SOURCE: I have a Brother SE-270D
its the problem of the timing belt in your machine its extra loosen or extra tightned or is slightly came out of its position or finally broken.
as the machine is proper just missing the proper speed as it should be .
it is running continuosly as you stated.
check the timing belt and make it proper if its worn out and needs replacement this is how its done
There is an adjusting screw on the right side of the machine head. Follow the motor bracket to the machine head and loosen that big old screw or bolt which will raise or lower the motor giving you slack to remove or replace the belt.
feel free for further queries
thanks
SOURCE: thread jams & wheel axel cannot turn
there are a couple of things that come to mind.
Bobbin: wound with uneven tension. Try taking the bobbin, rewind that thread onto another bobbin and wind slowly. make sure the thread feeds onto the new bobbin evenly.
upper thread: catching on something or not flowing off the spool easily.
you're doing well, sounds like you consulted the manual and used your noggin, hang in there and let me know if this doesn't help. we can troubleshoot some more!
SOURCE: on a babylock elegante the bobbin thread shows,
Have you reset the tensions for this machine, look in your manual and follow directions. If this is an Elegante there is also a set of instructions on the machine. On the LCD screen there is a picture of a sewing machine with a question mark, touch it, find Troubleshooting and touch that then find the problem you are having and read. If this does not help take it to a Brother dealer and have it reset so as to keep you machine in good running order.
SOURCE: I have a Viking Husqvarna and it seems that the
If the winder is not moving either there is a worn part on the winder rubber, or, the winder iteself may have seized up becuae a lot of people do not realise that the spindle has to be oiled because of its high speed.
