Fix fat man docking station having plugged in on wrong voltage
4 Suggested Answers
SOURCE: bose docking station chip broke off
I had the same problem that the ipod would onl play when I pulled it forward in the dock. Looking closely, I saw that some of the pins on the left hand side of the connector were bent forward, so I bent them back with a needle:
(ie. pushing the pins to the right, as shown here). This solved the problem for me.
If your connector is too far gone, I suggest looking to:
http://www.chargeconverter.com/shop/connector.htm
for a new connector for £3-4 or
for a whole PCB (Printed Circuit Board) replacement for £10-15.
Hope this helps...
Posted on May 01, 2009
cjackHD
  • 71 Answers
SOURCE: Plastic shroud pulled out of docking station power port.
If the 4 input jacks on the back of the SoundDock seem to be okay, then just order a new power supply. If this is not the case, send it in for repair ($100) which upgrades the SoundDock to be able to use the newer iPods (iPod touch 2nd gen, new nano, iPhone 3G)
They give you a new 1 year warranty as well.
Posted on May 28, 2009
jazzyboy11
  • 728 Answers
SOURCE: My Ipod Nano wont charge...
There may be a broken power cord that leads to the charger for the ipod in the nextplay dock. If there is only one broken wire leading to the charger or there is only something wrong with the actual charger in the dock itself, it will not affect any other part of the dock itself which allows the clock and other stuff to work like normal. Unless the one you still have is still under warranty, you will have to get another one.
Posted on Aug 05, 2009
AC adapter not charging system
The low battery light may be indicating that the battery needs to be replaced.
Nov 28, 2013 | Altec Lansing Inmotion-IM600...
I plugged wrong adapter (dock's proper voltage was
Doubtful, you've plugged it into a voltage of nearly twice its rating. My guess is that you've blown it up.
Oct 30, 2013 | Altec Lansing - IMT320 - inMotion Compact
How can i update dell dock?
A docking station is an extension or addition of ports for a laptop computer. Once the portable computer is docked, you can access the docking station's ports, such as PS/2 or USB 2.0 ports, through your computer. Some docking stations have monitors that you can connect your computer to, placing your video on an external screen so you can turn off your computer's monitor and conserve some of your computer's energy. All Dell docking stations will have the same general troubleshooting steps.
Plug your laptop's power adapter into the docking station and dock your laptop onto/into the docking station. If there is no power going to your laptop from the docking station but it works when the power adapter is plugged into the wall, the docking station is bad and needs to be replaced. Plug your power adapter into the docking station and dock your laptop onto/into the docking station. If power goes on but your computer doesn't recognizes accessories such as a USB mouse--plugged into the docking station, try a different port on the station. If it works in a different port, the previous USB port is burned out. Plug your power adapter into the docking station and dock your laptop onto/into the docking station. If power is going through the docking station but no accessories are being recognized, you might have a corrupted docking profile. Undock the computer and dock it again once it has fully started up to reset the docking profile. Plug your power adapter into the docking station and dock your laptop onto/into the docking station. If you have an external monitor and it is not working, completely close the lid on the laptop so the image will move to the external monitor. Plug your power adapter into the docking station and dock your laptop onto/into the docking station. If power is going through the docking station but no accessories are being recognized and resetting the docking profile fails, update all drivers through Dell's support website and then re-dock the computer. Some of the software that runs the hardware may have become corrupted. Hope this helps
b>
Jan 16, 2013 | Dell Inspiron 1545 Notebook
Dell duo station
I had the same issue. I tried opening the dock and could not find anything wrong. It seems the charger was delivering sufficient voltage. So I disconnected power to the charger and reconnected couple of times and it started working again. My charger has a LED light and based on the brightness of the light you can findout if the output voltage is close to 20 volts.
Sep 20, 2012 | Dell Jbl Inspiron Duo 1090 Audio Station...
My docking station keeps making an intermittent noise sort of a blip blip noise whether it is plugged in or not
The problem could be your dock resetting if itis a type B build. I suggest you visit www.invebo.com and enter your dock serial number. (Several builds of Sounddock look identical butthe internal hardware is different) You get access to diagnostic and repair videos and it tells you what pods and phones your dock is compatible with. Also there is a diagnostic video that helps you decide what's wrong and kits and detailed instruction videos that lets you fix the problem yourself. If your dock connector is faulty than you can fit the charge upgrade or upgrade to Bluetooth on a Bose SoundDock Original for less that the cost of a repair. All kits you get a new docking connector of the later, tougher design included in the kit.
Oct 01, 2011 | Bose SoundDock Portable Digital Music...
Wont charge my iphone
The adapter off the docking station can be faulty and so that must be checked for working voltage.
If there is voltage on the adapter then the socking station charging section can be faulty.
The failure of the regulator IC in the docking station cannot be ruled out. You will need to remove the docking station after making sure there is no voltage to the docking section to the phone.
Nov 19, 2010 | RCA RP5500I Docking Station
Jbl radial dock connector broken
I have the same problem, but I got round it instantly by plugging my ipod into the speaker via the headphone port on the ipod and into the audio port on the speaker. The speaker came with a spare lead as you can plug any music player into it this way. The sound quality seems exactly the same and I dont have to throw away the speakers, hooray! If you have lost the lead you need a 3.5 mm male to male headphone lead, just pence in any electrical shop or amazon!
Aug 15, 2009 | JBL Radial Speaker Dock Docking Station...
1tb external hard drive connecting to a laptop
No its nothing wrong with connecting a external harddrive to a laptop. Usually docking stations wouldn't cause this problem. It could have been just a bad luck of the draw with your laptop. Man made it and it can fail. Just normal wear and tear
Jun 17, 2009 | Samsung 1TB SATA2 7200RPM 32MB HD103UJ 334...
Dock station for hp pavilion
You need to check the plug that plugs into the laptop to determine that you don't have a faulty lead or plug. Test it with a multimeter and wriggle the plug to see if the voltage reading remains steady. If it doesn't then it could be the lead and this is easily repaired.
You may be able to borrow an adapter to test your laptop's connector.
If you determine the fault is with the laptop then problem is most likely the connector socket on the laptop, it most likely need re-soldering onto the motherboard, or needs to be replaced. This requires the laptop to be dismantled completely.
A docking station would solve your problem because the docking station has its own power connector and you plug the existing power adapter into the docking station.
My HP is connected to a docking station, the other advantage is that the docking station has several more ports than the laptop which is useful.
Feb 12, 2009 | HP Pavilion dv6000z Notebook
D630 docked , ext mouse & kybd not responding
If the docking station has power:
Make sure power is off for both the laptop and the docking station. Plug your keyboard and mouse into the docking station. Dock the D630 to the docking station and then power on docking station. This should then turn on your D630. Your D630 should detect the keyboard and mouse.
If the docking station has no power:
Verify that the power cord, AC adaptor, etc. is plugged in. If the items listed seem to be in order,
there may be a problem with the power going into the docking station. (AC adaptor?)
support.dell.com will have the specific details for your D630 and your docking station, et al.
Please let me know if you have success in this.
Binary Bob
Nov 27, 2008 | Dell Latitude D600 Notebook
47 people viewed this question
 Grubhead
Grubhead
