Question about Ricoh Aficio MP2352 Copier
How to Remove error code SC865
I have tried to remove but still have the problem
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Ricoh Master
  • 884 Answers
Hi there
I managed to find a list of Ricoh error codes with brief explanations of their causes here:
Ricoh copiers error code messages
It details the SC86? as hard disk or disk controller problems with SC865 being specifically the hard disk. I therefore doubt if you will be able to get rid of this fault without replacing at least the hard disk and possible the disk controller board as well.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Posted on Nov 23, 2014
Ricoh c6501 sp error coad sc 925 solution
SC925 B Net File function error *GW The NetFile file management on the HDD cannot be used, or a NetFile management file is corrupted and operation cannot continue. The HDDs are defective and they cannot be debugged or partitioned, so the Scan Router functions (delivery of received faxes, document capture, etc.), Web services, and other network functions cannot be used.
HDD status codes are displayed below the SC code: • Refer to the four procedures below (Recovery from SC 925). Here is a list of HDD status codes:
Display Meaning (-1) HDD not connected (-2) HDD not ready (-3) No label (-4) Partition type incorrect (-5) Error returned during label read or check (-6) Error returned during label read or check (-7) "filesystem" repair failed (-8) "filesystem" mount failed (-9) Drive does not answer command (-10) Internal kernel error (-11) Size of drive is too small (-12) Specified partition does not exist (-13) Device file does not exist
Procedure 1
If the machine shows SC codes for HDD errors (SC860 to SC865) with SC 925, do the recovery procedures for SC860 to SC865.
Procedure 2
  1. If the machine does not show one of the five HDD errors (SC860 to SC865), turn the machine power off and on.
  2. If this is not the solution for the problem, then initialize the NetFile partition on the HDD with SP5832-11 (HDD Formatting - Ridoc I/F).
    NetFiles: These are jobs printed from the document server using a PC and DeskTopBinder. Before you initialize the NetFile partition on the HDD, tell the customer:
    • Received faxes on the delivery server will be erased
    • All captured documents will be erased
    • DeskTopBinder/Print Job Manager/Desk Top Editor job history will be erased
    • Documents on the document server, and scanned documents, will not be erased.
    • The first time that the network gets access to the machine, the management information must be configured again (this will use a lot of time).
  3. Before you initialize the Netfile partition with SP5832-11, do these steps:
  4. Go into the User Tools mode and do "Delivery Settings" to print all received fax documents that are scheduled for delivery. Then erase them.
  5. In the User Tools mode, do Document Management> Batch Delete Transfer Documents.
  6. Do SP5832-11, then turn the machine power off and on.
Procedure 3
  1. If "Procedure 2" is not the solution for the problem, do SP5832-1 (HDD Formatting - All)
  2. Cycle the machine off/on.
Apr 12, 2016 | Ricoh Office Equipment & Supplies
Solution for aficio mp 2352sp error code sc865
Address book data error,
clear ucs settings under mode option in service mode and if still error coming then format HDD,by taking backup
Feb 11, 2015 | Ricoh Aficio MP2352 Copier
Sp5200dn
check Hard drive connections,
format HD.
replace HD is this doesn't work.
Feb 14, 2014 | Ricoh Aficio Office Equipment & Supplies
Ricoh 3045 sc865-01 , any solutions ?
In general the SC 860-900 refer to HD acces error.
SC 865 - the hard disk detected an error.Error detected other that the bad sectors error SC 863 or the CRC error SC 864.Reset the error code by turn the operation switch and main power switch OFF and ON.Try disconnect and reconnect the hard disc connectors and verify the cable.
Feb 20, 2013 | Ricoh Aficio 3045 Digital Copier: 45cpm....
Richo Aficio 3035 shows error SC865-01 What do I do?
the problem is with a electronic board, so nothing can be done by the used, the specific board need to be replaced.
Jan 14, 2013 | Ricoh Aficio 3045, 3035 Kit
MPC 2550. What is error code sc 865 01?
SC865 (HDD access error) is displayed when the power is turned ON, and SC819 (kernel stopped) is displayed when the power is turned OFF and ON.
Some broken files may be left in the HDD image disk space.
Repair by initializing the HDD image disk space (SP5-832-002).
Dec 17, 2012 | Ricoh Office Equipment & Supplies
ERROR CODE sc865-01, TRIED CALLING TECH SUPPORT BUT HOLD TIME WAS FOREVER & CLOSEST TECH IS 4HRS AWAY WE HAVE ONLY ONE MULTIPURPOST SO WE ARE COMPLETLELY DOWN
Your message is not clear because you have not told us what type of machine you are having problems with.
As far as I can tell it is a Ricoh copier. First of all I would suggest turning off the machine, leaving it for 5 minutes and then restarting it. Sometimes it is just a sensor which is throwing a fit! Next I would check the toner level and the waste toner bottle. Finally check that the paper pathways are clear.
These are just commonsense suggestions and I apologise if you have already tried these.
Further research on the internet shows that it may be a hard drive error, if you can locate the hard drive -with the power off - check all the connections. If you still have no luck then you may need to format the drives
http://www.copytechnet.com/forums/ricoh-savin-gestetner/12877-ricoh-aficio-mp-c4500-error.html
Hope this helps
Feb 28, 2011 | Office Equipment & Supplies
Error code E020 0181 on oce cs115 how do we remove the code
Hello sir; Try to replace yellow color developer and then running"stir" or "install". should removed the error code.
Oct 09, 2009 | OCE Office Equipment & Supplies
Gestetner DSM627 Service Code Problem
These SC errors are related to the Hard disk.
Re - enter SP mode: Clear, 107 and press and hold Stop button for 3 secs.
Enter SP 5832-008 and press #,(Mail Tx data) to initialize the HDD. Then switch off and on the machine.
If still with error, replace the HDD.
Attention not to change any others SP modes - very sensitive settings!
Good luck and please rate me, thanks.
Feb 18, 2009 | Gestetner DSm627sp All-In-One Laser...
Ricoh Aficio MP2352 Copier Logo
198 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
