Question about GE 4 in 1 Grill / Griddle
Wiring diagram for product
It trips circuit breakers when I try to use not sure what the issue is
Where can I get a wiring diagram?
Samorman, sorry, but one cannot answer this question with more info. For example, what type of equipment or structure is this breaker used in or on? There are several conditions that case breaker tripping, but more info is needed to answer your question.
Nov 05, 2015 | Electrical Supplies
Microwave tripping breaker
The microwave may be too big for the circuit it's on. The breaker is tripping to protect the circuit. Try to determine how many appliances/lights/etc are running on this circuit. If there are alot of things, you may try turning some of them off when trying the microwave. If not, then you may have an electrical issue in the wiring or the breaker.
NEVER replace a breaker/fuse with anything larger than what's already in there (recommended by code or a manufacturer).
Feb 15, 2014 | Frigidaire Kenmore Washer Tub to Pump Hose...
White springs spa wiring diagram and troubleshooter
120Volt or 240Volt?
Hardwire or plug-in-outlet?
Where is the GFCI? On the outlet or on the breaker?
Here is a starter:
http://waterheatertimer.org/See-inside-main-breaker-box.html
http://waterheatertimer.org/How-to-wire-GFCI.html
http://waterheatertimer.org/How-to-replace-circuit-breaker.html
Are you connecting a new spa?
Or is old spa having problems?
Exactly which problems?
Or if the element getting wet and causing GFCI to trip?
Is circuit breaker tripped?
Add a comment for live response 11-7-12
Nov 06, 2012 | Pool & Spa
Range made a loud popping noise, shortly after the wife said the analog clock on the range had stopped. when we tried to use the range neither the burners nor the oven would start. upon investigation the...
Matt you did not pass us a model number so how are we supposed ot even begin to look for a diagram. Places to start looking for wiring problems.
1. The terminal board connection inside the range for the input power connection.
2. The terminal connections all 4 burners
3. The terminal connections of the 2 bake elements
Usually when you have a sudden short there was a hot wire and only ONE wire will be obviously damaged.
I have nothing to use to look for a wiring duagram at the moment. Usually there is a wiring diagram in a tech data sheep packet inside the control panel or on the back of the Range near one of the legs taped / glued onto the side wall of the cabinet. The packet will be 3 x 5 or 4 x 6 in size.
If you respond with a model number I will see what I can find as far as a wiring diagrm.
Thanks for choosing FixYa,
Kelly
Sep 02, 2011 | GE Kitchen Ranges
Do you have a wiring diagram for the square d qo250gfi
Any 2-pole GFI breaker typically supplies power to a dedicated balanced load, such as a pool motor or heater. Any load imbalance between either power leg (L1 or L2) and/or the neutral (N) will cause the breaker to trip on ground-fault, ie, it senses more power is going out than is coming back, so it must be leaking out somewhere and the breaker trips.
The load conductors are connected to the breaker under the brass colored screws just like a conventional breaker and the white wire pigtail from the breaker is always connected to the neutral (not bond (green)) buss bar whether the load circuit has a neutral or not. If the load circuit does have a neutral, that white neutral conductor connects to the GFI breaker under the chrome colored screw, else, this screw is left empty.
If you have any questions or hesitations, you really should have this project performed by a licensed electrician. GFCI protection is a life-safety issue and any improper installation defeats this protection.
Jul 20, 2011 | Square D Qo250gfi 2pole 50amp 240v Circuit...
Whirlpool dryer awz121/3 not heating
Based on the information provided above, I am unable to provide a positive solution to your issue. I have provided some common solutions to help guide you in your search.
This information is for an electric, generic model dryer only!
This link, http://www.repairclinic.com/SmartSearch/SmartSearch.aspx, provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again. Just follow the links to navigate through the site.
You will need to enter the model number stamped on the manufacturers product information data tag, located on the unit, and not in the User’s Manual. to access your product information.
Temperature Switch:
Make sure a positive heat selection has been made. Then check these:
Note: A volt-ohm meter is beneficial in performing these electrical tests.
If your dryer doesn't heat, Check:
Power from the house
Heating element
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jul 11, 2008 | Washing Machines
Whirlpool electric dryer keeps tripping main circuit breaker
First off, be sure the pigtail is wired correctly to the back of the unit. Black and red to the outside terminals, white to the middle, green to the frame or cabinet (should be a green screw close-by). If that is ok, you probably have an issue with possibly a bad pigtail, bad outlet, wiring issue, or possibly a bad circuit breaker or breaker box. Probably going to be more of a electrical problem than a appliance problem. Good Luck!!!!
Feb 02, 2008 | Whirlpool LER5636P Electric Dryer
GE 4 in 1 Grill / Griddle Logo
635 people viewed this question
Top GE Grilling Experts
Dan Webster
Dan Webster
paulcarew
Tom Chichester
Are you a GE Grilling Expert? Answer questions, earn points and help others
