Question about Dishwashers
My Defy Dishmaid Super Silent breaks the dishes, stays hot for a long time and leaves white residue on the dishes. Someone said it could be the water level that is too low. How do I check the water le
To wash dishes on lower level but some does not get clean. To clean the filters and spray arms which did not help. I have even run a cycle with a Dishwasher cleaner.
  • 40 Answers
Change the heat sensor its almost sure that is short circuited
Posted on Nov 24, 2014
  • 641 Answers
SOURCE: dishwasher leaves residue in top rack only
Most cleaning problems are caused by the dishwasher not getting enough water. It could be cause of the switch level, which control water level in the tub. The switch level is usually a diaphragm device with a small clear tube attached between the switch and the bottom of the washer's outer tub. I am not familiar with your machine, but if you will open the rear panel you will find it easily. Be aware you should discoonect the power cable !!! Clear the tube (attached between the switch and the bottom of the washer's outer tub) from any obstruction.In case it will not solve the problem, you should replace the switch. Good luck !
Posted on Jun 01, 2006
  • 677 Answers
SOURCE: Dishes are not coming out fully clean
the is a new product out called the dishwasher filtration system. it actually filters the water going into your dishwasher and leaves your dishes spot free. after the first load i was amazed that the white film was gone and my dishes were sparkling. you can get it at www.dishwasherfilter.com.
Posted on May 21, 2008
reg501
  • 413 Answers
SOURCE: Dishwasher spray arms don't spin & spray water
Could be a a couple different issues.. Not filling with enough water or food chopper broke or food chopper filter screen clogged.
Check water level:
Run the DW and wait for the main wash to start (water will fill. pause then complete fill) The water should be no more than 1/4 inch below the heating element. If not there..replace water inlet valve.
Inspect food chopper:
1. Remove lower spray arm and rear water supply tube to upper spray arm.
2. Remove torx screws that secure the sump cover.
3. Remove primary filter
4. Remove food chopper cover to expose the chopper assembly. Inspect for breakage or blockage.
If you need further assistance, let me know
Regards,
reg501
Posted on Jun 29, 2008
jonniewalker
  • 1029 Answers
it could be due to Not filling enough water or food chopper broke or food chopper filter screen clogged.
Check water level:
check the food chopper:
. Remove torx screws that secure the sump cover. Remove primary filter. Remove food chopper cover to expose the chopper assembly. Inspect for breakage or blockage.
Posted on Aug 15, 2008
  • 677 Answers
SOURCE: GE Profile Dishwasher (5 years old); Leaving residue on dishes
There is a new product out that actually filters the water going into your dishwasher. My dishes came out amazing after the first load. No more cloudy glasses. I was very impressed. Who knows whats in the water cleaning your dishes so i thought this filter was great. It is very affordable and you can get it at www.dishwasherfilter.com. Hope this helps some people.
Posted on Jan 06, 2009
My Maytag quiet series 200 is not cleaning and despite many attempts it is also leaving terrible residue on dishes.
I found this on ehow I believe it will help. How to Troubleshoot Dishwasher Residue By Dale Yalanovsky eHow Contributor
5Found This HelpfulGeorge Doyle/Stockbyte/Getty images
Dishwater residue is a fairly common occurrence, and several things can cause it. Even the newest dishwashers may leave residue, and it might have nothing to do with the actual dishwasher function itself. However, there are things you can do to prevent, limit or completely remove dishwasher residue during every washing cycle.
Other People Are Reading
  1. Detergent Residue
    • Modern phosphate-free detergents are the main culprits when it comes to detergent residue. After every wash, many leave a slight whitish residue behind. After several washings, the residue becomes caked on and leaves a noticeable white tint to your dishes. Some dishwasher detergent brands are better than others, and either minimize residue or do not leave any. Once residue is present, however, the only way to remove it is by hand scrubbing or scraping.
    Hard-Water Residue
    • Hard-water residue comes from non-softened water from your hot water tank. Non-softened water leaves a white tint on dishes, but no amount of scrubbing will remove it. Only by wiping a small patch of the dish with vinegar or lemon juice will you be able to ascertain whether the white residue left is hard water or detergent. The slight acidic action of the vinegar or lemon juice removes hard-water stains, but they have no effect on detergent residue.
    Greasy Residue
    • If the dishes feel greasy when they come out of the dishwasher freshly washed, you are dealing with a greasy residue. There are two main reasons for this: either the detergent is not an effective grease remover, or the hot water inside of the dishwasher, either from the hot water tank or the dishwasher's heating elements, is not hot enough. Boosting the hot water temperature on the water tank may solve the problem, and a second wash cycle may be needed for the dishes. A preventive measure of running the dishwasher empty with a full load of detergent also removes the residue inside of the dishwasher.
    Streaking and Spotting Residue
    • If you have spotting or streaking on your dishes, that may be a sign you need a rinse agent. Many modern dishwashers recommend a rinse agent to prevent spotting or streaking, and without one, your dishes will never be crystal clear or streak-free. The next time you do a dishwasher load, add a rinse agent. If the dishes come out spot- and streak-free, the problem is solved.
Read more : http://www.ehow.com/info_12285021_troubleshoot-dishwasher-residue.html
May 19, 2015 | Maytag Dishwashers
Defy dishmaid DW12
You have a major short to ground which is tripping the breaker. Get an electrician to check the machine, it may be as simple as you have trapped the cable. Don\'t mess with water and electrics. Electricity is the silent killer.
Aug 21, 2014 | KitchenAid Kitchen Aid Diswasher Part...
Have a Maytag MDB4000AWW dishwasher that now leaves white residue on glassware. I think that the water is not getting hot enough. Does this model increase the water temperature, if yes how do you test that...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Nov 08, 2010 | Maytag 24 in. MDB4000 Built-in Dishwasher
White residue left on dishes; Plastic ware being oxidized
heatman101
May 10, 2010 | Bosch 24 in. SHX46A02 / SHX46A06 Built-in...
Leaving white film on dishes, outside of glasses dirty
The problem is hard water. There is a new product out called the dishwasher filtration system. It filters the water before it enters your dishwasher. It works amazing and has a money back guarantee. You will love the way your dishes look after the first load. It is also very affordable (like 70 bucks). Go to www.dishwasherfilter.com to find out more info.
May 03, 2010 | KitchenAid 24 in. KUDS01FLBL Built-in...
It is leaving an enormous amount of white residue on our dishes and is causing all of our metal dishes to come out dark.
The white residue could be from one of two sources.
Detergent Residue:
Using too much detergent or poor circulation of water can leave a white residue on the dishes. If the residue is easily rinsed off with warm water then it is detergent. Use less soap, especially if you pre-rinse the dishes or have soft water. Use a hi temperature wash to help dissolve the soap better.
Hard water deposits:
See this link where I put together some information on this.
http://www.fixya.com/support/r4666624-hard_water_calcium_white_powder_build_up
May 01, 2010 | Whirlpool Dishwashers
Residue on dishes
You may have a problem with your heating element...if the water isn't staying hot the dishwasher2_bing.gif will not work well...
Check out this tip and the there are others at the bottom of that one...
http://www.fixya.com/support/r4589033-dishwasher_problems_heating_element_not
heatman101
Apr 20, 2010 | GE Adora GHDA656LSS Stainless Steel...
DISHWASHER MODEL # KUDS03FTBL2 WORKED VERY WELL UNTIL TWO TO THREE DAYS AGO DISHWASHER NOW LEAVES MASSIVE FILM AND DEBRIS (LOOKS LIKE FINELY GROUND UP GRAVEL AND DIRT) OTHER DISHES AND SILVERWARE HEAVILY...
There is a product out called the dishwasher filtration system. it filters the water going into your dishwasher reducing the hrad minerals that leave that white residue. it is very affordable and works amazing. it goes right under the sink and is easy to install. go to www.dishwasherfilter.com for more info on it.
May 01, 2009 | Dishwashers
Dishes not getting clean
the problem is hard water leaving the residue. go to www.dishwasherfilter.com and get the dishwasher filtration system. it will reduce the hard minerals that leave the residue and your dishes will be clean as can be. it is very affordable and fits right under your sink.
Mar 10, 2009 | Maytag MDB6000 Dishwasher
My dishwasher leaves a cloudy residue on my dishes
The cloudy residue that is left on your dishes is soap that has not completly broken down.
There are a few solutions to the problem. First off, you want to ensure that you are using the "high temp wash" option. This will boost your water temp during the wash cycle to ensure that all the soap breaks down.
The second thing that you want to do to give your dishwasher a boost, is run the hot water in the sink and make sure it's pipping hot before you start your dishwasher. What this will do is ensure that the water that goes in for the "pre wash" portion of the wash is hot and will improve the wash quality.
Mar 01, 2009 | Kenmore 24 in. 15079 Built-in Dishwasher
Dishwashers Logo
192 people viewed this question
Top Dishwashers Experts
