Question about 1995 - 1998 Mitsubishi Eclipse Exhaust Muffler Kit 15691 M
Automatic gear box in a 1995 magna
When im comming to a stop my gear box shunts into a low gear
  • MagnaFlow Master
  • 987 Answers
Delay shifting can be caused by low tranny fluid, and or late response from a shift solenoid or TPS throttle position sensor or high RPM
Posted on Jan 22, 2015
Vf750 honda idles but dies when throttle opened
Hi, Anonymous and the usual suspects are:
1. Idle port, transfer ports, slow air jet clogged.
2. Idle adjusting screw set too low.
3. Air fuel mixture adjustment too lean.
4. Pilot/slow fuel jet clogged.
5. Faulty accelerator pump.
6. Float level too low.
7. Float bowl contaminated old fuel, water, dirt, rust, etc.
8. Carburetor bowl vent line clogged/blocked/pinched.
9. Fuel line to carburetor kinked or pinched.
10. Fuel filter clogged.
11. Intake manifold leak.
12. The gas cap is not venting properly or fuel tank venting system blocked.
13. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
14. Needle and seat stuck closed in the float bowl.
15. Multi carburetors not in sync.
16. Faulty fuel pump.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Starts choke but dies with little throttle
1984 VF700 Magna starts but won take throttle
Honda Magna VF750C Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda 1995 VF750C Magna Owner Manual
Jun 14, 2014 | 1995 Honda VF 750 C Magna
I have a 99 2.4l alero and when im in drive and when i stop at a stop light or stop sign its like a hard vibration coming from the motor like it wants to die and when its in neutral or whend its really...
Have you at all serviced the automatic gear box? one possibility is the gear box.Also the vibration is either broken gear box or engine mountings broken or weak.
Sep 15, 2012 | 1999 Oldsmobile Alero
2003 Honda VF 750 C Magna will not idle
Hi, Roy and the usual suspects are:
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Vacuum line from the petcock to intake manifold cracked.
5. Float needle and seat sticking.
7. Carburetor bowl vent line clogged/blocked/pinched.
8. Idle adjusting screw set too low.
9. Air/fuel mixture screw set too lean.
10. Idle port, transfer ports, slow air jet clogged.
11. Slow fuel jet clogged.
12. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need please Click on the blue links below. Good luck and have a wonderful day.
Not used to V4 carbs Advice
http://www.magnaownersoftexas.com/forums/index.php?topic=5371.0
May 25, 2012 | 2003 Honda VF 750 C Magna
1994 honda magna 750 will not accelerate
1. Faulty wiring to any safety switch.
2. Safety switches loose at the mounting point.
3. Faulty kickstand safety switch.
4. Failed kickstand safety switch circuit diode.
5. Stretched side stand spring.
6. Side stand not coming up far enough to disengage switch.
7. Faulty clutch lever safety switch.
8. Faulty neutral safety switch.
9. Clutch not properly adjusted.
10. Clutch plates sticking, forward lurch
For more information about your question and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
V45 Magna Stalls when clutch is out bike in gear
motorcycle stalls when put into gear
Apr 11, 2012 | 1994 Honda VF 750 C Magna
1995 manga right side engine case bolt torque specs
Hi, Fastgun9mm for this scenario you will need your service/owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Honda Magna VF750C Service Manual http://www.partsfish.com/page/oem-parts-for-honda
1995 Honda VF750C Magna Motorcycle Specs
Honda Magna Wikipedia
May 24, 2011 | 1995 Honda VF 750 C Magna
How to change air filter on honda 750 magna 1995 model
Hi, Mbboboian for this scenario you will need your service/owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Replace Air Filter
1996 Honda Magna Carb removal flv
Oct 18, 2010 | 1995 Honda VF 750 C Magna
Auto box not selecting gears
get a replacement automatic transmission or have your unit reconditioned
May 05, 2009 | Mitsubishi Lancer Cars & Trucks
Transmission won't shift from low gear .
Check you transmission fluid if its thin theres your issue if not it could be your bands or your torque converter.
Mar 19, 2009 | 1995 Geo Tracker
1995 - 1998 Mitsubishi Eclipse Exhaust Muffler Kit 15691 M Logo
71 people viewed this question
Top MagnaFlow Vehicle Parts & Accessories Experts
Johnathan Lence
Johnathan Lence
Dan Horsefield
Dan Horsefield
ray gallant
Are you a MagnaFlow Vehicle Part and Accessory Expert? Answer questions, earn points and help others
