Check temp. in freezer shoud be 0 to -5 Deg. Check condensor if dirty clean some units had a recall on diers cap.tube to far in dier also check for ice on back wall if icedup check defrost heater and defrost timer check evap. fan make sure it's turning.
Hi, Put a thermometer in the freezer and see if it gets down to 0 to 5 above zero. If it is not getting that cold, something is wrong. If you had frost building up behind the rear panel, there is a defrost problem.
Please let me know the temperature and I can assist you further.
I have a woods freezer Woods model v15hds . I just got it out of storage yesterday,. I plugged it in and can hear the motor running and the shleves are cool, but it is not freezing. What could it be
Hi dgh1,
The freezer should stay within 5 degrees of 0 while in operation. While in defrost the freezer may reach as high as 20 to 25 degrees. If any higher temperatures are reached your food will spoil as they are defrosted and refroze everyday. If you find that the temperature is allowing your food to defrost you may want to replace your defrost thermostat. This device is located on top of the evaperator coil inside the back of the freezer. It is made to turn the heater off when a temperature of 55 degrees is reached. One other possible problem could be your defrost timer is taking to long to restart the cooling cycle after defrosting. I hope this will help you and please send any other questions you may have, I am happy to help. and dont forget to rate me.
Mike Anderson
Anderson Appliance
(865)945-3808
i dont think so i would look at the compressor kicking out on thermal overload or a faulty thermostat thermostats have two settings cut in cut out your cut in could be bad and not turning the compressor on till the temp reaches melting temps now if your hearing a click buzz then you need to look at the compressor and make sure the compressor fan is running but its not a defrost promblem
