Question about Car Audio & Video
I have a Power Acoustik 1000 watt amp and 2 Alpine type r 12 s SWR-1221D what's the best way to hook up 2 omg or 4 omh
    Problem Solver:
  • 7 Answers
USE WHICHEVER THE DRIVERS ARE RATED FOR
Posted on Nov 28, 2014
2 Suggested Answers
dj_relly999
  • 4070 Answers
SOURCE: HELLO i have 2 12"
Hi! Theres no problem if it's 1 is to 1. Just remember not to overdrive the amp for it may damage the speakers. Hope this helps and thank you for using FixYa!
Posted on Sep 01, 2010
What amp would be better to use with what speakers/sub? I have a KAC-7202 kenwood 920W maximum power (150wX2 RMS, 4ohms) (230wX2 RMS 2ohms) and then the other amp I have is a Alpine MRP-M500 mono power...
I'm using that Alpine right now for 2-12" subs and I have compared it to 6 or 7 other amps this month and most were 4 channel 150Watt/Channel Bridged to 300Watts x 2 and found the Alpine to be superior in both sound quality and loudness. The Alpine has also not turned off even with full volume for hours at a time, Very solid amp I was very surprised due to it's size!
Apr 04, 2013 | Kenwood Car Audio & Video
I have one alpine type R 12 SWR-12D4 1000 watts rms-3000 watts peak, and I have it hooked up to the Alpine MRP-M500 mono power amp (500w RMS+1 at 2 ohms and 300w RMS+2 at 4 ohms) I have all great...
I usually run an extra pair of RCA's when I do an install. This way if you have a problem with one you're already set or if you upgrade you won't have to tare you car apart again.
Apr 03, 2013 | Alpine MRP-M350 Car Audio Amplifier
What is the best amp for one 15" alpine type r?
sub spec 250watts per coil you should be just fine I have 2 typr 15s on orion hcca 2500 1 and it kicks a$$ thats 1000 watts over the rated limits of the subs only shut the amp down once these subs can take a lot more power than they say just use your common sence with the volume and gain levels
Jan 31, 2012 | Alpine Type-R SWR-1242D Car Subwoofer
What is the best way to connect two 4 ohm type-r
Connecting the speakers in parallel is the best route here. Parallel wiring is simply connecting the positive wires together and connecting the negative wires together. Then connect both positive wires to the positive output of the amp and both negative wires to the negative output of the amp. When both 4ohm speaker are connected in parallel the combined impedance is 2ohms. This particular amplifier has a damping ratio of >250 at 2 ohms compared to a damping ratio of >1000 if you connected them in series at 8 ohms. the damping ratio is simply the reduction of power transferred. (For future reference in order to get the maximum power transfer input impedance must match the output impedance.)
Jul 24, 2010 | Alpine Type-R SWR-1242D Car Subwoofer
Can you hook up two 12 inch subs to a 1000 watt amp?
need more info well you need to look at the subwoofer and see how many watts it can take and if it 2 ohm or 4 ohms single or dual voice coils and on your amp is it mono or 2 channel and what is the omhs for it
Mar 11, 2010 | Alpine SWS-1223D Car Speaker
Amp for 12" Alpine Type R DVC 4ohm
i actually have 2 12" type s's and i did the same thing just wanted a cheap amp... i went on ebay and bought a pyramid 1600 super blue series amp..... its 1600 watts and ive also hooked it up to type r's and it POUNDS!!! ill copy and paste the website where i got mine from on ebay... if you tune it right it'll make it so you cant breathe inside your car......http://cgi.ebay.com/NEW-1600-WATT-PYRAMID-PB559X-Car-Audio-Amp-Amplifier_W0QQitemZ350169009069QQcmdZViewItemQQptZCar_Amplifiers?hash=item5187b30bad
Nov 11, 2009 | Alpine Car Audio & Video
I just wired my alpine type 12 4 ohm subwoofer to two ohms by putting the two red runners in the positive terminal and the two black runners to the black terminal and hooked the wires up to the outside...
If you have the Alpine SWR-1222D, that's a dual 2 OHM Sub. So, the way you have it hooked up to the amp ,it's 1 Ohm, and unless your amp can safely operate at 1 OHM, you are better off connecting the voice coils in series so the amp will see 4 OHMS. The link below will show how the connections are made to the amp. Look at example # 1.
http://akamaipix.crutchfield.com/Manuals/500/500SWR1242.PDF
Hope this helps!
Aug 19, 2009 | Alpine SWR-1222D 12" Type-R Series...
What size enclosure (sealed)for Alpine 12"1242D(METAL Music)
  • 12" subwoofer with dual 4-ohm voice coils
  • Kevlar reinforced pulp cone with Santoprene™ rubber surround
  • cast aluminum frame with perimeter venting
  • frequency response: 25-500 Hz
  • power handling: 200-500 watts RMS (250 watts per coil)
  • peak power: 1,500 watts
  • sensitivity: 85 dB
  • top-mount depth: 7-5/8"
  • sealed box volume: 0.57-1.0 cu. ft.
  • ported box volume: 0.75-2.0 cu. ft.
  • For rock, i actually have 2 seperate 12's in slot port boxes i built facing forward. Facing forward reduces a little resonance and spl, but keeps alot of that annoying rattle off your tag lol
    Hope this helps :)
    Dec 10, 2008 | Alpine Type-R SWR-1242D Car Subwoofer
    Need to know
    I'm assuming that you have an amp that you are installing these to. Its always tricky installing subs of different impedances. Do you have the model number of the amp that you are hooking them up to.
    Most likely if you have a 2 channel amp, you would connect one sub to each channel as most amps can handle a 2ohm load in stereo, but don't bridge the amp with these two subwoofers without specific instruction from someone with experience as you will most likely overlad the amp. If you can be more specific with your set-up I'd be able to assist you more.
    Mar 30, 2008 | Alpine Type-R SWR-1042D Car Subwoofer
    Car Audio & Video Logo
    61 people viewed this question
    Top Car Audio & Video Experts
    xxxxxx xxx
    Are you a Car Audio and Video Expert? Answer questions, earn points and help others
