Question about Microwave Ovens
GW397LXub05 bake button n numbers won't work. Replaced circuit/switch board and membrane. Now only bake button wont work.
  • Microwave Ovens Master
  • 3,382 Answers
When you reassembled I hope were you careful to put it together correctly, that nothing was bent and everything was clean.
Posted on Nov 27, 2014
  • sherwin Nov 27, 2014
    Unplugged, cleaned n put together everything correctly.
  • 2,355 Answers
Check ur element. Make sure it is securely attached and in good shape.
Posted on Nov 26, 2014
  • 1 more comment
    Going to check element Friday when I get back home n posy update.
    Going to check element Friday when I get back home n post update.
  • sherwin Dec 04, 2014
    Took range out and took it apart. Checked all connectors, wires, etc. Only bake button wont work. Put the old membrane on and not only bake but a few more buttons didnt work. Called the place I bought the membrane from n they said they will send me another membrane for free. I'll try that and update.
My start button of microwave suddenly stopped working only its stop button works.What can I do?
You could have a defective door switch. Or, a bad membrane switch on the touch pad. Or, the ribbon cable (if so equipped) between the touch pad and circuit board might not be making connections on all of its wires.
Sep 14, 2016 | Microwave Ovens
Kitchenaid microwave KBMC140HH03
If you wish to get some details about microwave oven repair then check the following link
http://electro-medical.blogspot.com/
Aug 16, 2016 | KitchenAid Microwave Ovens
The kitchen timer button does not work on my Kenmore circular wave microwave.
If it has membrane switches, you might have a bad switch. Or, you could have a bad connection between the touch panel and the circuit board. Or the circuit board itself could have a problem.
Jul 25, 2016 | Kenmore Microwave Ovens
Built in microwave counter top lights not working
Did you replace bulb yourself if so it may look a good bulb with filament complete but if you have touched the glass part of bulb with your fingers it can knacker the bulb.
Also the switch membrane panel traces the circuit from both the switch membrane and the lighting circuit to the power circuit board. So, I know that both the lights and the switch membrane have a common terminus on the power circuit board. Since the circuits from both sources lead to a common point,
Apr 06, 2016 | In Microwave Ovens
Jnm1731dm1bb
For model JNM1731DM1BB, there's no reset. Your membrane keypad is failing and has to be replaced.
On this model, the membrane keypad is not available as a separate part, so you would have to order the control panel frame assembly which comes with a new keypad.
In this case, you simply move your circuit board into the new frame. That is a simple do-it-yourself job.
It is part number WB07X11033 and you can order it from the Pros here for $148.66 (subject to change).
You can find helpful exploded view diagrams and order other parts at that link, too.
There is a video here showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you unplug the keypad (as per the photo below) and move your circuit board into the new frame.
Be careful, the display is made of glass.
Oct 26, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
JT980 trivection double wall oven, some buttons are not working
If the control circuit board is clean with no signs of grease or moisture deposits, it's almost always the membrane keypad.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
You can download GE owner's manuals and installation instructions here.
Jan 09, 2013 | GE Profile JT980 30" Built-In Double Wall...
We cannot set clock on mirowave model wmh1163xvb
Your actual model number from the tag on the oven will be WMH1163XVB0, WMH1163XVB1, or WMH1163XVB2.
You have a failed membrane keypad.
On these models, the membrane keypad is not available as a separate part, so you would have to order the control panel frame assembly which comes with a new keypad.
Here are the part numbers, depending on color:
Panel Assy, Control - Includes Lens and Membrane Switch
part number color
W10315771 Black
W10315772 White
W10315773 Stainless
W10315775 Universal Silver
You can find helpful exploded view diagrams and order parts by entering the part number or your full model number from the tag on the oven here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you unplug the keypad (as per the photo below) and move the circuit board into your frame.
Some connectors on the relays may have a lock:
May 23, 2011 | Whirlpool Microwave Ovens
Frigidaire microwave model fmv152ksa Some of the buttons on the console do not work. The number 5 does not work (if I hit timer & any other #, the # will show up, but 5 will not show up) the clock on...
If you're saying that some digits or segments on the display do not light up, then I would first suspect grease or moisture on the control circuit board.
If it's just that some pads on the keypad will not respond, I would say your membrane keypad is failing.
I would first give it a "hard reset" by unplugging it for 2 minutes, then trying it again.
If it still fails, I would remove the control panel assembly (see the disassembly video here) and inspect the circuit board for green, gray, or white residue or grease.
The membrane keypad is not available as a separate part, but comes already installed on a new control panel frame, which is part number 5304464130 which you can order from the Pros here.
To replace that, you unplug the keypad (as per the photo below) and move your circuit board into your frame.
If you need more help, feel free to contact us directly.
Jan 27, 2011 | Frigidaire FMV152K Microwave Oven
Microwave oven push buttons not working no sound not functioning
You have a failing membrane keypad.
It is part number WB07X10950 and you can get it here for $89.59 (compared to over $135 from from GE!).
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Oct 07, 2009 | GE JES738 Microwave Oven
Kenmore microwave model number 401.80084700 Displaying -SE-/-5E-
-SE- error means you have a shorted membrane keypad.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and of course one should never leave a microwave unattended while cooking.
There are three ways you can get it fixed:
DE34-00178X SWITCH MEMBRANE $20.30
ref#53 membrane keypad
take yours off as in the video at our site, peel the old keypad off as in this handy guide with pictures , clean the surface, stick on the new keypad
order by part number here
(We can do this job for you for a total of $70.25, but as you can see, the other two options are more practical and economical)
DE94-01647A ASY CONTROL PANEL $39.01
ref#66 control panel frame with keypad
take yours off as in the video at our site, disconnect the keypad strip as shown here, move your circuit board to the new frame, reinstall
DE94-01648A ASY CONTROL, BOX $58.12
ref#59 complete control panel assembly with frame, keypad and circuit board
take yours off as in the video at our site, then install the new one
If these parts are not in stock, they should be available in about a week or so.
Aug 06, 2009 | Kenmore Microwave Ovens
Microwave Ovens Logo
32 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
