Question about Continental Electric Irons
How to fix an iron (Philips Azur GC series) that does not get hot enough. The light turns off too quickly after turn on: how to replace the thermostat??
- Tried descaling it, but as it does not get hot enough, this does not work. -Tried disassembling the iron COMPLETELY and did not find anything wrong with it. Thermostat would behave as expected. - Checked the thermal fuse with a multimeter while the iron was disconnected, and there was electrical connection between plus and minus after turning the temperature knob. - Iron is now back in one piece, still does not descale, but seems to be heating a bit more. - Maybe the thermostat must be replaced? In that case, how to do that? It is not obvious how to replace it, and I can see no serial number on the thermostat assembly
    Master:
  • Continental ... Master
  • 996 Answers
Only by expert professional,by opening upper lid,
Posted on Jan 21, 2015
VOTIT
  • 2071 Answers
SOURCE: Black & Decker Iron - Steam Advantage - won't turn on
Just open your flat iron and locate the face plate contactor that has a soot burn causing the filament not to heat,use a sand paper to clean the contact from soot burnt,this the common problem of a flat iron...
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Posted on Aug 10, 2008
SOURCE: Problem with Philips Azur Precise 4340 Iron
i had the same problem and the Philips hekp site was no use. I turned my iron off until it was completely cooled down then switched it back on again, with the steam number turned to 5 and the heat on max. as soon as the ready light went off, i put my iron in the horizontal position and shook it back and forth (quite vigorously) and it seemed to have dont the trick!
Posted on Aug 28, 2008
SOURCE: Iron No Longer Heats Up
Recommended solution, gently shake, did not work.
Considering the iron was at a minimum two years old, I decided to purchase another Rowenta. I found the recommended solution documented on a FAQ sheet enclosed with the new iron.
I actually own another Rowenta iron (I now have three) that has the same issue. I will send one iron, the one manufactured in Germany, to a Rowenta Service Center to see if can be repaired - it was the first Rowenta iron I purchased and it provided several good years of service.
Posted on Sep 21, 2008
SOURCE: HOW DO I DESCALE A STEAM GENERATOR IRON
Place the iron soleplate, unplugged of course, in a shallow dish of water and descaler and leave it for a while. I have just done this with mine and its working a treat.
Posted on Sep 15, 2009
DiYerTech
  • 70 Answers
SOURCE: What happens if I use CLR in my steam iron?
The steam tank may not be heating because of mineral deposits in the tank. But also do this check first. Open up the tank reservoir cold, and drain all water out, (is it clean inside there when you shine flashlight in there? Rinse with clear filtered water only (low minerals).
Do not use CLR or anything agressive in there. You should have the main unit in full steam mode and the iron control also in full steam mode. Leave one tablespoon of water in the tank, put back together and let the pressure build. Put a clean towel on your ironing board and when iron is at full pressure and heat, hit the burst of steam and look at what comes out of the sole plate. If you see lots of white deposits look at the sole plate and see if the white chunks are coming out steam holes.
When using iron, run it till steam/water tanks are dry, the burst of steam is used in this case to clean the iron of all standing water. Pull the reservoir and allow to cool...once tank is cool drain it as well. Doing this several times should help purge unit of the heavy mineral deposits.
If you need parts, here is the Rowenta repair facility....
California Electric Service in Concord CA (it is the only Rowenta repair station in California) go to either of the following addresses:
their website is: http://www.californiaelectricservice.com/
or tech service: service@californiaelectricservice.com
Posted on Jun 06, 2010
WHERE IS THE SERIAL NUMBER ON THE PHILIPS GC4890/02
I remember reading a # stamped right on the prongs of the plug in. Let me know if that works!
Jul 10, 2014 | Philips Azur Gc4890/02 Steam Iron With...
Red light refill flashing but water in the tank
Hey did you ever get an answer to your question?
I have the same problem
Jun 10, 2013 | Philips GC 8220 Iron
Philips GC 2510 won't light up or heat up
If the iron doesn't heat, make sure power is on to the outlet,,test the outlet with desk lamp for to see if working. check the electrical cord, and check the thermostat + fuse inside replace if necessary.
Jan 25, 2013 | Philips GC 2510 Iron
Refill water tank light won't go out
Then replace it because they are not repaired.
Jun 30, 2017 | Philips GC 8220 Iron
Philips GC 8220 repair manual
Red water light has come on for the first time.
water chamber is full of water.
Iron is not producing any steam what could be the problem ?
Sep 14, 2012 | Philips GC 8220 Iron
I cant get my iron to get hot enough it gets warm but then the light will sut off and it will stop heatting up
The problem lies with the thermostatic control. Check that your control knob has not been incorrectly replaced on the thermostat shaft and that you have full turning motion on the knob, it should turn about 3/4 turn from stop to stop. The thermostatic control is adjustable, but to do this the iron must be stripped.
Feb 02, 2011 | Maytag Irons
Iron producing lots of water
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
May 18, 2010 | Philips GC 8220 Iron
Phillips Azur Precice 4340 , lost instructions . How do you de calc it ? Thank you . Claire
Fill tank with water and put steam setting to 0.Set temp pial to hottest setting. Let the iron heat up till the light in the hand goes out. Switch off power and hold iron over sink. Push down and hold descale button until all the steam and water has gone from iron. Wipe plate and heat up iron again with no water in it.
Nov 09, 2009 | Philips HI-296 Iron
Jul 09, 2008 | Irons
Help
heres a link so you can get more information for your product , hope this helps AJ .
http://www.shopping.com/xPP-irons-norelco~LO-1~CR-0
May 17, 2008 | Philips HI-296 Iron
Irons Logo
259 people viewed this question
Top Continental Electric Irons Experts
Are you a Continental Electric Iron Expert? Answer questions, earn points and help others
