Question about Schumacher XP500 Jump Starter
I charged my schumacher 6 in 1 booster all of a sudden display reads f00
Turn on push battery level display doesn't change
5 Suggested Answers
  • 509 Answers
SOURCE: I borrowed a friends and don't know how to read
the meter goes down as it's charging.
Posted on Jan 03, 2010
SOURCE: schumacher SC7500A DOES NOT WORK
Check the fuse.
Posted on Feb 07, 2010
SOURCE: Issues with Schumacher Battery Charger SE-82-6 -
I have the same one. The black wire from teh ac cord has a white connector that goes on the switch but there are 4 choices. I need a diagram as well.
Posted on Mar 14, 2011
  • 4 Answers
SOURCE: i have a schumacher se-82-6,i
If you look at the meter, the charge meter of 100% is slightly above the 2 amp mark so it is confusing. because it says the charge represents the amont charged and the amp meter shows when there is no draw on the charger. so if the battery shows 2.5 amp on the amp meter, it's showing 100% charged. but yet they say it should go to zero on the amp meter, which would mean about 150% charged. i think everyone is scared of blowing up or damaging their batteries because the instructions manual is quite contradictory and confusing. well apparantly, they have several versions of this model to make it more confusing, but here's a pic of what i have.
http://www.northerntool.com/images/product/zoom_images/1677820.jpg
ok, as i was looking for manual online, it is more detailed than the one in box. it now explains this in picture detail. thank you schumacher.
here's the updated manual:
http://www.batterysales.com/downloads/SE-82-6.pdf
hope this helps.
Posted on Jan 23, 2012
I have an error code of FOO ?
Joseph, No F00 maybe contact company. Digital Battery Charger Error Code Explanation Chart. Check the attached links,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
ERROR CODE DESCRIPTION REASON/ SOLUTION F01 The battery voltage is still under 10V (for a 12V battery) or 5V (for a 6V battery) after 2 hours of charging. Could be caused by trying to charge a 6V battery on a 12V setting or charger, or the battery could be bad, have it checked or replaced. F02 The charger cannot desulfate
the battery. The battery could not be desulfated, have it checked
or replaced. F03 The battery was unable to reach the "full charged" voltage. Could be caused by trying to charge a large battery or bank of batteries on too low of a current setting or the battery may have a shorted cell. Try again with a higher current setting or have the battery checked or replaced. F04 The connections to the battery
are reversed. The battery is connected backwards. Unplug the charger and reverse the connections to the battery. F05 The charger was unable to keep the battery fully charged in maintain mode. The battery won't hold a charge. Could be caused by a drain on the battery or the battery could be bad. Make sure there are no loads on the battery. If there are remove them.
If there are none, have the battery checked or replaced. F06 The charger detected that the battery may be getting too hot (thermal runaway). The charger automatically shuts the current off if it detects the battery may be getting too hot or the battery may have a shorted cell. Have the battery checked or replaced.
FAQS
Schumacher XP2260 Owner Manual
XP2260W Schumacher Portable Power 1200 Peak Amps
Mar 05, 2016 | Schumacher XP2260 6-in-1 Jump Starter
I need to see how the wires go inside a Schumacher SE-1052 battery charger.
Most likely that is not the case. Battery chargers that are not really old have current sensing and dont switch on unless there is a load attached to it. A totally dead battery wont be seen by the device and it wont charge it.
Jun 12, 2013 | Schumacher SE-1052 2/10/50 Battery Charger...
HAVE NO IDEA HOW TO READ THE METER ON SE-82-6...RED AND GREEN TRIANGLES...DON'T KNOW WHICH DIRECTION THE NMEEDLE'S SUPPOSED TO BE GOING.
The meter is telling you approximately how much current (amps) it is sending to the battery. When the meter moves all of the way to the right it is charging as hard as it can (that would be 6 Amps) which indicates that the battery needs a lot of charging. As the battery becomes saturated with charge, the meter will move toward the left. As the battery become charged, the unit automatically tapers off the current. The meter can indicate as little as little as zero Amps, meaning it is not charging the battery at all - which is the case when the battery is powered up, but isn't even connected to the battery. If it reads zero when it's connected to the battery, the battery is broken and can't be charged.
Since this charger is rated at 6 amps, it will indicate about 3 amps when the battery is about done. It won't normally go to zero because those 3 amps are getting wasted just heating up the battery.
Aug 16, 2010 | Schumacher & Fast Charge Starter Charger
When Charging a battery with charger do you set it on the 12 Volt 2amp or or 12volt,6amp My Charger is SE-82-6, H943
For charging a car battery that is run down, use the 6 amp setting. The 2 amp setting is for smaller batteries (like a motorcycle or lawn mower battery) or if you are using it to maintain a charge on a battery that is used infrequently (like a boat battery).
May 30, 2010 | Schumacher & Fast Charge Starter Charger
Schumacker battery charger problem?
You are charging. The meter corresponds to the level of charge in the battery. Try setting to 10 A for 4 hours, battery should be half-way up. To determine if battery id dead.. leave battery off charger once it is fully charged...test with a voltmeter after 10 min.....battery should still be above 12v...after1 hour it should still be above 12v...if not battery is spent.
Mar 11, 2009 | Schumacher & Fast Charge Starter Charger
I have a schumacher se-82-6,i dont use it much and have misplaced the instruction manual.how do i read the guage,when do i know battery is fully chargrd or battery wont charge? thanks erik
hope this helps.
Feb 02, 2009 | Schumacher & Fast Charge Starter Charger
Schumacher XP500 Jump Starter Logo
50 people viewed this question
Top Schumacher Air Tools & Compressors Experts
Marc Taylor
L Pfaff
L Pfaff
DonziGT230
DonziGT230
Are you a Schumacher Air Tool and Compressor Expert? Answer questions, earn points and help others
