Question about Ovens
Westinghouse pgh658 oven how to remove cover on light bulb ..does one lever it ? or twist it or ? thanks for any help ROB MOORE
HAVE only inspected oven and cover over the light have twisted the cover gently but do not want to proceed without knowing being sure of myself. thank you Rob moore
3 Suggested Answers
apart4u
  • 213 Answers
SOURCE: I can't get the bulb out of my bottom oven. It is
THEY LIGHT NORMALLY UN SCREWS ANTI CLOCKWISE HERE IS A LINK TO THE BULBS AND YOU MIGHT FIND THIS VIDEO HELP FULL
You-Tube video "j3TPHgf1MRg" placeholder (do not delete)
Posted on Jan 12, 2010
  • 523 Answers
SOURCE: Trying to change bulb in oven, but cant remove old
if its like a reg bulb it twists out
Posted on Apr 25, 2010
How to change light in oven westinghouse florentine
Turn off the power to the oven. Grip the glass light cover and turn anti-clockwise. I think the lamp then unscrews.
Replace lamp, turn on power and check if lamp lights up, replace cover twist clockwise to fasten.
Jun 29, 2014 | Ovens
How do i change the oven light
Hi your light bulb is at the back of your oven behind a glass cover just twist this glass antyclockwise to get access to bulb.
Apr 08, 2014 | Ovens
How do I remove cover to change interior light bulb ?
Welcome to FixYa.
In order to answer your question effectively, you'll need to provide a model number for your range and confirm it is indeed a Thermador oven.
There are simply too many different styles to generalize on how to simply "remove cover to change light". In fact some Thermador lens covers are square glass covers which pull off, others are round "dome" shaped which twist off and yet others are held in place via a single metal clip or fastened in placed with a metal bracket and two screws.
I'll watch for your post and be glad to assist you in solving this problem in whatever manner I can.
Thank you for choosing FixYa.
Regards,
Macmarkus :)
Mar 17, 2011 | Thermador Ovens
Replace oven light bulb? magic chef wall oven
for model 9815xub, the oven light consists of a light bulb cover(clear plastic, sometimes called lens) the light bulb receptacle( pressure mounted against the back wall of the oven ) and the light bulb, standard appliance bulb that screws into the receptacle, the same as the lens, it also screws into the receptacle, twist counter clockwise to remove both the lens and the bulb. as a reference try the following site:
www.partselect.com/ and type your model number in the window, then click on the oven cavity breakdown to view thwe assembly.
Jan 31, 2010 | Whirlpool RBS275PD Electric Single Oven
I CAN NOT GET THE LENS OFF OF THE OVEN LIGHT TO REPLACE IT
where is your oven light as i have no bulb or cover !! I have read that the cover should twist off maybe some wire holding it in place hope this helps
Jan 24, 2010 | Baumatic B151SS Single Oven
The bulb seems to have fused. How to remove the fused bulb and replace with a new one. Have I got to pull the oven out and fix it from the rear?
No, you should be able to replace it within the oven space. The cover should unscrew and reveal the bulb which you then remove and replace.
Jan 19, 2010 | Zanussi ZBS963X Electric Single Oven
No manual to Kenmore electric oven 8+ years old
if the glass bulb cover has a 'wire' across it that's the spring clip that holds it in place.pull clip down or aside to remove cover,unscrew bulb as you would any other.if it doesn't have aforementioned clip.try to rotate cover counterclockwise to disengage 'ears' from 'slots',similar to the the way a blender fits the base.look under cook-top,above oven door for the lock lever that must be pulled out [engaged] for self clean to work.
Oct 11, 2009 | Kenmore Ovens
How to replace oven light bulb for beko DC543 electric cooker
hi
You may need to remove the glass cover by turning it anti-clockwise.
On some models access to the bulb is from outside so the oven has to be slid out of it's housing and an access plate removed.
chek this following steps..
Step 1 Make sure the bulb is actually burned out. Confirm the oven is plugged in and that a circuit breaker is not tripped.
  • Step 2 Look for the manual to determine what size bulb is required. Most use a 40 watt appliance bulb. If you can not find the manual, then buy a bulb to replace it after you take out the old one.
  • Step 3 Confirm that the oven is not on. Allow it to cool to room temperature if it has recently been used.
  • Step 4 Open the door and use a flashlight to light the area where the bulb is located. Do not put weight on the door itself, but go in at an angle or sideways.
  • Step 5 Find the shield or cover over the bulb, gently pull or twist it off. Some glass covers are surrounded by a wire clip or a ring that is screwed in to the back.
  • Step 6 Gently remove either the wire clip or ring. Since the cover is most likely glass, be cautious. Unscrew the entire glass cover similar to a jar lid in older versions of ovens. Then repeat process if there is more than one bulb.
  • chek this usefull link
    http://www.espares.co.uk/advice/cookers-and-hobs/a/1/112/changing-your-oven-light-bulb.html
    hope u will b helpfull
    tnx for contactin fixya
    regards
    Jul 12, 2009 | Ovens
    Unable to remove the glass cover to change the light bulb in oven
    I went out and bought a 4 inch strap wrench from LOWE's. I had never heard of one before. After figuring out from the diagram how to use it, I wrapped it around the glass bulb cover and did a counterclockwise twist and off it came. P.S. I'm a girl so I feel pretty good about that project
    Jan 12, 2009 | Ovens
    Ovens Logo
    61 people viewed this question
    Top Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you an Oven Expert? Answer questions, earn points and help others
