Question about Pool & Spa
We have a Rianni 1004F propane water. We were wondering how low the temp will go in economy mode as we are leaving it on during the week while we are gone. The manual is unclear.
    Top Expert:
  • Pool & Spa Master
  • 8,143 Answers
Turn on before you leave and monitor temp
Posted on May 11, 2016
My spa is at 89 and its set for 104 and the pump will not cut on what is the problem
You may be in economy mode. Economy only heats the water during a programmed filter cycle. You want it to be in standard mode which turns on the hot tub once the water is 2 degrees below the desired temperature. There should be a mode or program button on your topside. One some systems you'll have to hit prog/mode button then the temp up button to change the mode. There is also a sleep mode. Never used it not sure what it's for.
Apr 12, 2015 | Dream Maker Spas Dream Maker Ez Spa Hot...
We have a Rianni 1004F propane heater. We were wondering how low the temp will go in economy mode as we are leaving it on during the week while we are gone. The manual is unclear.
Do not leave it on. The thermostat could [ figuratively freeze up] lock on a certain temperature, overheat and cause internal wires to catch on fire
Nov 23, 2014 | Heating & Cooling
A downeast hot tub water is only 78 degrees turn up to 100 doesn't never get warmer and shows a ECn code
Check your filter cycles and switch spa into Standard Mode as you have it in Economy. (In Economy mode it will only heat during the filter cycles).
If the Ecn or Ec Message is Alternating with the Water Temperature on the Display, the Spa is Operating in the Economy Heating Mode.
If the Ecn or Ec Message is ON Solid (Not Flashing) on the Display, the Spa is Operating in the Economy Heating Mode, but there is No current water temperature because the Spa is between Filter Cycles.
Ecn or Ec is Alternating with Temp:
The Spa is Operating in the "Economy" (Ecn or Ec) Heating Mode.
The Water Temperature is Sampled Only during Programmed Filter Cycles. The Heater will Only operate and Heat up to Set Temperature during the Filter Cycles. The Water Temperature will probably drop Below Set Temperature between Filter Cycles. Other Heating Modes are Standard, Standard in Economy, and Sleep Modes.
Ecn or Ec is ON Solid (Not Flashing):
The Current Water Temperature is "Unknown" (- - - or - -) while in Economy or Sleep Mode.
Between Filter Cycles, while in the Economy or Sleep Heating Modes, the Pump has not turned ON and the Last Water Temperature is not Current. To read the Current Water Temperature, either Change to Standard Heating Mode or turn On the Heating Related Pump, and wait at least 2 Minutes.
Apr 06, 2013 | Washing Machines
On my hot tub control panel Balboa M1 is the code Ec?
Your spa is in Economy Mode:
Ecn or Ec MessageEcn or Ec Message
Mar 13, 2013 | Balboa Instruments Pool & Spa
Hot tub in EC with light flashing
Ecn or Ec Message
Ecn or Ec Message
Dec 23, 2012 | Jacuzzi Balboa R574 System for 1 2 Speed...
I have a Rinnai 1004F, no manual. Vent Contol Button is in open position, its winter, should vent be closed at all? Economy button, whats it for?
Not sure about Vent Control however the Economy button is like a night time set back. Over a 2 hour period it will decrease the temperature up to 6 degrees from set point. In morning, just take off economy and unit will come up to temp. Go to www.rinnai.us for on-line manual.
Nov 28, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
What part do i change when convertin a ranni propane gas to natural gas
I think the part numbers listed in the solution are LPG injectors.The orifices (injectors) needed to change over from Propane (LPG) to Gas (NAT.) would be 2 High Injectors 100F-2031-B-1.80 and one Low Injector 1004F-2036-B-1.95.
Feb 17, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Rinnai 1004F Heating the Outdoors!
Do you have the Economy button on? If so, and you have a large space to heat or the outside temp is very cold the unit may not be able to keep up. If this is the case the stove runs forever, trying to reduce the temp by 2 degrees every 30 minutes. This may not work for your space and outside temp.
Your ideas about the intake and exhaust are not quit right. There is a fan that pulls air from outside over the outside of the exhaust pipe (to preheat it). This fan actually pushed the combustion gasses all the way out the exhaust. The exhaust exiting should be a little hot. In very cold temps, frost can build up around the air intake, which is right around the exhaust pipe. If you see this you will need to keep it clean. It is a good idea to look at the exhaust everyday when it really cold.
Good luck,
Tom Hawkins
Bethel, Alaska
hawkins111@gci.net
Jan 10, 2009 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Rinaai LP space heater will not shut off when set temp is reached
Test the thermistor by using an ice cube. Place the cube on the thermistor and see if the unit starts. Then using a warm towel, wrap the thermistor ans see if it stops. Watch the display to see if it is registering the changes in temp. I suspect a bad thermistor.
Jan 02, 2009 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
1004F Rinnai Gas Heater
I found the manual online... I have the same thing, and had a couple of problems with it. I'll try to paste the link here: http://lib.store.yahoo.net/lib/hectors876/1004om.pdf It's 60 pages, so I wouldn't advise printing it, but save it to your favorites list ;)
~Bethany~
Oct 05, 2008 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Pool & Spa Logo
46 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
