Question about Canon iR 1600 Copier
What should i do my canon ir 1600 control pad is not displaying but its running and warming up?
Have removed a pram and inset it
    New Friend:
  • 34 Answers
Sounds like the LED display has gone out. if so it must be replaced.
Posted on Nov 25, 2014
  • 121 Answers
SOURCE: Canon IR 1600 Error message E000
You'll need to replace the fuser unit. Not exactly the cheapest part of the machine...
Unless, that it, you were taking things apart and happened to unplug something accidentally. If you take the cover off where the paper comes out, look at the connectors directly inside there under the black piece of paper that you'll see. If one of those are pulled out, it could cause the problem.
Otherwise you need to replace the fuser unit.
Erice
Posted on Nov 23, 2007
color_50
  • 22 Answers
SOURCE: Canon IRC3200 says printer warming up but does not
How old are the Drums ? Also check & Remove the Delivery Vertical Path Unit on the left side of the machine. You will see a photo sensor PS5 Fixing Feeder Unit Open/Close Sensor sandwiched between two microsensors that actuate when closing the Fixing Feeder Unit. Clean that photo sensor as it fills up with dirt and dust
Posted on Aug 12, 2009
canontech
  • 1219 Answers
SOURCE: my copier is canon ir 1600 and it have system error
wich system error?Is it 001, E100, E019?
Posted on Feb 25, 2010
john504
  • 31 Answers
SOURCE: canon IR C-4580 with Fiery controller
No, but the fiery will just speed up your prints etc.. I have the c3380 and c5185, they are stand alone with no fiery. If you are buying this machine for office coping it will be fine. But remember! this is a Buisness Color machine. In my customer base the 80's have done well as long as you run them as an color machine and not the office black and white work hourse. The color prints are great without any help from fiery. Sales people will try to sell you all!!!!
Posted on May 10, 2010
SOURCE: iR 1600 photocopier display INSTALL CARTRIDGE
Check the developer unit contacts , and the magnetic roller contact.
Posted on Oct 02, 2012
IR 1600 photocopier display INSTALL CARTRIDGE
Oct 02, 2012 | Canon imageRUNNER 1600 Laser Printer
DEAR I AM FACING PROBLEM IN IR2000 ROM ERROR SO I NEED FIRMWARE FOR THIS MODEL OR GIVE ME A SOLUTION. THANKS
When the ROM Error message is displayed on the control panel, this will indicate an issue with the Flash DIMM on the Image Processor PCB.
re-flash the system software/or replace the DIMM Assembly.
When replacing the DIMM, you may be required to flash the system software to it's latest version.
iR 1600/2000 FG6-9978-000, Dimm assembly.
As a temporary work around, power on the iR while holding down the STOP key. This may boot the iR to a ready state and copies can be made.
Service Mode=Additional Functions #
Aug 05, 2010 | Canon iR 1600 Laser Photo Printer
Canon IR 1600 the code display 000
Main motor malfunction error.Remove the fuser unitmand rotate manually to see to work easy,if not the problem in this unit(change the bearings or gears).Rotate the transfer unit and developer unit manually.If worked is OK.Open the front door turn OFF the power switch,wait 3 sec.turn ON and closed the front door.
Aug 20, 2009 | Canon Office Equipment & Supplies
Error code E677
677 error is printer board error.u check conection( lpt port or usb cable loose conection.printer board loose conection.remove all conection and conect all conection i mean reinsert conection ) then this error come u will service u r printer board(re insolve printer softwere).803 error is expouser lamp end side blocked change u r lamp u r 803 problem is ok
Jun 01, 2009 | Canon iR 1600 Laser Photo Printer
No tengo el manual de la iR 1600-2000
http://software.canon-europe.com/products/0000705.asp
May 05, 2009 | Canon ImageRunner 1600 Copier
How to set
Find your printer on the Canon website and download a manual for instructions.
http://www.usa.canon.com/consumer/controller?act=SupportIndexAct
Feb 15, 2009 | Canon iR 1600 Laser Photo Printer
Canon ir 3300 xerox machine display board not working
dispaly and pad is not working who to open it tell me the codes
Feb 13, 2009 | Canon Office Equipment & Supplies
Copier canon ir 1600
Problem with fixing Unit, simple simulation will help. otherwise need to change fixing unit,, contact ur service engineer
Nov 03, 2007 | Canon imageCLASS D860 All-In-One Laser...
Canon iR 1600 Copier Logo
48 people viewed this question
old marine
old marine
