Question about Fisher and Paykel Washing Machines
Can some one tell me where the earth wires go and the rest of the plugs on a fisher and paykel washing machine mw511
Please help need to no where to plug what like earth and the rest of the wired please help me
    Habit-Forming:
    Scholar:
  • Fisher and P... Expert
  • 142 Answers
The wiring plugs for the controller box are all different sizes and will only go in one place. Each plug location is written next to it on the plastic casing if you look close i.e. RPS, Display, Lid/OOB, Motor, Drain pump etc. The plug on the power lead will go in the place right next to it and just to the right of that is where the earth wires go (green)
Posted on Nov 28, 2014
  • Fisher and P... Master
  • 5,499 Answers
If you are not sure of the wiring contact an electrician!
Connect each wire to the correct terminal. Slacken the screw and push the bare wire into the hole. Re-tighten the screw. Make sure the terminals are tight and that there is no bare wires or loose strands of wire showing. It is often easier to push the pins up slightly when connecting the wires.
  • Brown - Live
  • Blue - Neutral
  • Yellow and green - Earth
Older appliances may have different colours:
  • Red - Live
  • Black - Neutral
  • Green - Earth
Posted on Nov 23, 2014
JULIANFIX
  • 975 Answers
SOURCE: fisher & paykel (mw511)
check out the DRAIN MOTOR PUMP , its a small motor with 2 hoses connected to it , it could be clogged , need to remove it , inspect inside the impellers for any debri , clean it , re install and try again , hope this helpful AJ
Posted on May 20, 2008
SOURCE: Problem with Fisher & Paykel MW511 toploader washing machine
Having the same problem. Any ideas at all? It's really frustrating.
noavatar_s.gif nwesthamz
Rank: Apprentice
Rating: 75%, 1 votes
mw511 fills with water but cylinder isnt spinnig and when it stops filling nothing happens. However sometimes it will go complete cycle ans a noise can be heard on spin cycle even though it is not spinning. As thoiugh the motor is not engaging with the cylinder
Was this helpful? Yes No
Posted on Jul 20, 2009
  • 41 Answers
SOURCE: My fisher and paykel washing machine keeps flashing a fault code
needs a new Rps sensor , 130 is a fualty Rotor postion Sensor
Posted on Jan 31, 2010
  • 3 Answers
SOURCE: fisher & paykel washing machine fault codes
I have a Fisher & Paykel GW609AU Smartdrive Excellence 6.5 Washing Machine that would start then stop then start then stop a few more times before eventually beeping.
I fixed it by bypassing(joined the white and yellow wire) the trip out switch which is located under the control module(one screw to remove).Now it Works.
Posted on Feb 20, 2010
  • 713 Answers
SOURCE: Fisher and Paykel GW612 - Lights showing
Hi just read your posting.The fault on your machine is called Single Rotor Position Sensor Error.The rotor sensor is attached to your motor which is located underneath the machine.Now the Error Code will come up on your machine because 1--The wiring to the Rotor Sensor is faulty. 2-- The rotor sensor itself is faulty or 3--- The motor controller, 'which is located under the top panel is faulty.Unfortunately to test the rotor sensor you need an RPS tester .This device will also check the wiring to the rotor sensor.If you have an electrical test meter I can guide you throe the testing of the wires to the rotor sensor but without the RPS tester you cant accurately test the rotor sensor.Some service techs I know just change the rotor sensor to see if that rectifies the fault but in your case you dont have a rotor sensor so even if you do purchase one and change it, the fault could be your Motor Controller.My best advice to you would be to borrow an electrical test meter if you do not have one and reply back and I can help you eliminate the Wiring as the cause of the fault,and then contact a service tech to find out if the fault is with the Rotor Sensor or the Motor Controller.But if the fault is with the wiring then I can guide you throe step by step to repair it.I hope this helps and please reply on how you got on or if you need further assistance.Good luck.
Posted on Jul 17, 2010
Fisher paykel mw511
take it apart-something has let go in the tub suspension department-springs or bearing-tear it down and it will become apparent-cheers Denny
Oct 28, 2013 | Fisher and Paykel GWL11 Top Load Washer
Fisher & Paykel MW511 error code lights 1 and 7 lighting up and beeping
Error code 130 is rotor position sensor faulty or wiring to it.
sensors sell for $25 to $50 on Ebay.
Jan 28, 2013 | Fisher and Paykel GWL11 Top Load Washer
Washing mashine MW511 top loader was running good but this morning tried to start but it is making a beep beep tone and flashing lights
It is giving out a fault code,
Of the 8 wash progress lights, tell me witch are on,
I will tell you the fault code and info on how to fix.
Jan 29, 2012 | Fisher and Paykel Washing Machines
Hi. I need some info on the fisher and paykel mw511 pride. When I press start the machine beeps and shows the short wash and spin lights. Any ideas?
Hi - I will need the product number found on the sticker in the rear of the machine - the controls has been changed so it needs to be programmed to a 5Kg machine.
I cant help you without that information as there are about 6 methods of doing this, the product number will tell me which is the correct way.
Jun 26, 2011 | Fisher and Paykel Washing Machines
Need replacement motherboard for Model MW511 fisher & Paykel washing machine
Hi just read your posting.Have you try ed Fisher and Paykel local distributor ?What country are you in?If you are in Australia I can help you with phone numbers.Please reply with additional information and I am sure I can help you out.Looking forward to your reply.
May 20, 2011 | Washing Machines
No spinning action on my MW511 Fisher and Paykell Wash Machine. Drains water ok. Then shows small beginning of back/ forth agitation - but not progressing to full spin mode. Warning lights showing...
Hi just read your posting.Now with the error code you have shown it tells me you have an out of balance fault.To find out if the fault is with the out of balance switch or the motor controller you will need an electrical test meter. the reason for this is to test the switch for conductivity,not to test for power or anything dangerous.Have you or can you borrow an electrical test meter to test the switch?please reply and I can guide you throe the repair of this fault.
Jun 14, 2010 | Fisher and Paykel GWL11 Top Load Washer
My MW511 model is not spinning , slow motion wash cycles, noisy
Hi blow down the hose that the waste water comes out of, it may be blocked
Nov 29, 2009 | Fisher and Paykel (IWL12)
Rank: Apprentice
Jan 12, 2008 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
marley mcelhinney
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
