Question about Husqvarna Sewing Machines
My husqvarna lily 550 slows down almost to a stop and the I have to keep pressing the pedal in different places to get it to move. What could be the problem
  • Husqvarna Master
  • 665 Answers
IT SOUNDS LIKE YOU NEED SOME WORK DONE ON THE FOOT PEDAL. YOU CAN EITHER REPLACE IT OR HAVE IT WORKED ON.
Posted on Nov 23, 2014
  • 192 Answers
SOURCE: missing a foot pedal
Check with your local Husqvarna Viking dealer. That is what they are there for.
The foot control is a little pricey for that machine, but why would you want to take a risk on cheapening your experience with your machine that you "ADORE" by trying to take the cheap way out in getting a part for it.
Get what you need and continue to "ADORE" your machine.
Posted on Apr 09, 2009
bargainbox
  • 1388 Answers
SOURCE: Husqvarna Lily 530- dont know how to correct tension
Ask your local Husky dealer about availability of manuals.....if no joy, google "Husqvarna Lily 530 manual"
Please TRY the solution BEFORE giving your considered rating.
Specific detail on bobbin case adjustment (with picture) near halfway down reply, the remainder will help you achieve a balance of top and bottom tensions.
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks
bargainbox.com.au
Posted on Aug 23, 2009
  • 980 Answers
SOURCE: I have a Viking Husqvarna and it seems that the
If the winder is not moving either there is a worn part on the winder rubber, or, the winder iteself may have seized up becuae a lot of people do not realise that the spindle has to be oiled because of its high speed.
Posted on Nov 05, 2009
  • 192 Answers
SOURCE: Have Viking Husqvarna #1+ sewing machine that when
Make sure that the bobbin winder stop is up. That is the little black post below the bobbin winder. If it is pressed down, the machine will not run.
Posted on Feb 09, 2010
  • 201 Answers
SOURCE: Husqvarna Sewing machine
The H foot is the Teflon coated foot and it is used when sewing foam, plastic, plastic coated fabrics, leather and imitation leather.
Yes, you can get a darning foot for the Lily. My foot catalogue shows part number 412 54 17-45 and it is called the Darning/Quilting foot. It has a clear oval shaped "foot" and a spring lever which is placed above the needle screw. When I owned a Rose (sister to Lily!) I actually purchased a Brother foot that was exactly (and I mean EXACTLY) the same as this foot for half the price of the Husqvarna one. So if you have a Brother dealer handy, try there.
Posted on Jun 22, 2010
Downloadable lily 550 manual
I suggest you go to the website
LILY 550
and contact them, by email, telephone or letter
May 19, 2016 | Husqvarna Sewing Machines
Change the light bulb on husqvarna lily
use the tool in your accessory box, otherwise take the machine to your authorized Viking dealer and have them put a new bulb in.
Apr 05, 2014 | Husqvarna Lily 540 and 550
Instruction manual
Hello, Here is website for the manuals that you want: Husqvarna sewing machine instruction manuals
Sep 29, 2013 | Husqvarna Lily 540 and 550
Apr 12, 2010 | Husqvarna Lily 540 and 550
I have misplaced the smaller spool holder for my Lily 550 .
Contact your loca authorized Husqvarna Viking dealer. They should have one or be able to order one for you. A list of authorized dealers is available at the Husqvarna Viking website - http://www.husqvarnaviking.com/us
good luck.
3rd party vendors to try:
http://www.pd60.net
http://www.sewingpartsonline.com
Apr 10, 2009 | Husqvarna Lily 540 and 550
Bobbin does not wind all the way up
I have had this problem, easily fixed by twisting the rubber knob that is in contact with the spool to the left.
Feb 08, 2009 | Husqvarna Lily 540 and 550
Husqvarna lily 540
bobbin wound too tight. remove thread first then pull off bobbin.
Jun 02, 2008 | Husqvarna Lily 540 and 550
Machine stops and sews in place
sews only one stitch at a time and have to wait a few seconds before it will do this
Dec 16, 2006 | Husqvarna Lily 540 and 550
Sewing Machines Logo
49 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
