Question about Bosch 24 in. SGS43C02 Classixx Built-in Dishwasher
What dose check water meeans
Just started the programe
  • 366 Answers
It means it cant feel if any water is entering the machine. either due to the water being turned off somewhere , the inlet hose not connected or the inlet flow sensor has failed
Posted on Nov 23, 2014
Pasquini Livia 90 Auto Dose Panel
First, I'm not a Pasquini tech, but I have worked on several similar brands.
* Most Semi-automatic machines will usually have the program button on the same as the stop button. Some will program all the groups at once or can be individually set up for different pours (shots)
* Holding down the program or stop button for 5-10 seconds will activate the program mode. Note that if you don't press any dosing buttons after 5-10 seconds the program mode will revert to normal mode. Some may cancel out the previous dose set up.
* Before starting, determine what you want a shot to look like. 1 oz, 1.5 oz, 2 oz., etc.
* Set up your portafilter with ground coffee. DONOT change the grind size once your satisfied with the QUALITY of pour (don't confuse this with the amount of the dose. This is handled with the programing of dose water.) Water is absorbed by the grounds depending on the grind size and some times the amount. Pods are different from loose ground coffee too.
* Load up portafilter and place measuring cup(s) under spout(s).
* Press program button and hold for 5-10 seconds. The button will light and stay on (some blink).
* Press the dose button for the appropriate portafilter you have mounted. The pasquini requires you to press the stop/program button once you have achived the desired dose. Other brands require the dose button to be press and held down until the amount of dose water is reached. Letting go button logs the amount in but only after pressing the stop button does it set.
* For other brands, you may need to set up all buttons prior to pressing the program/stop button to confirm dosing of all buttons.
* Remember to keep reloading fresh coffee grounds in the portafilter for each adjustment. Used (wet) coffee will throw out the water dose calibration.
Aloha, ukeboy57
PS; I found a good video from Whole Latte Love site:
https://www.youtube.com/watch?v=1NGN55nYBxQ
Mar 11, 2018 | Pasquini Coffee Makers & Espresso Machines
Semi automatic espresso machine shot won't stop pouring
Continuous water flow indicates a stuck valve. These suggestions may help depending on type of machine:
Full Automatic (Super Automatic); Valve needs back flushing, cleaning, or replacement. There is an off chance the dose needs re-programing.
Semi-Automatic; Valve needs back flushing, cleaning, or replacement. Check programing for dose.
Manual; Most manual espresso machines require operator to stop dose. (By releasing dose button or lever)
Arm style Manual "Jaw Breaker"; These are physically chambered dose which are unable to constant dose. Bad seals needs replacement (if you can still find them)
final comment to this 'open' question; All coffee machines needs periodic cleaning. Most espresso machines needs back flushing (not to be confused with de-scaling.) Usually a cleaning tablet or powder is poured into dose chamber (or back flush portafilter) and cleaning cycle or long dose is performed. This cleaner will loosen baked in coffee and push it out the pressure relief pipe. The machine will need to go into a normal dose cycle without coffee to flush the cleaner out of the valve and dosing system. Do this several times. Good daily cleaning habits will keep your machine in top condition.
Sep 30, 2017 | Coffee Makers & Espresso Machines
Why dont my Nuova simonelli Musica pour when pressing the Continuous coffee dispensing button? The button flashes.
have you tried programming the doses, maybe your continuous dose is not programmed. if you did, botton switch damaged need to replace whole touch board
Jun 22, 2014 | Nuova Simonelli Musica Espresso Machine
Zanussi jetsystem ZJD-12191 TURBODRY washer dryer drum will not turn
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Test a pressure switch: Click on : http://www.youtube.com/watch?v=HZZ2bDMspj8
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Jan 22, 2013 | Washing Machines
The water is getting cloudy and the sides of the pool are slimy
If your pool water is clowdy and slimy then it is about to turn green. What you need to do first is shock the pool to recommended dose to start killing the algae.
The most common error users make in managing a salt water pool besides not having salt in the pool has no stabilizer in it. This is a chemical that has an affinity for chlorine ions and if it is not there the chlorine can be disipated in a few hours when the sun hits it. Another name for it is Cyanuric Acid. It can be purchased in granular form at many pool supply stores or in a liquid form at Leslies. In order to get your pool blue you need to have the chemistry checked at a pool store or with a test kit (either liquid or strips). Don't buy everything a pool supply tells you to buy but start out with vinyl safe shock, stabilizer and salt. The pool store should be able to help you determine the dose. The following is what I would do:
1. Make sure salt is at the recommended concentration.
2. Shock the pool to recommended dose to start killing the algae.
3. Place the recomended dose of stabilizer in the pool.
4. Make sure pump and filter are working properly.
5. Check the pool chemistry on a daily basis until it is ready for swimming.
6. Check the chemistry on a weekly basis and clean the pool and equipment according to the pool instructions.
Smile, you are a pool manager.
Jul 05, 2011 | Intex Automatic Salt Water System for ...
My bosh exxcel disher dose dot fill
Hi
Thanks for using FixYa. To start with check the water inlet valve which is located behind the lower access panel on the left or right side of the Dishwasher. If the water inlet valve is bad you have to replace it, also check the main water line for clogs/obstructions. If still the issue is not resolved then it’s a bad float switch and needs to be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 03, 2010 | Dishwashers
Fills water goes through program drum dose not
Remove the motor, and check the brushes in the motor, if o/k, then could be a board prob, or something as simple as a broken or bad connection.
Pleasre rate my solution.
Thanks.
Oct 10, 2009 | Hotpoint WMA46 Front Load Washer
No water coming through but steamer working
Check the shower screen it might be clogged.
Aug 11, 2009 | Gaggia Baby Espresso Machine
Bosch 24 in. SGS43C02 Classixx Built-in Dishwasher Logo
53 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
