark Plug-Gap (0.64 mm (0.025 in.)
Spark Plug-Torque (20 N·m (15 lb-ft.)
Cylinders (One
Stroke/Cycle (Four
Lubrication (Full-Pressure
Oil Filter (Standard Single Element
Air Cleaner (Dual Stage
Engine HD75
Engine Model Numbe(Kawasaki FC540V
Horsepower (12.7 kW (17 hp)
Displacement (535 cc (32.6 cu.in.)
Crankcase Capacity w/o oil filter (1.6 L (1.7 qt.)
Crankcase Capacity with oil filter (1.9 L (2.0 qt.)
Cylinders (One
Stroke/Cycle (Four
Fuel System
Fuel (See Fuel in the Service Miscellaneous section
Fuel Filter (Single Stage, 60 Micron
Fuel Pump (Vacuum Operated-Diaphragm
Fuel Delivery (Gravity Feed to Fuel Pump)
Fuel Tank Capacity (19 L (5.0 gal.)
Drive Train Mower Deck (36-inch)
Blades (2
Blade Bolt Torque (81 N·m (60 lb-ft.)
Cutting Heights (25-114 mm (1-41/2 in.)
Weight (86.7 Kg (191 lb)
Overall Width (chute up) (927 mm (36.5 in.)
Mower Deck (48-inch)
Blades (3
Blade Bolt Torque (68 N·m (50 lb-ft.)
Cutting Heights (25-127 mm (1-5 in.)
Weight (83.6 Kg (184 lb)
Overall Width (chute up) (1308 mm (51.5 in
ower Deck (54-inch)
Blades (3
Cutting Heights (25-127mm (1-5 in.)
Weight (86.7 Kg (187 lb)
Overall Width (chute up) (1460 mm (57.5 in.)
Recommended Lubricants
Engine Oil (John Deere PLUS-4
Grease (John Deere MOLY HIGH Temperature EP
Transmission Oil (HY-GARD-J20C (TURF-GARD-SAE10W-30 (PLUS-4-SAE10W-30 (TORQ-GARD SUPREME-SAE30
(Specifications and design subject to change without notice.)
Sep 28, 2016 | John Deere Garden
When accelerate above 30mph its cuts out or loses power but runs smooth at idle
Acceleration cut off when reach 30mph - Range Rovers
www.rangerovers.net/...rover.../27680-acceleration-cut-off-when-reach-...
Mar 30, 2010 - 16 posts - ‎6 authors
All of a sudden, RRSport HSE 2006 can not speed above 30mph. ... It's only an hour's drive away if your car could go straight upwards. .... My guess is that some control module got fried or out of whack when the power spike ...
WILL NOT GO OVER 30MPH WITH PEDLE TO METAL ...
repairpal.com > Questions > Dodge > Charger > 2006 Dodge Charger
... and a 18 wheeler comes up behind me going 85mph. or more and my car drops down to 35 to 40. ... It would not let me go pass 30mph and it would bog out. .... His truck was barely over 36k. when this happened. ... sudden I was cruising at 30 more or less and could not accelerate or shift gears I could just switch to Drive.
My Chevy Silverado won't go over 25 miles an ... - CarGurus
www.cargurus.com > Questions > Chevrolet > Silverado 1500
CarGurusSep 19, 2012 - His response wasn't even there until the page refreshed when I hit ...The engine would shut off due to a clogged fuel filter not hit 25 MPH and just stopaccelerating. ... when the gas pedal was to the floor but it wouldn't go over 30 MPH?.... When I punch it at 110 or above, it will cut out and drop to 103kph, ...
Starts,Idols perfect Bogs down, no power upon acceleration ...
Jan 31, 2016 | Cars & Trucks
9.8HP 4 stroke engine cuts out when accelerating about 25 %
That sounds like fuel starvation. Check the fuel lines for kinks or pinches and make sure you have the fuel tank vented. Slacken off the cap, and run it, that will prove if it is a venting problem. Also make sure the priming bulb is installed the right way round. The arrow should be pointing to the engine.
Also check spark plug gap and that the HT leads are tight and aren't rubbing on metal and have worn through.
Jan 08, 2016 | Seloc Nissan Tohatsu Outboards 2.5-140HP...
1997 geo prizm won't stay running sputters and dies upon acceleration
, like it ain't gettin fuel; probabley a fuel pump or fuel injecter, fuel filter, something along those lines. Start with the filter its cheapest
Jan 13, 2013 | 1997 Geo Prizm
I have a 18" Craftsman gas chain saw. It will not keep running, after two or three cuts it just stops and cannot be started again until it sits for 15 to 20 minutes. I have cleaned the air filter and...
Try removing the fuel cap for a moment, then try restart. If ok, check the fuel vent for plugging. Check the fuel filter for plugging. Inspect the fuel lines for decay or other damage. Check for spark when it stops--it may be the ignition module failing when hot. Check for sawdust and dirt plugging the ventilation system--blow it out with compressed air. Does the engine 4-stroke at speed when not cutting, but does 2-stroke when cutting? Make sure the chain is being oiled while running. Hope this helps!
Jul 13, 2010 | Craftsman 18" Chain Saw Replacement Bar...
Craftsman Chain saw cuts out
Check the fuel filter for plugging and the condition of all fuel lines. Make sure that all carburetor fasteners are tight. Check the air cleaner and muffler for any plugging. Make sure to warm the engine up before accelerating it. If still not running correctly, try turning the H jet needle about 1/8 turn CCW, which should cause the engine to 4-stroke at speed when NOT cutting, but immediately 2-stroke when you are cutting. Hope this helps!
May 11, 2010 | Garden
My Echo CS starts fine but then will not accelerate. Sometimes, after it's warm, it will work OK, but more often, it acts as if the chain lock is engaged and almost wants to stall as the throttle is...
Can the chain be pulled by hand fairly easily? Check the fuel filter, air cleaner, and muffler for plugging. Inspect the fuel lines for decay or other damage. Make sure the carburetor fasteners are tight. Try turning the H jet needle CCW about 1/8 turn--the engine should 4-stroke when running free at speed, but 2-stroke when cutting. Hope this helps!
May 12, 2010 | Echo CS400 18" Chain Saw
MacCulloch 839 Petrol Chainsaw.Erratic running
Check the fuel filter, air cleaner and muffler for plugging. Warm up the engine first. Pull the throttle full on and try turning the H jet needle CW with the engine 4-stroking, but which immediately 2-strokes when cutting. This will not produce the highest speed, but will produce the most power and least heat. Be sure to use fresh fuel mix at all times. Hope this helps!
Mar 29, 2010 | Garden
My 1992 Nissan Maxima is sputtering upon acceleration. It has 220,000 miles on it and it seems to mainly have this problem in first gear. And mostly happens shortly after starting the car. Ive done a basic...
92 max
I own a 92 max 370 kms runs good but one day just cuts out while doing about 30 km, I pull over i can start it no problem but when I touch the pedal to accelerate the car stalls out.
It got worse to the point of sputtering on the highway , sometimes i could keep it alive by working the pedal but others would slow down and stall out.
I have changed the fuel filter and plugs seemed to make it a bit better but still stalling. I ran it in my driveway for 10 mins on idle then it stalls out
Is this the fuel pump??
Jun 13, 2009 | 1992 Nissan Maxima
Seloc Nissan Tohatsu Outboards 2.5-140HP 1992-2009 Repair Manual All Engines - Seloc Logo
483 people viewed this question
Top Seloc Boating Experts
Bill Boyd
Steve P
Steve P
Are you a Seloc Boating Expert? Answer questions, earn points and help others
