Question about ASUS Computers & Internet
MY Asus K70 AC won't start. Put in a new battery, no result. Startup Only with adapter, so without the accu. no result. Sometimes after many hours it starts and all functions go very well. It has
Chipset AMD RS780 chipset Main Memory DDR2 800 MHz SDRAM, 2 x SODIMM 4GB SDRAM Put in a new battery, no result. Startup Only with adapter, so without the accu. no result. Sometimes after many hours it starts and all functions go very well.
    Scholar:
  • 32 Answers
If it stays on long enough I would look at the error reports (you can google how to check that) and see if there are any critical errors that are affecting it from starting up or makes it crash and appear to not start up almost immediately after start-up.
If its a new computer there is a chance that there was a manufacturer flaw and 1) Could have been damaged during transportation, 2) Could be a design flaw if it was customized, 3) Could have been damaged while being built if customized, 4) Dropping it the wrong way could make it so the battery can't interact with the PC
To clarify, when you say it starts up after many hours, is that while plugged in and does it say the battery is charged/charging or is it a hit and miss type of thing where it will sometimes start up and sometimes not?
I hope this helps, but if it doesn't you should try to provide a bit more information as to the issue!
Posted on Nov 25, 2014
TimeDefensiv
  • 746 Answers
SOURCE: The screen display reset to 640x480 on startup.
Anyways, yes, the native resolution is 1280x800 at 60 Hz. Its a PnP device part of the Mobile Intel 945GM Express chipset family. Find a ATI Mobility Radeon plugin or create one. Be careful, ATI desktop drivers dosn't support offficial mobility chip (some inf entries are missing).
Start with drivers from your manufacturer. You can use ATI desktop driver files, but you have to add your hardware device number. Be aware, that's not a official solution, but this works in most cases.
Thank You
Posted on Jul 26, 2009
SOURCE: my dell inspiron 1521 laptop with amd athlon x2
hit Ctrl and F11 while the blue bar is loading this will start your recovery process. now if there are beep codes then it might be something diffrent your computer will beep once thats normal but if it beeps more times after that you need to post how many count them. right now it looks like your harddrive crashed.
Posted on Feb 24, 2009
SOURCE: Winxp Drivers For CQ45-112AU or CQ45-106AU
in compaq cq 45 112au fingerprint reader not working with windows xp pro with sp3
Posted on Feb 19, 2009
SOURCE: Everex XT5300T StepNote will not boot?
We had the same problem. The computer went into hibernation after losing a/c and running the battery down. Found several people on internet had same problem but only one solution (wich didnt work for us). What we did finally was to turn on and leave it until battery dies. (goes into hibernation) try to power up and when screen lights up plug A/C power in. Sounds like a jury rig i know but it is what worked for us.
Posted on Dec 14, 2009
harit1988
  • 149 Answers
SOURCE: Toshiba Laptop - Startup freeze 40% of the time.
its a common thing for a vista based system to freeze after some updates , and my good advice to you is you better dont place too many applications on the startup , and avoid unwanted updating , ie8 is one such thing . if u have an option better switch to windows 7 , its really fast on notebook computers . install only defender updates from windows.
Posted on Jul 05, 2010
Laptop asus K70 only green lights and sound of harddisc and fan
Do you get bios beeps when you remove the memory all together? If no, then I would suspect processor or motherboard failure.
Feb 13, 2015 | ASUS Computers & Internet
Asus a3a laptop
Probably the AC Adapter is no good....Go to e-bay and purchase a new AC Adapter for that model # notebook. But if it shows charging then try first by taking out the battery and see if the AC adapter will run the computer without the battery in it (if so, then the adapter is good, the battery is actually bad, so replace the battery instead).
Good Luck.
Nov 29, 2013 | ASUS A3Ac Notebook
Laptop won't startup on power or battery
Step 1:
Take the battery out, plug in the charger and see if the laptop works. If it works, the battery may be the problem. Check the AC Adapter
Check to make sure the adapter is plugged securely into the wall outlet, connected firmly to the adapter box and to the back of your laptop. Most AC adapters have a little light in them on that rectangular box in the middle of the cord that lights up when it's getting electricity. If that light isn't on, try a different outlet. Check your fuse or circuit breaker box and plug a different device into that outlet to make sure there is power to it. If it still does not light up, your adapter could need replacing. Also check the adapter box for signs of warmth, as it will generate heat when it's plugged in. No heat means no power.
Remove the Battery Sometimes it's as simple as a seated battery. Remove the battery entirely and clean out any dust, lint or hair that may be clogging the connectors and preventing a proper connection. Reseat the battery securely and make sure the little locking pins that hold your battery in place are securely fastened and there is no movement. Unplug your laptop while it is running. If it still works, the battery has been charging. If it shuts off, or doesn't hold a charge very long, you have a bad battery. Unplug your laptop while it is off, then try to turn it on. If the battery is bad, your laptop probably won't turn on at all. Turn off your laptop's screen-saver when testing its battery. The screen-saver will conserve the battery and not give a clear time frame for how long your battery can really last. Click the battery icon on your laptop when it is unplugged. It can tell you how much battery life you have available. This icon is usually located in the bottom right corner of your screen and will provide the percentage of battery power you have left. Keep track of the time it takes to go from 100% charged to 1% charged. If this takes less than an hour, your battery is probably beginning to fail. You can also try this every week or two to see if your battery holds a charge for shorter periods. Factor in the amount of time you have used your laptop. Most laptop batteries last 2 to 3 years or about 500 charges. Wait a few days before determining whether a new laptop battery is faulty. New batteries sometimes take a few charges to build up to their maximum run time.
Feb 07, 2013 | ASUS F3SV-B2 Notebook
Asus wont turn on
For this kind of issue, please follow up the following steps to check:
1.confirm the battery and ac adapter connect the laptop normally.Maybe the bad connect lead to this problem. If there are no lights when you turn on laptop, one of possible reason is that your adapter is malfunction.
2.the second possible cause is laptop dc jack failure. If the dc jack is broken or loose, you are required to replace it or repair it.
3.Another possible reason is that there is something wrong with laptop motherboard. For this situation, it includs two kinds of possibility,a failure in an electronic circuit and BGA malfunction.
For more detailed reasons and solutions, please have a look at the following article:http://www.ifitjams.com/lappower.htm
If you verify your laptop adapter is dead and you plan to order a new one, I recommend one for you on the basis of your laptop model:
http://www.chargerbuy.com/laptop-ac-adapter/asus-ac-adapters.html
Nov 30, 2012 | ASUS K Computers & Internet
Hello. Today in the morning my laptop (Asus A8Jseries) was working alright. Then after 6 hours when i tried to turn it on, it didn't. I mean, it starts to work and Asus symbol comes alone, but then it just...
If it happens only when you move the adapter plug inside the power jack, it's likely that you have a problem with the power jack inside the laptop. The power jack has to be resoldered or replaced.
If it happens even without touching the adapter plug, the problem could be related to the faulty power adapter.
You can test the power adapter with a voltmeter and find out if the ouputed voltage is correct. If the voltage is not correct, replace the adapter.
http://www.chargerbuy.com/replacement-asus-a8-ac-adapter-19v-3-42a.html
But don't trust that even if the output votage matches specifications. It's possible that the power adapter doesnt' work correctly under load. Test your laptop with another known good adapter. If the laptop works fine with another adapter, your power adapter is defective and has to be replaced.
Mar 13, 2011 | ASUS A8J Laptop AC Power Adapter (4.3A...
I have a problem with my Asus 1005HA bios revision 1301 the computer stopped responding, windows did not start successfully.
1.Try to unplug the ac adapter (charger), remove the battery(located on the bottom) and without the power sources (w/o battery and ac adapter), hold down the power button 10 secs. Put the power sources back and turn ON the laptop. If same thing go to 2.
2.Boot in safemode and do system restore. Follow the steps http://support.microsoft.com/kb/304449
Mar 01, 2011 | ASUS Computers & Internet
Pavilion dv9308nr PC Notebook: hp dv9308nr wont power on all the time... works if...
Due to regular use of the notebook, some static charges tend to stay in the computer, and sometimes results in not allowing the computer to function properly.
Please follow the power drain procedure to confirm the same:
1. Disconnect the AC Adapter.
2. Remove the Battery.
3. Hold the Power button down for 30seconds to 1 minute.
4. Put the Battery in.
5. Reconnect the AC adapter.
6. Turn on the Notebook power.
7. Restart the Notebook.
If the Notebook boots up you may fix the battery back. Try restarting the computer only with the AC power, without the battery & vice-versa. If the issue still persists then I request you to reset the memory modules, as sometimes the memory module connection get loose.
May 17, 2010 | HP Pavilion dv9308nr Notebook
I have tried removing battery and reinstalling. i have reset with button and have used new ac adapter. I get power to laptop but all it will do is the power light blinks like in standby mode. it will not...
Please get back with the results.
Mar 19, 2010 | HP Compaq Presario 2135US Notebook
Thbattery does not charge.I have installed a new
you can try 2 things
1st option
If you get this message that "Plugging, Not charging", don't worry. it may be cause inconvenient removing your battery, well:
1- remove your battery
2- directly connect AC adapter
3- restart or on your laptop
4- after loading windows, put the battery
enjoy...
if it not work, you must flash your BIOS or upgrade to new version can find from your manufacturer company website.
2nd option
Take battery out and use pencil erases to gently clean the contacts. Also clean contacts on laptop battery box.
Sometimes the contacts oxidize.
Then put back in and see if it charges.
Jan 13, 2010 | ASUS Computers & Internet
Asus eee 901 will not start
Try this - open the laptop up and on the motherboard there should be a small round flat battery (bios/cmos) take this out and leave it out for atleast 20 minutes then put it back in and startup the laptop. Hope it helps, leave me a comment to let me know!
Aug 09, 2009 | ASUS Eee PC 900 PC Notebook
Computers & Internet Logo
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
