Question about Frigidaire Refrigerators
My frigidaire refrigerator reading cf and water and ice maker do not work.
I unplug refrigerator ,tryed pushing all buttons to reset.
  • Official Brand Answer
  • 2,267 Answers
Good Morning jesse, I appreciate your post!
I see that your Frigidaire refrigerator is displaying an error code of "CF". Normally, "CF" stands for communication failure upon start up. I would recommend performing a reset on your refrigerator and you can do that by disconnecting power from it for ten minutes. If you continue to experience this error code it could be a possible problem with your user interface board or main control panel and I would suggest contacting a technician for proper diagnosis and repair. I hope this information is helpful. -Matt
Posted on Nov 25, 2014
yalmer
  • 549 Answers
SOURCE: Ice Maker
Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Posted on Feb 13, 2008
SOURCE: Kitchen Aid Ice maker Stopped working
I would suggest not buying a KitchenAid. I have the same problem with my ice maker. Have had nothing but problems with every KitchenAid product that I have ever owned. I will never purchase another KitchenAid product.
All of there appliances are second rate. That is "The KitchenAid Difference"
Posted on Feb 18, 2008
The ice maker has stopped working. The red led light blinks when the freezer door is opened. Any thoughts?
Posted on Sep 16, 2008
aasc
  • 1606 Answers
SOURCE: ice maker not dispensing ice
If the dispensor light switches to cubed or crushed , the panel is good . Remove the ice bin , and hold the light switch in . Press the arm for CRUSHED ice , and if you hear a buzzing or hum , then the auger motor is frozen . Use a hair dryer directly on the " forks " for a while , ocasionally holding switch and activating arm , until the forks move . Lower the freezer temp slightly and reinstall the ice bin .
Posted on Aug 30, 2009
kvhappliance
  • 218 Answers
SOURCE: Ice maker makes noise like it is working but turned off
If you want to have a working ice maker it will need to be replaced. You can buy the whole unit part # 1129316 for almost the same price as any of the individual parts. Behind the unit on the back wall is a plug with several wires unplug this plug to disable the icemaker.
If I can be of further assistance please let me know.
Posted on Apr 15, 2010
There is a constant buzzing noise coming from the lower freezer ice maker. It is producing very few ice cubes. The control bar is down and in proper position to make ice.
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.html
Cause of Beeping Noise in Frigidaire Refrigerator eHow
May 21, 2015 | Whirlpool Gold Series GB2SHTXTS (219 cu...
FRS3HR5JB0
Good Morning Friend,
I understand the ice maker is not working in your Frigidaire refrigerator, model# FRS3HR5JB0. I suggest starting by changing the water filter in your refrigerator. You should be changing the water filter about every 6-8 months. If this does not work, I also suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and try getting water out of the dispenser. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 23, 2014 | Frigidaire Refrigerators
Frigidaire SY CF issues
Good Morning Jack, thank you for your question!
Typically error code SY CF indicates that your refrigerator has detected a communication failure after power up. The error code may possibly continue after replacing the part you have ordered. With this error code, a professional would need to check wiring between the main control board and user interface board. After proper diagnoses and if the error continues, the main control board may need replacing. Hope this information helps to some degree!
Dec 27, 2013 | Frigidaire Gallery Series GLHS269ZDB 36"...
Ice marker stopped making ice
There is a test button underneath of the motor side of the ice maker. Unplug your refrigerator for 5 minutes then push the test button on the ice maker if it doesn't move you need an ice maker if it does move and you still don't get any water the metal tube that supplies the water to the ice maker is frozen up and blocking water from coming into the mold.
Nov 07, 2013 | Samsung Refrigerators
The ice maker has stopped making ice.
first check the water supply on the ice maker check inlet water solinoid valve then reset the unit by unplugging power cord after a minutes plug the unit and start ice maker see to it that the compressor running.
Jan 23, 2011 | Frigidaire 20.6 cu. ft. Top Freezer...
My ice maker crushes all of my ice as it comes out the door. Help me - I'm strictly a cube kind of girl!! Cindy ( I've already tried to push the "crush" button and then the "cube" button again. The...
unplug the fridge 2-3 minutes and see if it resets the computor to make the ice control work normally again. You can also open up and get the cubes out cheaper than having it repaired. Sorry about that!
May 06, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
The ice maker
the water does not kick on to flow into ice maker you can still get water from the door
Aug 26, 2008 | Frigidaire FRS3R5EMB Side by Side...
ICE MAKER
See the following fixya thread:
http://www.fixya.com/support/t127529-water_ice_dispenser_not_working
Dec 14, 2007 | GE GSS25JEMWW Side by Side
Refrigerators Logo
158 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
