Question about Jensen Car Audio & Video
Jensen SPX-17 has power and the blue light goes on but the sound level and base power is only about 10% performance level even after configuring the sound level on my new amp/receiver to a full +10. I
Jensen SPX-17 has power and the blue light goes on but the sound level and base power is only about 10% performance level even after configuring the sound level on my new amp/receiver to a full +10. I took the power board off and reattached another SPX-17's power board and everything was okay; so the problem is inside the power board box which I took apart to make sure all the wires were attached to their terminals and they were. What's the problem please. Gary
  • Jensen Master
  • 637 Answers
What made you determine that it was at 10%?
Posted on Nov 24, 2014
Duncan
  • 218 Answers
SOURCE: Need help in wiring speakers to amp.
The right speaker will connect to the R+ and R- terminals and the left speaker will connect to the L+ and L- terminals. Only one speaker per connection. If both speakers are not exactly the same brand, part number,size, etc. then they may NOT sound the same. Be sure to watch the polarity of the speakers so they don't interfere with each other. I.E. speaker + to amp + etc. Good luck.
Posted on May 11, 2007
KaeZoo
  • 156 Answers
SOURCE: How should I wire up this amp and sub
The amp's not actually a very good match for the sub, since the sub can be wired for 2 ohms or 8 ohms, and the amplifier is most efficient at 4 ohms in bridged mode. My advice would be to wire the amp in bridged mode, and wire the sub for an 8 ohm load. To do this, the amp's (+) wire should go to the (+) terminal on one of the sub's voice coils. Then run a wire from the (-) terminal on the OTHER voice coil to the (-) terminal on the amp. The remaining (+) and (-) terminals (on opposite voice coils) should be connected to each other with a wire. Your original wiring setup had the amplifier connected to only one voice coil, while the other voice coil was shorted.
Posted on Jun 10, 2007
Vulfen
  • 5 Answers
SOURCE: Jensen LXA400
I have this same amplifier. I have noticed several ways it will "not work" during my ownership of it. I have it connected to a seperate battery to save my alternator, battery, etc as it is a power hungry beast for how low the output wattage is. Test the input voltage to see if you have enough, one way to see this is to check the "jensen" emblem that lights up. If you dont have enough power it will appear dim and only the right side lights up. Also the amplifier will not work if your speakers are "blown" even a little bit. Ive taken speakers that wont work on my lxa400 and connected them to a higher power amp and they will work (although they will sound horrible) If youre smart you will keep the gain under 3/4 on this amp, I see some people have found out the hard way that full gain fries the amplifier circuitry. Not an expert on electronics but it smells somewhat like melting glue or plastic. Ive noticed a lot of people have problems with the RCA jacks as well. There are 8 jacks, in two clusters. The first one is A+B and the second is C+D. Note: You do not NEED Y connectors on this amp! Connect your output rcas from the deck to top left and bottom left jacks of the left cluster. This will give you left and right (a+b) output from the first set of speaker outs. Then connect an rca patch cord from the top right and bottom right jacks of the first cluster and connect the other end to the top left and bottom left of the second cluster. This will give you output from the second set of speaker outs. Remember that this is in 4 channel mode. I dont remember the set ups for 3 channel but two channel I believe is the left deck rca goes to top left of the first cluster and the right deck rca goes to the top left of the second cluster. Then you just wire the speaker outs according to the picture on the amplifier. something like this: _________________________ |(+) - (-) +| ~~~~~~~~~~~~~~~~~~~~~~~~~ Speaker + goes to (+) and speaker - goes to (-) Also addressing another issue if you want to increase the wattage to your speakers you just use a lower resistance speaker (2ohm instead of 4) I would not recommend using anything over 4 ohms. As for the high level inputs, I dont recommend using them unless you have the plugs that go with them, its a lot easier to wire your deck rears to a line converter (changes straight speaker wire to RCA jacks) or to just buy a new deck with RCA outs. Last item, common knowledge: 400 watts does NOT mean 400 watts!!! This amplifier puts out very little actual wattage (50 or 83 per channel depending on the load) Hope all this helps someone out there.. Anyone who knows the 3 channel setups I would appreciate it.
Posted on Jul 15, 2007
  • 113 Answers
SOURCE: Amp will not turn off and the Remote wire is correct.
check pwm chip ,may need replacing
Posted on Aug 22, 2007
SOURCE: Please help.... I need a wiring diagram or pinout for my Jensen xa1120 amp, thanks
xa 1120 amp pin out 123
456
1 left neg
2 ground to radio
3 left positive
4 right neg
5 blank-not used
6 right positive
Posted on Oct 10, 2008
Why is my Jensen SPX-17 home entertainment subwoofer only putting out about 10% functioning base power volume level and loudness?
Gary, If you have the subwoofer open, what did you keep from measuring the voltage of both power supplies? And while measuring, why not put a load on both, and see what current they can handle?
When the error moves with one component (power supply) the error must be there. Without a multimeter, (I have several, but I'm not close to the power supplies) you can't tell if the power supply is working to full performance. So start there.
Just try to find out, if a part of the rectifier is defect (one diode) It won't be possible to point out what is wrong, if you can't measure on the device yourself.
Sorry.
Nov 23, 2014 | Audio Players & Recorders
I can't get any sound out of my jensen spx-17 subwoofer
Pull the woofer out of the box and make sure it's hooked up on the inside, if so you will want to test the ohms reading off of your subwoofers terminals to make sure it's reading either 2 or 4 ohm which ever it's rated at to eliminate the woofer as the problem. After all of those have been done check your amps out put for power to the woofer and make sure your rca cables are hooked up correctly and have power.
Jul 01, 2012 | Car Audio & Video
What is the watts
Hi.
The Jensen XS-1010 is a 450-Watt 10" (450W peak, 150W RMS ) Subwoofer.
Below the full technical specifications:
Tech Specs
Product Type - Car subwoofer driver
Dimensions (WxDxH) / Weight - Car subwoofer driver : 4.7 in Diameter 10.1 in
Dimensions - Diameter - 10.1 in
Enclosure Color - Blue
Localization - English
Speaker Type - Passive
Speaker Diameter - 10"
Nominal (RMS) Output Power - 150 Watt
Max (RMS) Output Power - 450 Watt
Response Bandwidth - 24 - 1000 Hz
Input Impedance - 4 Ohm
Output Level (SPL) - 88 dB
Connectivity Technology - Wired
Speakers Included - Car subwoofer driver - 10" - 150 Watt - 24 - 1000 Hz - 4 Ohm - wired
Driver Details - Car subwoofer driver : 1 x subwoofer driver - 10" - polypropylene - Mid-Q
Diameter - 9 in
Depth - 4.4 in
Sep 07, 2011 | Jensen XS-1010 Car Subwoofer
My Jensen spx 17 sub makes a loud thump on turn on.Is this normal or an easily solved problem? Will it damage the cone?
all the spx17 will do that, no it should not damage the driver.
We usually suggest to customers that it is best to leave the Sub in the Auto switch position as this will allow it to automatically switch on and off without the loud pop.
Nov 16, 2009 | Jensen Audio Players & Recorders
Poor radio reception with Jensen VM9512 in 2001 Nissan Altima
If you used the 2 plug nissan radio harness, there should be a blue wire on there which is the (power antenna) even if your car doesn't have a power antenna, this wire needs to be connect to power on the am/fm amplified ant which is used in many nissan cars.
if the jensen has a blue or a blue/white wire, connect it to one of those. if not, you can always connect it to the red ACC wire. that should solve your reception problem..
hope this helps
Aug 25, 2009 | Audiovox VM9512 Car DVD Player
Jensen LCD JE1907DC keeps looping the Jensen intro logo.
I don't have a solution but do have the same problem.
I took it in a reputable shop and they told me the main board was gone and they could not get parts for it.
I just found out that Jensen is a Audiovox trademark.
May 18, 2009 | Jensen Televison & Video
Rane Mixer ttm 54
in sound system you have different sound level start with phono level up to line level up to speaker level.-you will switch to phono when you connect phonograph and you will switch to line when you connect another audio source like dvd and video sound.
Sep 01, 2007 | Rane PE 17 Home Equalizer
Car Audio & Video Logo
130 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
